Thomas Henry's SN76477 Super Controller Module
Page 9 of 10 [232 Posts]
Goto page: Previous 1, 2, 3, ..., 7, 8, 9, 10 Next
Is there an interest in Super Controller PCBs?
Yes, by all means.
95%
 95%  [ 23 ]
No, it just doesn't cut the mustard, i think.
0%
 0%  [ 0 ]
I don't know. I mean, i... er...
4%
 4%  [ 1 ]
Total Votes : 24
Luka
PostPosted: Mon Mar 09, 2009 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
ahh ok cool
ill add a little led driver for gate/trig then
thanks for info mate
i look forward to getting the pcb
problemchild
melbourne australia
Luka
PostPosted: Fri Jul 31, 2009 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
hihi
im wiring up my SCM and am confused about the 3 position switches
you mention that you use a 1 pole on-off-on
how is this done?
does that mean that one state is always on?
problemchild
melbourne australia
Luka
PostPosted: Fri Jul 31, 2009 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
i just noticed the picture in the other thread
oh is everyone using rotaries for s1, s2, s4 ?
im limited to space
can this be done with toggles?
problemchild
melbourne australia
mark_olson
PostPosted: Fri Jul 31, 2009 7:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Luka wrote:
...is everyone using rotaries for s1, s2, s4 ?
...can this be done with toggles?
I am sourcing parts and working out a panel for this module right now so the issues associated with it are on my mind. I am using rotaries for those three but you can definitely do it with toggles. Here's a link to fonik's schematic:
http://www.modular.fonik.de/files/ononon.gif
I think he posted an english translation on the em forum once but I can't find it - the picture tells the story well enough though, I think.
Good luck,
Mark
Luka
PostPosted: Fri Jul 31, 2009 9:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok great thanks
problemchild
melbourne australia
Luka
PostPosted: Mon Aug 24, 2009 4:09 am    Post subject: Reply with quote  Mark this post and the followings unread
well mine is pretty much working except for noise
is the ha17458 a swap for a lm1458?
problemchild
melbourne australia
PostPosted: Mon Aug 24, 2009 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
you could use any common dual opamp with same layout. i think i used a TL072.
what's the issue?
fonitronik at
Luka
PostPosted: Mon Aug 24, 2009 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
oh cool ill try swap it out
well my noise is not working
im just getting a 5.5 dc offset from the out jack
my wiring on this module has been really bad Embarassed hehe
i really should read the build docs more thoroughly before wiring
ive had to rewire almost the entire thing Smile
problemchild
melbourne australia
Tronato
PostPosted: Sun May 02, 2010 11:02 am    Post subject: Silence Reply with quote  Mark this post and the followings unread
Hello all!
Not much talk about the Super Controller for some time now... what happened?
Did anybody succesfully build and use one?
Any samples?
Have a nice weekend!
TRON
SolderSmoke
PostPosted: Sun May 02, 2010 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Have anybody made an MOTM frontpanel for this?
new voodoo
PostPosted: Sat Nov 30, 2013 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
just, you know, in case smeone wants to MAKE MORE..id be down for a few..just so whoever knows..Im DEFINATELY interested..yep..me, interested. yep. jst FYI
www.newvoodoodesign.com
-my creations, bends & bendable pieces
-vintage parts & tubes, IC's & audio chips
-oddities & weird
newvoodoo.blogspot.com
-bending DIY/projects
-crap
PostPosted: Sun Dec 01, 2013 6:21 am    Post subject: Reply with quote  Mark this post and the followings unread
good to know.
i am currently struggling with a new PCB design. still tryig to find the error. anyways, something is in the works, and there will be a printed eurorack front panel for this one...
fonitronik at
Dan Lavin
Audio files: 21
PostPosted: Thu Dec 05, 2013 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Matthias, could the error be in the one we found with the original pcb payout? Remember there was an error in the schematic as confirmed by TH? I believe it was a transistor.
Synth DIY since 1977!
PostPosted: Thu Dec 12, 2013 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the suggestion.
i can remember that error, however, the error was in the original schematic from the book and on the 1st prototype accordingly. this has been corrected both in the redrawn schematic and in the manufactured PCB.
since i made the new design from the working redrawn schematic/PCB this should not be the problem.
in fact i see 5V on the 5V rail as long as no SN76477 is in the socket. as soon as i put it in the 5V rail changes to 7V (sic!)...
alas, i had the wrong socket on the PCB in the first place and had to remove it, which did not work well. i guess i did something to the PCB when removing the socket. i am currently assembling the spare PCB. hope it works well then...
fonitronik at
PostPosted: Wed Jan 15, 2014 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
so some progress. a little. i now see the 5V. obviously a fault/short in the PCB after removing the wrong socket... Rolling Eyes
okay. the sn76477 ist still not working though. ridiculous. more checks to do...
fonitronik at
infraxpert
PostPosted: Tue Feb 11, 2014 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would love a couple of these when they are ready.
Hope the hard work pays off.
PostPosted: Tue Feb 11, 2014 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks.
i want one more myself, too. Very Happy
fonitronik at
Ayab
PostPosted: Wed May 24, 2017 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Any news on another run of the Super Controller PCB?
I would definitely be interested if you go ahead.
Thanks Very Happy
PostPosted: Tue Aug 08, 2017 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
With blessings from Matthias and using a Eurorack Front panel designed by Cameron Korth, and an SMT PCB for it, we are creating a new version of the Super Controller with a couple extra features. Kits, panels, and PCB's will be available through Synthcube. I am in the midst of doing the dimensioning and layout will be next.
Further status shall be reported in this thread.
Bill
Ayab
PostPosted: Wed Aug 16, 2017 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bill
Really looking forward to this and if you can send me a pm when it is done that would be great! Very Happy
PostPosted: Sat Mar 10, 2018 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Finally the Eurorack Supercontroller front panels are completed by CJ Korth and I have completed the design and testing of the new SMT PC Board. Everything has gone well and another classic design by Thomas Henry has now been cast into the popular EURORACK modular format.
The panels and PC boards will be sold over at Synthcube later this spring.
http://synthcube.com/cart/forums.html?route=product/search&search=sn%20voice&description=true
http://synthcube.com/cart/fonitronik-en
 Filesize:  89.48 KB
 Viewed:  85 Time(s)
 Filesize:  359.84 KB
 Viewed:  93 Time(s)
 Filesize:  94.89 KB
 Viewed:  79 Time(s)
PostPosted: Sat Mar 10, 2018 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
yay!
fonitronik at
PostPosted: Sat Mar 10, 2018 11:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
cheers
Dan Lavin
Audio files: 21
PostPosted: Fri Apr 06, 2018 12:38 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Not sure how I missed this before today, Bill, but dang! That's great! I'll definitely be getting one of these to replace my old 19" rack version. Very Happy
One question: those 2 trimmers on the back. Are you sure the screw portion will clear a rack rail? I suppose you could get the kind that have the screw facing up instead of on the side, in a pinch.
Ayab
PostPosted: Fri Apr 20, 2018 5:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great news. Will they be stocked by Thonk in UK?
