my05
Joined: Jan 02, 2010 Posts: 26 Location: stockholm, sweden
Posted: Sat Apr 03, 2010 3:39 am Post subject:
My small Juno-106 repair thread Subject description: Some pictures and text around it |
Hello forum,
This january, i purchased a top cover from LektroiD here on this forum (thanks again, mate) and promised him to publish some pictures from my restoration of a juno-106 (replacing faulty wave-chips, voice-chips and quite a lot of other stuff).
I will try to put images and text in this thread later today and hopefully it will help someone else doing what i did. I am i no way a soldering expert but taking it slowly and methodically (and having a small enough soldering-iron) will definately help.
Stay tuned....
Kind regards
Daniel |
my05
Posted: Sun Apr 04, 2010 1:11 pm Post subject:
Opening her up and de-soldering voice chips, wave and 662 |
Why did i undertake this operation to begin with? First of all, two of my voices did not work. The sub-osc did not work either, nor did the white noice. I got the juno off Ebay from a german seller and it had seen better days (to say the least). The top-cover was very rusty (not kidding) and most things were loose (bender board for example). I had one of these over 20 years ago which i bought almost new with its original casing, etc. When the D50 arrived i went digial all the way and sold it (which i have regretted since). I then found this and purchased it, not knowing exactly what i was in for.....
The first thing i did was to extract the main board where the voice and wave chips are. There are 6 voice chips and 3 wave chips:
(Voice-W-Voice-Voice-W-Voice-Voice-W-Voice) counting the rightmost voice chip as number #1, etc (from right to left, 1 to 6)
| Before the "surgery" begins :-) |
3.17 MB |
| Viewed: |
140 Time(s) |
385.57 KB |
| Viewed: |
166 Time(s) |
my05
Posted: Sun Apr 04, 2010 1:15 pm Post subject:
While disconnecting everything, it is very wise to also document where the wires and stuff go...
278.22 KB |
| Viewed: |
130 Time(s) |
537.48 KB |
| Viewed: |
130 Time(s) |
3.46 MB |
| Viewed: |
121 Time(s) |
564.13 KB |
| Viewed: |
129 Time(s) |
460.09 KB |
| Viewed: |
138 Time(s) |
my05
Posted: Sun Apr 04, 2010 1:18 pm Post subject:
Time to desolder voice chips. Best thing is to have a small enough soldering iron and means to clean as much of the old solder as possible
304.64 KB |
| Viewed: |
120 Time(s) |
| Try not to do what i did and burn yourself in the finger. It hurts..... ;-) |
183.66 KB |
| Viewed: |
107 Time(s) |
my05
my05
Posted: Sun Apr 04, 2010 1:50 pm Post subject:
After doing the same for the other voice chip and the faulty Wave-chip (which was the cause of the missing sub-osc) it was time to swap the old rusty cover for the new one that i purchased from LektroiD.
First pictures of how the old rustbucket looked like:
77.81 KB |
| Viewed: |
124 Time(s) |
62.48 KB |
| Viewed: |
113 Time(s) |
84.43 KB |
| Viewed: |
119 Time(s) |
76.71 KB |
| Viewed: |
123 Time(s) |
86.79 KB |
| Viewed: |
117 Time(s) |
my05
Posted: Sun Apr 04, 2010 1:51 pm Post subject:
| To be continued tomorrow... |
Joined: Apr 03, 2004 Posts: 19623 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sun Apr 04, 2010 1:54 pm Post subject:
Nice thread Daniel! _________________ Jan |
my05
my05
Posted: Sun Apr 04, 2010 4:00 pm Post subject:
To swap the cover, you have to extract the jack board, midi board and control board + take out the power supply plug, etc. Did i mention that photo-documentation is key
Also, in my case i found it impossible to get the power plug out so i cut the wires and re-soldered them when the new top-cover was in place again.
