  bingsatellites Mostly Ambient
Windows 7 and the editing software for my Micro Mod
Page 1 of 1 [18 Posts]
infradead
PostPosted: Fri Dec 11, 2009 12:35 pm    Post subject: Windows 7 and the editing software for my Micro Mod Reply with quote  Mark this post and the followings unread
Anyone know if the editing software will work under Window 7?
I did a quick search and didn't really have any luck.
I'm thinking about upgrading pretty soon but i'll stay xp if its going to have issues
KABELTON
PostPosted: Fri Apr 02, 2010 9:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi, i have the same qustion... Any news? Thx
www.kabelton.de
www.myspace.com/kabeltonlux
Stomper
PostPosted: Sun Apr 04, 2010 1:17 am    Post subject: Reply with quote  Mark this post and the followings unread
http://electro-music.com/forum/viewtopic.php?highlight=windows&t=35601
I think G1 and G2 are the same in this case. havent tried it myself though.
cappy2112
PostPosted: Tue Apr 06, 2010 11:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I wouldn't make that statement since the G2 requires a special USB driver just to work on Vista/Windows 7.
The NM1/G1 doesn't require a USB driver, but there may be compatibility issues.
mimolizer
PostPosted: Sat May 01, 2010 12:16 pm    Post subject: win 7 x64 editor problem
Subject description: win 7 x64 editor problem
My editor looses contact with my NM1 rack after a couple of seconds. I use a E-Mu 2x2 interface and windows 7 x64 and the editor v3.03.
Audio files: 116
G2 patch files: 317
PostPosted: Sat May 01, 2010 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you have another MIDI interface handy I'd try that ... NM has always been picky on the MIDI interface .. for me ever so since win95 and now on Vista, so likely on windows 7 too.
Or maybe you can try a compatibility mode (if having a windows 7 version supporting that on the end user level).
And welcome mimolizer.
mimolizer
PostPosted: Sun May 02, 2010 3:39 am    Post subject: win 7 x64 editor problem
Yes, the weird thing, that I forgot to mention is that the same setup works fine on my old computer with WinXp.
I tried using my M-Audio FireWire card as midi interface and it works! Thanks for the help! Must be the win7 drivers for the E-Mu 2x2 that are incompatible with the NM1.
cappy2112
PostPosted: Sun May 02, 2010 9:09 pm    Post subject: Re: win 7 x64 editor problem
If you're running W7- Have you tried using Virtual XP mode?
you'll need to download 3 installers from Microsoft to get a virtual xp machine running on W7.
http://www.microsoft.com/windows/virtual-pc/download.aspx
If you try this, let us know the results
mimolizer
PostPosted: Mon May 03, 2010 11:08 am    Post subject: win 7 x64 editor problem
I haven't tried Virtual XP, i have tried the compatibility mode though, and it didn't work. However, i've noticed that the E-Mu 2x2 complete destroys the performance of Cubase. When i run Cubase with the E-Mu plugged in, the sound glitches and as soon as I unplug it, everything works fine. Probably faulty drivers for the E-MU.
rayzr
PostPosted: Mon Nov 22, 2010 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
This is my first post and it is regarding the Micro Modular's communication
with the Editor (Both Clavia / Nomad versions) on Windows 7 x64.
My main interface is a MOTU 828 MK3, I have tried using the midi in/out on the 828
exclusively for the NM's Pc port and it reads "Waiting.." then followed by
"Still Waiting.." on the Clavia Editor.
Nomad seems to be the way to go based on reading what others are saying,
though I cannot seem to get this editor to find the NM either.
(A good way to start Nomad I found is to make a simple ".bat" file using
notepad and the command line "java -jar nomad.jar".)
I have tried both applications in XP Mode as well as a Virtualized Win 98SE.
Ideally, I would like to use a separate midi interface for the modular, So
I went ahead and picked up a M-Audio Midisport Uno 1x1 Usb Interface.
This also will not allow communication to either software editor.
However, once the Uno has been connected to the NM the LED light on
the Uno will begin flashing rapidly displaying activity.
Has anyone else experienced difficulties in Win7?
Has anyone got it working? Any Ideas?
twisted-space
PostPosted: Mon Nov 22, 2010 11:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Clavia editor v3.03 works fine here on win 7 x64, using either m-audio midisport uno or midisport 8x8s.
rayzr
PostPosted: Mon Nov 22, 2010 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
@twisted: was there anything further to your initial setup other than installing
the latest Uno driver and running the clavia 3.03 editor and selecting your midi ports?
I executed this same procedure and ended up with only "Still Looking.." for hours..
with quite a bit of sysex data being shifted around judging by the send light on the Uno.
At least I can now confirm that the Uno is a device which can handle such
demanding requirements. (as stated in the NM manual) *checks it off the list*
Also, a software/driver incompatibility is not likely the issue. Perhaps another piece
of software/driver is conflicting as I also own a MOTU MTP AV.
twisted-space
PostPosted: Mon Nov 22, 2010 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just downloaded the editor from clavia, and ran it, no special options or compatibility modes.
The driver I'm using with the uno is 5.10.0.5141
rayzr
PostPosted: Mon Nov 22, 2010 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
WTF.. man, All I needed to do was power cycle the NM and the
Nord Modular Editor v3.03 responded immediately displaying
all patches in all it's gloriousness.
Amazing. Excuse me while I punch myself in the nuts a few times.
Audio files: 116
G2 patch files: 317
PostPosted: Mon Nov 22, 2010 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
rayzr wrote:
WTF
Ah well, fixed is fixed Cool
twisted-space
PostPosted: Mon Nov 22, 2010 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool, glad you sorted it.
SamAndrew
PostPosted: Fri Jan 21, 2011 4:03 pm    Post subject: Works in Win 7 for me Reply with quote  Mark this post and the followings unread
I am using the Clavia NM editor 3 in Windows 7 and yes, it works fine for me. I chose "run as XP service pack 3" under the options>compatibility tab and also "run as administrator." May not even be necessary, though...
cappy2112
PostPosted: Mon Jan 02, 2012 4:42 pm    Post subject: Re: Works in Win 7 for me Reply with quote  Mark this post and the followings unread
Ok- good. I too will try this.
