demalignonm
Posted: Thu Jun 03, 2010 2:11 am Post subject:
Megaphone bend |
I am wondering what anyone may know about bending megaphones. Ever seen, heard, smelled, or maybe even bent one yourself?
I'm not talking about a toy megaphone. What I have is an actual megaphone and not a voice changer.
I just wanted to see if there was any point to doing it before I possibly wreck it. |
synthmonger
Posted: Fri Jun 04, 2010 4:40 pm Post subject:
I doubt there is much bending you can do it with. The only things I'd suggest is adding an external input so you can use it as an amp with a guitar or something. Maybe add a feedback loop? If you're looking for glitches and pitch bending, stick with toys or voice changers. _________________ Youtube!
modular demos!
Whacky tunes! |
Lorenzo
Joined: Nov 09, 2008 Posts: 338 Location: Trieste - Italyjstan
Posted: Fri Jun 11, 2010 12:41 pm Post subject:
| synthmonger wrote: | | I doubt there is much bending you can do it with. The only things I'd suggest is adding an external input so you can use it as an amp with a guitar or something. Maybe add a feedback loop? If you're looking for glitches and pitch bending, stick with toys or voice changers. |
I think so too!
..the external input is a usefool thing to do! ;D _________________ Oh Yeah!
Yes!
Wow! |
telstarmagikistferrari
Joined: Jun 16, 2008 Posts: 275 Location: Indianapolis, Indiana
Audio files: 43
Posted: Mon Jun 14, 2010 9:45 am Post subject:
| An external input would be pretty awesome if you're a guitar player or even want something to play bentstruments through! |
destroyifyer
Posted: Sun Aug 01, 2010 10:15 pm Post subject:
| You might as well wreck it. What good is an un-bent megaphone anyways. I think you could definately bend it... I recommend doing the audio 1/4" jack output first, and a switch for the megaphone speaker on/off though because you will just erode your hearing trying to bend that think without it. Maybe circuit bend a fire alarm and hook it up to the megaphone... and make it so it doesn't turn off... some psyops... you could, always circuit bend your town's tornado siren also. |
bennid
Joined: Feb 18, 2011 Posts: 2 Location: Villeurbanne, France
Posted: Fri Feb 18, 2011 2:40 am Post subject:
bending input places... |
How can I bend regular megaphone...
Where should I put my 6,35' jack input ?
Should I put it just where the microphone is plugged? how about the impedance if I want to use it with a boss DD7 pedal?
"Input Impedance
1 M ohm
Nominal Output Level
-20 dBu
Output Impedance
1 k ohm
Recommended Load Impedance
10 ohms or greater"
Can I still use the megaphone mic to go in the DD7 and then to the megaphone?
In case I put a little analog synth on the input, is it possible to create a switch to bypass it going back to the traditionnal mic?
Thanks a lot for your reply,
a newbie geek that will try anything, but not destroying 10 of them before getting something |
bennid
Posted: Thu Feb 24, 2011 2:46 am Post subject:
up Subject description: up |
any ideas?
thanks |