278.02 KB |
| Viewed: |
126 Time(s) |
129.22 KB |
| Viewed: |
119 Time(s) |
| The panel board when extracted from the top-cover |
267.09 KB |
| Viewed: |
129 Time(s) |
| The fuse board. Soon to be cut to get the power-plug out... |
145.96 KB |
| Viewed: |
118 Time(s) |
my05
Posted: Sun Apr 04, 2010 4:07 pm Post subject:
Here, everything is lined up for soldering and assembly. Just reverse the procedure and be careful that you don't miss anything
237.64 KB |
| Viewed: |
124 Time(s) |
| put the midi-board back in place again |
131.41 KB |
| Viewed: |
124 Time(s) |
| the pushbuttons (i swapped them over from my old panel-board) |
125.3 KB |
| Viewed: |
119 Time(s) |
306.12 KB |
| Viewed: |
133 Time(s) |
| Solder back the power leads (be extremely careful not to swap the leads by mistake...) |
178.51 KB |
| Viewed: |
117 Time(s) |
my05
Audio files: 218
G2 patch files: 93
Joined: Jul 11, 2005 Posts: 4742 Location: Nambucca Heads, Australia
Audio files: 51
Posted: Tue Apr 06, 2010 3:22 am Post subject:
I would definitely look at replacing as many electrolytic caps as possible, starting with the biggest ones in the PSU.
This synth would be at least 20years old, and all the electrolytics would be drying out by now. Dodgy caps means dirty power rails, and when the big ones in the PSU get dry you end up with power rails which simply fail to deliver smooth, responsive power. This leads to transients being compromised and an increased noise level all round.
I know someone who has an M1 which recently became chronically distorted. Replacing 20 or so electrolytics (including the biggest PSU ones) has not only fixed the immediate problem, but has given it a "clearer, more dynamic sound than it has had for years." (This guy plays it live quite regularly) _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
We would lose our friends.
So,.........
Do you really want to lose yourself? |
my05
Posted: Tue Apr 06, 2010 3:28 am Post subject:
| Antimon wrote: | I've got nothing to add here except my compliments on a thorough job and documentation!
/Stefan |
Thank you Stefan,
In comparison to all the DYI:ers and skilled people on here, i haven't really done anything special to write home about
(Men tack ändå. Kul att någon kollar in tråden ).
regards
Daniel |
my05
Posted: Tue Apr 06, 2010 3:32 am Post subject:
| Uncle Krunkus wrote: | I would definitely look at replacing as many electrolytic caps as possible, starting with the biggest ones in the PSU.
I know someone who has an M1 which recently became chronically distorted. Replacing 20 or so electrolytics (including the biggest PSU ones) has not only fixed the immediate problem, but has given it a "clearer, more dynamic sound than it has had for years." (This guy plays it live quite regularly) |
Hi Uncle Krunkus,
That is indeed a good advice. I have replaced a bunch of capacitors on one of my old pc-mainboards (where the fluid leaked out at the top, causing the computer to re-boot sporadically) so it should be doable.
Hmmmm... time to open it up again and write down a shopping list for caps...
Thanks
regards
Daniel |
Audio files: 51
Posted: Tue Apr 06, 2010 4:24 am Post subject:
Remember that the most important part is the value (uF)
You can use caps which are over rated for voltage (ie, if the original is 25V you can use that voltage or higher, not lower)
Keep in mind that if you have to go for a replacement with a very much greater voltage rating, you need to check that it will still physically fit into the space provided.
Try to get the pitch of the leads the same, but this is not critical.
There are newer "Low ESR" caps which could even make the de-coupling better than it was originally.
I'm thinking of doing my D50 soon. It's of (almost) the same vintage. _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
So,.........
Ashe37
Posted: Sat Apr 24, 2010 2:03 am Post subject:
The noise on my Juno 106 doesn't work either. Have you checked the slider to see if it is changing values? _________________ E-Mu e6400 Ultra -Ensoniq VFX & ESQm
Korg M3, EMX-1 , MS2000BR
Roland MKS-50, Juno 106 Alesis Micron
Waldorf Blofeld |
my05
Posted: Sat Apr 24, 2010 11:21 am Post subject:
white-noice |
Hi Ashe,
I have but unfortunately nothing is heard besides a very slight change of "something" noice-like in the background. I have tried two different panel boards so i am pretty confident that the problem is elsewhere.
