programmer/sequencer pots??
Page 1 of 1 [10 Posts]
fluxmonkey
PostPosted: Thu Mar 25, 2010 7:39 pm    Post subject: programmer/sequencer pots?? Reply with quote  Mark this post and the followings unread
does anybody know a US source for 100k linear pc-mount alpha 16mm pots, with 1/4" shafts, for the programmer/sequencer? log i can find, solder-lug i can find, knurled shaft i can find... they're all close but not seegar
www.fluxmonkey.com
numbernone
PostPosted: Thu Mar 25, 2010 7:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got mine from Mouser, but that was a couple years ago, and I bet you already checked there!
zthee
PostPosted: Fri Mar 26, 2010 12:57 am    Post subject: Reply with quote  Mark this post and the followings unread
http://au.mouser.com/ProductDetail/Alpha-Taiwan/RD901F-20-15R1-B100K/?qs=sGAEpiMZZMtxdMMi52izylmYYWNxsv7WyXawLcW4ogY%3d
http://au.mouser.com/ProductDetail/Alpha-Taiwan/RV24AF-22-15R1-B15/?qs=sGAEpiMZZMtxdMMi52izypa54xBHd1436WjtyPc0yck%3d
Maybe?
Rykhaard
PostPosted: Fri Mar 26, 2010 3:45 am    Post subject: Re: programmer/sequencer pots?? Reply with quote  Mark this post and the followings unread
Alpha Single-Gang 16mm PC Mount Vertical
Mouser 313-1510F-Value, Alpha RV16AF-20-15R1-Value
From Small Bear Electronics. One of my favourite suppliers from down in the U.S. Smile
fluxmonkey
PostPosted: Fri Mar 26, 2010 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
@zthee--those are 9mm, and seem a little flimsy in terms of holding the whole weight of the pc board
@Rykhaard--i think those are either log or knurled shaft.
yeah, seems like it should be simple...
Rykhaard
PostPosted: Fri Mar 26, 2010 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
They're smooth 1/4" shaft. They're the PC mount version of the one that I buy from SBE regularly. They're also linear. Either as well as value can be specified, when ordering, from a drop down menu.
From the link that I provided, type 'potentiometer' into the search window. The page that comes up, has the one that you're looking for, at the very bottom of it.
fluxmonkey
PostPosted: Fri Mar 26, 2010 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
this link: http://www.smallbearelec.com/Detail.bok?no=694 ? looks like 3 values available, all audio taper, unless i'm missing something...
www.fluxmonkey.com
stewpye
PostPosted: Fri Mar 26, 2010 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can't see the ones you want there either. You could email Small Bear and ask them...
Rykhaard
PostPosted: Sat Mar 27, 2010 4:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Bugger - my error on assumption, based on the other pot stock that he carries, normally.
However, if you can deal with right-angle PC mount, on page 2:
http://www.smallbearelec.com/Detail.bok?no=692
They're available in a much larger pile of values. (Visually checked. 100k linear, is in there.) As well as tapers. Linear, Audio and Reverse Audio.
zthee
PostPosted: Mon Mar 29, 2010 11:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've used 9mm for my programmer sequencer. Can't say it feels flimsy...
Smile
