  Muied Lumens Frequencies
Death of a VCS...lets make it work again
Page 1 of 1 [4 Posts]
numbernone
PostPosted: Sat Apr 10, 2010 12:10 pm    Post subject: Death of a VCS...lets make it work again Reply with quote  Mark this post and the followings unread
One of my pair of VCS blew out this morning, after working A+ from first power and the following month or two. The 10ohm resistor on the positive rail burned up real good. It has been replaced, and I have also swapped a new set of ICs for kicks. So now, on power up in cycle mode monitoring the voltage at the main output, it just rises steadily and slowly from about .5v....very slowly...peaking at just over 9v+ and then just as slowly descending. It takes approx 7 minutes to just go up. This voltage seems far higher than expected as well. the rise/fall have an extremely miniscule effect on the rates as would be expected. Timing cap someplace not being discharged properly??? Very wacky this.
I can find no physical faults, and as I said this has been working perfectly for a good while now.
Any hints where to begin the serious poking would be appreciated.
numbernone
PostPosted: Sat Apr 10, 2010 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
FIXED
MODS PLESE DELETE
THANKS!!!!
Audio files: 213
G2 patch files: 319
PostPosted: Sat Apr 10, 2010 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
More interesting than deletion, for the readers, may be to read how you fixed it Cool
numbernone
PostPosted: Sat Apr 10, 2010 9:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Stray wire strand bridged one end of the rise pot and the wiper it seems. It got fried. Replaced. It works again.