I did order two BA662's from Roland one week ago (still waiting for delivery). I assume (perhaps wrong?) that the 662 is used in this chain and can perhaps be the problem? They are not very expensive so i thought i might give it a shot
At the same time, i plan to exchange capacitors (as uncle krunkus suggested). I got all needed caps for the PSU (exact spec, only slightly smaller nowadays) and a load of caps for much of the rest. Soldering time soon...
I'll keep you posted on the white-noise issue.
Kind regards
Daniel |
my05
Posted: Mon May 03, 2010 2:30 am Post subject:
Small update Subject description: caps |
Still waiting for the 662:s from Roland. In the meantime, i followed Uncle Krunkus advice and replaced some caps. I started with the big ones in the PSU and da-daaaaaa: No more hissing in the background Thank you U.K.
Some images follows
(ps. and after 3 months of waiting, finally my wooden sides decided to show up. They were purchased from Synthwood)
272.15 KB |
| Viewed: |
127 Time(s) |
380.65 KB |
| Viewed: |
114 Time(s) |
| 25 year old caps, big and dry vs. modern counterparts (same specs) |
296.73 KB |
| Viewed: |
108 Time(s) |
Audio files: 51
Posted: Mon May 03, 2010 3:42 am Post subject:
So how is the noise issue?
Something tells me it should be easier to trace it out than other possible faults on a Juno106. But I could be wrong. At least with the caps done, the noise source should stick out like the proverbial canine testes!  _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
So,.........
jc175
Posted: Sat Jun 05, 2010 8:34 pm Post subject:
| Also looking for some information on fixing the noise generator - i own a Juno which is in perfect condition sans for the noise slider having absolutely no effect. If anyone's got any information it would be ridiculously helpful, cheers. |
my05
Posted: Sat Jun 05, 2010 10:36 pm Post subject:
| jc175 wrote: | | Also looking for some information on fixing the noise generator - i own a Juno which is in perfect condition sans for the noise slider having absolutely no effect. If anyone's got any information it would be ridiculously helpful, cheers. |
Unkle and JC,
Still waiting for the 662:s from Roland (they had to order them from Denmark and it has taken more time than planned). I called the service center last week and they said they would ship on Friday (2 days ago). We'll see. I went back to the electronics store (ELFA in the european countries) and got me some more caps (might as well do as much as i can muster while i am opening it up again to replace the 662:s). I'll let you know if this solves the noice-issues. Stay tuned.
Kind regards
Daniel |
my05
Posted: Sun Aug 08, 2010 2:00 pm Post subject:
update - white noise |
Just wanted to drop by and update you guys
Got the 662:s and replaced them. That did not have any effect at all on the noise generator issue (altough not very expensive, it took some time to replace these - fully functional - chips.
Voice #6 decided to "kill" itself (the tone from it goes on forever and never fades away in the background) so a new clone chip is ordered.
kind regards
Daniel |
my05
Posted: Sun Sep 05, 2010 7:49 am Post subject:
Restoration - the sequel |
Well, i'm still at it. I finally got my voice-chips from D'naab in Belgium (analoguerenaissance.com) to fix my faulty number 6 voice (it emmited a weak tone in the background when the #6 voice was released). Ordered one extra just in case since i believe the rest of the Roland chips will soon start to act up as well.
Anyway, i managed to source a replacement for the noise generator transistor from a swedish company called "Elfa". The name/brand of this particular transistor is "NTE289A" in case anyone is interested. Afaik, this particular transistor is getting hard to source since they do not fulfill environmental directives (but again, there will probably be others that will and that matches the original....).
Long story short, i replace the original "NZ" transistor and.... didn't work
Everything works great now except for this ¤&#//"(# white noise part.
kind regards
Daniel |
