Dream Synths
Page 1 of 2 [45 Posts]
Inventor
Audio files: 256
PostPosted: Thu May 20, 2010 3:30 am    Post subject: Dream Synths
Subject description: schmooze about it
I just figured out my dream synth and I'm gonna build it. What's your dream synth?
Les
iPassenger
G2 patch files: 78
PostPosted: Thu May 20, 2010 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Well I am not sure I have a dream synth but I dreamt about a drum machine once, it was similar to the Machinedrum I've got but a bit fatter looking with a larger red screen.. It had a fully analog section for sculpting your own drum sounds from and a sampler section with a analog filter and distortions but importantly it was all neatly put together with a similar interface of that of the Machinedrum. In other words it was easy to use, logical and a proper instrument.
I was gutted when I woke up and realised that I neither had one nor did it exist. Sad
iP (Ross)
nobody
PostPosted: Thu May 20, 2010 6:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I literally have a dream synth. When I was a kid, I dreamt I walked into an old childhood bedroom of mine. On the bed was a 61-key synth that looked like a much-simplified Yamaha Motif (of course, the Motif wasn't even invented at the time of my dream, I'm describing it with what I know now). I did not need to physically touch the synth or be connected to it in any physical way. I thought the music and the synth played whatever I was thinking.
I woke up, naturally, going "Holy shit! I need one of those!"
Audio files: 211
G2 patch files: 92
PostPosted: Thu May 20, 2010 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I always forget my dreams, but I've daydreamed a bit about controllers like these (my submissions for that portugese invention competition someone posted about here some time ago - I forget what it was called).
 Filesize:  122.95 KB
 Viewed:  60 Time(s)
 Filesize:  176.87 KB
 Viewed:  64 Time(s)
GovernorSilver
PostPosted: Thu May 20, 2010 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Someone on the fiddle forum dreamt up a Roland Virtual Violin (he didn't say that specifically, but his description was eerily close to that of a Roland VG-99, except for violins). You could plug a polyphonic pickup violin, and have a choice of violin models (Guarneri model, Stradivari model, baritone model, custom model, etc.), non-violin instrument models (brass, woodwinds, Er-Hu, Kemancheh, the near-obligatory "synth" model, etc.) plus the usual assortment of pedal and amp models.
So I guess the Roland VV-99 would be my dream synth too.
VIRB site
pyrosonic
PostPosted: Thu May 20, 2010 8:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
A 16 part multitimbral Nord G2X with an added module that plays samples like the Wave.
Yeah,I think that would do me just fine.
http://soundcloud.com/pyrosonic-1
https://www.facebook.com/pages/Pyrosonic/106761076017889
https://www.facebook.com/pages/Whorlweaver/133469163426410
http://www.youtube.com/user/pyrosonic
http://www.myspace.com/pyrosonicmusic
nobody
PostPosted: Fri May 21, 2010 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Stefan, those arrays are cool. Why not build one? What about a combo wheel/track ball array?
nobody
PostPosted: Fri May 21, 2010 7:58 am    Post subject: Re: Dream Synths
Les
Wanna share?
Audio files: 211
G2 patch files: 92
PostPosted: Fri May 21, 2010 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
While I've had fun soldering kits, actually working out the electronics behind something like this is something I can't handle. Actually, I tried studying electronics at one time, and it drove me up the wall (two hours looking at an equation, a teacher walks by and says "Oh, you can approximate that this value is so small/large that it doesn't matter - take it out of the equation" - I don't do that stuff, it's on or off for me).
Glad you liked it anyway. Smile A combo could work too!
/Stefan
Audio files: 27
PostPosted: Fri May 21, 2010 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Interesting question, really. A tough one for me to answer.
Digital Dream Synth
My K2600 is as close to a digital "dream synth" as I can imagine. Ever since I encountered a Kurzweil for the first time (back around 1989) I dreamed of owning something like that however the five-figure price put it into the "unobtainable" category. When I found a K2600 for under $2K (back around 2002) I jumped at the opportunity -- since then I installed the sampling option, additional sample memory, and the DADAT-26 which enables 8-channel, 48khz/24 bit output. I kind of lucked out to find a K2600 at the price.
Analog Dream synth
The Aries is still a dream-synth for me. As of 1980, I had expanded it to be a good "meat-and-potatoes" keyboard modular synth. I mention keyboards because it is biased towards keyboard performance and when I built it I was interested in Switched-on music a la Carlos. I'm now adding new, more exotic modules for control, processing, and signal generation.
As far as my dreams, I dream more about the music I'd like to do than the hardware -- the hardware is the means to the music. Since I like to do multi-track and looping work, I strive for clarity and excellent s/n ratios. In the "old days" noise buildup while tracking and looping was a big issue.
Dream p/a system
My musical dream is to play through more channels -- currently my system supports 5.1 however I'd like to expand it and have some speakers in non-standard locations. The sound-design with 5.1 is somewhat limited in live-performance spaces -- particularly in the sense that the sound source is limited to the periphery of the listening space. I'd like to put speakers over and in the middle of the listeners, for example.
