Setting global array lengths in classes after loading
Page 1 of 1 [3 Posts]
witt0191
PostPosted: Tue Mar 23, 2010 8:48 pm    Post subject: Setting global array lengths in classes after loading Reply with quote  Mark this post and the followings unread
Playing with the graphics within the mini audicle but keep hitting a problem when building arrays of interface objects.
I think the problem I am having is to do with my understanding of using arrays.
The code I have works fine when I declare the length of the array with the class code. However it errors when I try and set this value after instantiating.
This works fine
class demo
//GUI
MAUI_View cip_eff_gui;
MAUI_Slider slider[3];
function void effectinterface(int k)
for (0 => int j; j < k; j++)
<<<"test">>>;
cip_eff_gui.addElement (slider[j]);
slider[j].precision(3);
slider[j].range(0., 10.0);
slider[j].position(0, (j * 100 + 50));
cip_eff_gui.display();
demo d;
d.effectinterface(3);
This does not work
class demo
int numsliders;
<<<numsliders>>>;
//GUI
MAUI_Slider slider[numsliders];
<<<"test">>>;
<<<numsliders>>>;
demo d;
3 => d.numsliders;
So any ideas how I can set numsliders after loading it.
Thanks in advance for any help.
Inventor
Audio files: 256
PostPosted: Tue Mar 23, 2010 9:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not really sure, but I think if you try MAUI_Slider sliders[]; that will work. Try it anyway.
Les
Kassen
PostPosted: Thu Mar 25, 2010 7:36 am    Post subject: Reply with quote  Mark this post and the followings unread
If you'd like to change the size of a array after the array has been instantiated then you'll need to use the .size() member function that all arrays have.
As it is the variable for setting the initial length of the array is just 0, the default value of a new int, at the time the array is instantiated.
Kassen
Niio2
