cloudscapes
Posted: Mon Jan 11, 2010 10:40 am Post subject:
First synth design brainstorm.. |
Over the last several weeks I've been thinking about how to make my first non-modular synth and I figure now's a good time to start writing up a design document. Here's a test I built on the weekend:
http://nearworlds.org/stuff/diy/diy_synth_01.mp3
http://nearworlds.org/stuff/diy/diy_synth_02.mp3
It's an AVR controlling a 12bit DAC control-voltaging an XR2206 func generator. I think this is how I will make the oscillators. I'm quite pleased with how it sounds, and the 12bit DAC resolution is good for 30hz-8000hz with a bit of drift (but I don't mind drift). I'd use 16bit but I haven't found many affordable ones in DIP (that weren't parallel). I've already got a DAC word data table for each note! I'll be using an SSM2044 as a filter and I'll be generating the LFOs and ADSRs on the AVR. Or on another if it gets resource-heavy. There are other things I want to do like programable 2399 delay and stuff, but they can wait. Patches are a must.
Then it dawned on me how many DACs I'd need.
- 4 DACs for the two VCOs (two 12bit for freq, two 8bit for mix)
- 1 DAC for noise mix (8bit)
- 2 DACs for the LPF (8bit for resonance and freq)
- 4/8 DACs for the 2/4 LFOs (8bit for the wave, 8bit for the depth)
- 2/4 DACs for the 2/4 ADSRs (12bit for the shape, don't need depth)
- others for the extra stuff I want, 2399 control, chorus, etc)
...then I made a face.
Am I doing this right? Do I have the right idea? There are a few octal DACs (8bit) in small-ish DIP packages on mouser (TLC5628), and I'll be using the MCP4822 double 12bit DACs where I need the resolution, but it still adds up to so much! I can share the SPI line but I'll still need many pins for chip select! There are also the ADCs I'll need for pots, though I suppose I can use a 16->1 channel multiplexer for that.
I haven't looked much into multiplexers in the past but I think I'll be needing some for switching between waveforms, routing LFOs, stuff like that also.
Am I crazy or am I sort of on the right track? I'm amazed at what a lot of you come up with here and so I will seriously consider to any tips you may have. Building a modular isn't really an option for me. I need it to be ultra-portable (throw it i na backpack with other stuff) and I'll be doing much of the flexibility in code. _________________ Sonic Crayon DIY effects lab |
DrJustice
Joined: Sep 13, 2004 Posts: 2114 Location: Morokulien
Posted: Mon Jan 11, 2010 12:10 pm Post subject:
You could use a single DAC and a multiplexer with a sample and hold on each output. That's how it's usually done.
DJ
cloudscapes
Posted: Mon Jan 11, 2010 12:14 pm Post subject:
DrJustice wrote: | You could use a single DAC and a multiplexer with a sample and hold on each output. That's how it's usually done.
DJ
Thanks for the reply!
Aren't sample&holds really expensive? The only I know of is the AD781 it I can't find it for less than $10 online. _________________ Sonic Crayon DIY effects lab |
magman
Joined: Feb 04, 2009 Posts: 363 Location: Liverpool, UK
Posted: Mon Jan 11, 2010 12:24 pm Post subject:
I've seen quite a few synth designs that use SSM chips, like the SSM2300 and the SSM5510. These are Octal S&H designs - so 8 S&H circuits in one chip.
You can get the SSM2300 from Vintage Planet for less than 18 euro's, though the SSM5510 is more like $60.
I keep an eye on this sort of chip, as I would like to work on some computer controlled designs in the not too distant future.
Regards
Magman |
DrJustice
cloudscapes
Posted: Mon Jan 11, 2010 3:24 pm Post subject:
magman wrote: | I've seen quite a few synth designs that use SSM chips, like the SSM2300 and the SSM5510. These are Octal S&H designs - so 8 S&H circuits in one chip.
Regards
Magman |
Oh wow! That these chips exist is such a great idea! I hadn't thought of looking for specifically this kind of thing. I feel especially dumb because I'm sure at some point I looked at every single SSM chip. I'm sure I looked right over this not knowing what it was exactly they did or how they were useful.
Thank you!
Apparently the AD SMP08 is a drop-in replacement. Still expensive, but a bit cheaper (by ebay prices).
DrJustice wrote: | cloudscapes wrote: | Aren't sample&holds really expensive? |
Not at all, you just need a cheap opamp (packages with four are probably cheapest) and a capacitor for each s&h. Something like the attached schematic. The switching is done by your multiplexer, usually a CD4051, so you need no other components. This is the exact method used in almost every commercial programmable analogue synth since it works well and is very cost effective.
DJ
Thank you! I haven't really considered this, though now it makes sense looking at it. I have a few dozen quad opamps I might use.
This is very helpful. If it works it means I can go with full 12bit resolution for anything. I think I'll still buy a couple SMP08 or SSM2300 to try out. I want to measure my options. Guess I'll also do some Mouser trolling tonight and see if I can find other multiplexers with this S&H behavior. _________________ Sonic Crayon DIY effects lab |
cloudscapes
Posted: Mon Jan 11, 2010 4:38 pm Post subject:
Just tried the S&H opamp trick, works perfectly! Didn't have a multiplexer on me but I could still see. Used a 0.1uf simply because I have a billion of those lying around.
It'll amount to a lot of parts. More chips than using many DACs, but I'll get more resolution out of it and it'll be cheaper! _________________ Sonic Crayon DIY effects lab |
cloudscapes
KammutierSpule
Joined: Feb 07, 2008 Posts: 40 Location: Aveiro - Portugal
cloudscapes
Posted: Thu Apr 08, 2010 11:43 am Post subject:
Thank you!
Still, I think many bits even for an LFO could be useful. That way I could have the DAC draw out the shape of the LFO as well as the amplitude as a single CV. no seperate CVs for the LFO wave and it's depth. I've already found a 16bit DAC that works with the AVR, the PT8211. _________________ Sonic Crayon DIY effects lab |
volting
Posted: Sun May 09, 2010 5:33 am Post subject:
Hi cloudscapes,
I just got a bunch of XR2206's, wondering how you have wired them up to be voltage controlled. I cant seem find any clear information on how to do that in the datasheet (or anywhere else for that matter).
Thanks,
v |