I'm developing a voltage-controlled quad (or greater) panner for the Aries synth -- still in the works and to some extent, such a module will help me to realize some of my ideas.
Inventor
Audio files: 256
PostPosted: Fri May 21, 2010 10:46 am    Post subject: Re: Dream Synths
audiodef wrote:
Les
Wanna share?
It's the Credit Card Synth, described in this thread:
http://www.electro-music.com/forum/topic-41976.html
It's a very simple little thing, but to me it is a dream come true because I've been working in software and hardware developing and exploring this thing for about two and a half years now. It's a dreamy little thing, lol.
Les
Octahedra
PostPosted: Fri May 21, 2010 10:52 am    Post subject: Re: Dream Synths
First thing that occurs to me: I'd like a Poly Evolver with 16 voices/parts, independent full audio fx, and (this is the bit you can't do by patching multiple hardware together) microtonal scales on each voice.
As for a completely new design, I really like the idea of a polyphonic/multitimbral virtual modular, but programmable directly through its own hardware interface, rather than (as in the Nord ones) depending on software that might not get updated to keep it compatible with newer operating systems. I've always programmed by the front panel rather than software - my first synth was a DX11, and after that piece of evil, nothing scares me! Cool
Looks like some people are working on this idea...
http://www.johnbowen.com/solaris-overview.html
http://www.arturia.com/evolution/en/products/origin/intro.html
Gordon
Inventor
Audio files: 256
PostPosted: Fri May 21, 2010 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a thought based on that ball array. Put a 3-axis accelerometer chip controlling the audio of some noise maker in a ball. The ball is a whiffle ball with holes in it so an internal speaker can be heard. Then when you roll the ball around it makes sound. Cute, maybe not a dream synth but cute i guess.
Les
Audio files: 211
G2 patch files: 92
PostPosted: Fri May 21, 2010 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Les
Cool idea! I'd like to have an accelerometer in a ball and use it as a controller! I've tried using Wiimotes and phones for controlling, but I always think it feels kind of awkward. If you had one in a ball, resting in a trackball crevace, you would have really good control of the movements. The tricky part is getting the accelerometer data stream... would probably require some kind of wireless transmission, which might be extra tricky in an object that is constantly spinning around.
/Stefan
G2 patch files: 584
PostPosted: Fri May 21, 2010 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
What about mounting the guts of an optical mouse under each ball (free back light). Use a microcontroller to glue all the USB signals together.
Inventor
Audio files: 256
PostPosted: Fri May 21, 2010 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
One way to build this interface is to simply mount an array of trackballs onto a backing plate and use USB hubs to connect them all to the computer... Not sure if some limit on the number of mouse encoders exists.
Les
Audio files: 211
G2 patch files: 92
PostPosted: Fri May 21, 2010 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've actually had that as a project in the back of my head for some time. I guess that besides being bad at electronics I'm also lazy. Wink But I've checked that ChucK can handle several mice/trackballs/touchpads/whatever on OSX, which it does!
/Stefan
Audio files: 211
G2 patch files: 92
PostPosted: Fri May 21, 2010 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Besides, I'm actually more excited about the wheel array. I love the feel of a mod wheel - you can control it in a precise manner. If you could make the wheels roll endlessly (perhaps using some optical tech like with mice or trackballs) I think it would be a very cool controller indeed.
/Stefan
nobody
PostPosted: Fri May 21, 2010 7:34 pm    Post subject: Re: Dream Synths
O.... M... F... G! Just based on the audio samples alone, I'm drooling over the Solaris. Unfortunately, it'll be a while before I have $4k. The deposit, I can come up with not too far down the road.
Thanks for the link, Gordon! Holy frigging WOW!
bachus
PostPosted: Sat May 22, 2010 5:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think my dream synth would be a sample player with 6 voice polyphony but able to weave each voice out of any number of samples with the equivalent of a Kyma-Pacarana behind each voice. And, of course loaded, with all my sample libraries
Audio files: 150
PostPosted: Sat May 22, 2010 6:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
my dream synth would be something like a Nord modular G2 with modules modelled on existing analogue circuits that were sonically indistinguishable from the real thing, with the ability to patch without needing a PC and enough DSP to switch sounds and patch without the horrible silence you get now
music | adventures in sound
Inventor
Audio files: 256
PostPosted: Sat May 22, 2010 10:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
While some of these dream synths require complex user interfaces or impossible ones with current technology, there does seem to be a commonality to some of them. Apparently polyphany and generally multiple outputs is a big deal, among other themes. I wonder if we should gather up ideas and consider building such a synth, as hardware or software... just a thought.
Les
Jack_Hertz
Audio files: 118
PostPosted: Sun May 23, 2010 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I want a wave table synthesizer that will do real-time re-sampling with assignable modulation at a harmonic level. There should also been an array of DSPs that I can configure to work as any combination of effects.
Web Site - Encyclotronica
DrJustice
PostPosted: Sun May 23, 2010 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like you want an Origin. I just ordered one... Smile
As for the dream synth, I spent a considerable time designing a stand alone digital modular which would be it.
DJ
nobody
PostPosted: Sun May 23, 2010 6:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would love to hear some samples when you get it.
Niio2
