MFOS Dual VCO's
Page 1 of 1 [12 Posts]
Audio files: 69
PostPosted: Fri Mar 12, 2010 7:08 am    Post subject: MFOS Dual VCO's
Subject description: squeezing 2 into a panel in my quest for free panel space(gate) :D
Next project... 2 MFOS VCO's into one panel , i've 4 of rays vco's so i'm doing 2 of these.
Adding PWM level in.
2 each log cv level in's.
Changing relevant resistors & caps to bring them up to Ray's latest vco version Rev D 2009.
Ready to wire shortly then re-calibrate them.
Here's the first module ready to connect up to the panel....
 Filesize:  89.5 KB
 Viewed:  130 Time(s)
www.myspace.com/skrogproductions
Last edited by Skrog Productions on Fri May 14, 2010 11:37 am; edited 1 time in total
jordroid
PostPosted: Fri Mar 12, 2010 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Very commendable! I have just spent a bunch of time listening to your music on myspace also, great stuff, very impressive.
loydb
PostPosted: Fri Mar 12, 2010 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice!
Audio files: 69
PostPosted: Fri May 14, 2010 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Jorderoid ..
Loydb..
Thanks for having a look , cheers Smile
Another 2 Vco's are coming soon , fab.
Audio files: 69
PostPosted: Fri May 14, 2010 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello.....
Now have 4 working & tuned mfos Vco's , really happy with their stability after 20min warm up .
2 more vco's to build yet , will be a 6 vco machine in the autumn Smile .
i played some notes into my RM1X midi sequencer that was hooked up to the Poly-dac 4 channel midi to cv converter then patched up 4 , single vco monosynths , 2 with wave folders and 2 with sub osc and recorded this (with help from a friend).
Anyone familiar with a classic sci-fi/horror story with a tall man from Morningside
will smile at the wrong key & bum notes Very Happy heh .
 Filesize:  371.4 KB
 Viewed:  108 Time(s)
 Filesize:  268.05 KB
 Viewed:  126 Time(s)
phantasm.mp3
 Filename:  phantasm.mp3
 Filesize:  6.26 MB
 Downloaded:  251 Time(s)
Audio files: 254
PostPosted: Sat May 15, 2010 3:44 pm    Post subject: phantasm.mp3 Reply with quote  Mark this post and the followings unread
"You play a good game boy, but the game is finished, now you die"
Awesome! I could just feel the tall man creep up on me,..
Thanks for doing this one.
http://www.acidtrash.com/
droffset
PostPosted: Sat May 15, 2010 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ha, I love those movies! Good stuff.
https://docs.google.com/Doc?docid=0AZIwOP-PR9sSZDlidzgzbV8wY3RjenJqanY&hl=en
Edit: Spelling mistakes.
Audio files: 69
PostPosted: Mon May 17, 2010 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Photon
PostPosted: Tue Jun 01, 2010 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dave,
What value pots did you use for CV attenuation?
Audio files: 27
PostPosted: Wed Jun 02, 2010 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Fantastic synthesizer and sounds. One can only imagine what you will do as you add more VCOs to your system.
Audio files: 69
PostPosted: Wed Jun 02, 2010 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Photon wrote:
Dave,
Hi Photon
I just used 100K pots as all of my attenuators on all the modules , i have cut down on extra patch cables by a few re-designs of some panels that commonly needed an audio mixer or cv mixer and built a mixer in (vcf's & vca's).
Audio files: 69
PostPosted: Wed Jun 02, 2010 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Kevin
Thanks for having a look & listen , you will hear the synth working out on my 2 projects "Epicyclus & Orchard" , There will be new, fresh sequency stuff on the upcoming EM summer solstice performing as Epicyclus, looking forward to hearing all the perfomers on the day sunny
