em10 Laptop Battle Circuit
Page 1 of 1 [5 Posts]
Inventor
Audio files: 267
PostPosted: Tue May 11, 2010 4:48 pm    Post subject: em10 Laptop Battle Circuit
Subject description: A design for the em10 Laptop Battle
I'm planning something special for the electro-music 2010 festival's laptop battle. The rules are very flexible and allow other stuff besides laptops including guitars, keyboards, turntables, whatever... so I thought I would breadboard a circuit.
And I happened to have a working KS board not in use so I drilled some holes in the breadboard's metal base and mounted the KS board onto the breadboard. Then I soldered seven wires to hook the KS circuit up electrically.
Now I'm going to add a BS circuit on the breadboard to create a song. We'll see how it goes, any suggestions?
Les
The breadboard with a KS attached and hooked up to it
 Filesize:  312.41 KB
 Viewed:  336 Time(s)
Inventor
Audio files: 267
PostPosted: Thu May 13, 2010 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well it turned out very well after all. In the image below you see the circuit that I created to drive the KS board. It is a dual BS to accommodate the two CV inputs of the KS. It's amazing the variety of songs and sounds that come out of this thing. I'll be featuring it on my show tonight.
Les
The BSKS circuit
 Filesize:  322.8 KB
 Viewed:  413 Time(s)
Inventor
Audio files: 267
PostPosted: Fri May 14, 2010 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a tune I made with the BSKS circuit by twiddling the knobs.
Les
BSKS Tune 20100513 2143.mp3
BSKS tune
 Filename:  BSKS Tune 20100513 2143.mp3
 Filesize:  3.05 MB
 Downloaded:  603 Time(s)
Dan Lavin
Audio files: 21
PostPosted: Sat May 15, 2010 6:46 am    Post subject: Reply with quote  Mark this post and the followings unread
fun stuff, Les!
Synth DIY since 1977!
Inventor
Audio files: 267
PostPosted: Thu May 20, 2010 12:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Dan Lavin wrote:
fun stuff, Les!
Ty Dan! Here is a "track" that I created with the latest version of the breadboard.
Les
BSKS1.mp3
Boolean Sequenced Karplus Strong 1
 Filename:  BSKS1.mp3
 Filesize:  3.08 MB
 Downloaded:  537 Time(s)
