destroyifyer
Posted: Thu Sep 11, 2008 7:21 pm Post subject:
Looking for a totally insane VST... Subject description: ...that will make my computer explode. |
I want a MONSTER vst that is insane, with tempo sync in mind. I have Moog Modular V along with basically every well known free VST on the internet, as well as a modular environment vst host ( I can hook them up all crazy like ect.)
So, please, help me out I'm looking for something that is beyond insane and is rediculous and will make my computer explode. I'm making this post, because I want to see if anyone knows what I'm looking for.
I want something INSANE that will make my computer turn into like a space robot that will enslave humanity. I mean, something that is seriously really cool. Prefferably something experimental and totally insane, and not an emulation. I'm sick of this "analog simulation" crap. This is the 21st cenutry and I want a space synth/vocoder that modulates its modulations with pico-HFO's and tempo syncs your brainwaves, while re-synthesizing its CPU fluctuating oscillator until it explodes. Any suggestions? Thank you. |
BobTheDog
Audio files: 32
Floppy
destroyifyer
Posted: Sun Sep 14, 2008 2:16 am Post subject:
| Thank you both. However, I'm not getting through to the "lucifer" vst. It seems to have fallen from devine-machine's product page. Thanks anyways though there are way too many VST's to make a sound choice. |
BobTheDog
Audio files: 32
Posted: Sun Sep 14, 2008 4:19 am Post subject:
How about reaktor 5 from Native Instruments.
Absolutely fantastic with some really weird stuff in the user library which contains hundreds of good instruments.
Demo also available on the NI site. |
sunny pedaal
Joined: Nov 16, 2004 Posts: 652 Location: netherlands
Audio files: 12
Posted: Fri Oct 17, 2008 1:27 pm Post subject:
| BIDULE, cheap and combining of all vst's possible |
XpanderXT
Joined: Oct 22, 2007 Posts: 133 Location: the flat universe
Posted: Mon Oct 20, 2008 7:55 am Post subject:
Reaktor - you can make your own exploding synths.
Tassman - very cool modular synth that weighs heavy on the Physical modeling side.
Tera - Virsyn's Tera is very modular and has all kinds of stuff. Use enough voices and your computer will explode or at least catch fire.
MAX/MSP - if you enjoy coding more than making music and want to do things that sonically only exist in the minds of mental patients. |
SONiVOX
realtrance
Posted: Fri Jul 24, 2009 6:43 pm Post subject:
| .. and for something a little more unusual and generative in nature, take a look at SYNPLANT. Truly an interesting little piece, the company I work at is actually using it for sound design. |
boony
Posted: Wed Jun 02, 2010 11:22 pm Post subject:
MASSIVE by NI instruments for sure. extremelly powerfull.
i use ut for everything.
ansd if you do liek to do a bit of cheating there is a shitload of presets which you can tweak and what not.
Another one you may like to check out is Albino 3. found this great for makeing real hevay bass's _________________ ausdjforums.com
KNOCKED UP NOISE |
loydb
Joined: Feb 04, 2010 Posts: 364 Location: Providence, RI
Posted: Thu Jun 03, 2010 9:46 am Post subject:
+1 Massive.
Though Reaktor is a lot of fun if you're into low-level sound mangling. |
destroyifyer
Posted: Mon Sep 06, 2010 1:38 pm Post subject:
| Thanks for the suggestions, I'll have to check some of those out sometime. A friend of mine is habitually upgrading his computer (he's even implemented liquid cooling) and I've been meaning to give some of the more CPU heavy programs a try on his system. In my opinion, even existing complex soft synths demand much more computing power than is available to the average musician- it's no fun having such a finite number of virtual patch cables that can be hooked up. Although, I should probably try something running at 4+ GHZ before I take too many stabs at the present level of affordable technology. |
DES
Audio files: 6
Posted: Mon Sep 06, 2010 6:55 pm Post subject:
I've been digging into z3ta by Cakewalk (former RGC audio synth) more and really having a ball with it. might be a worth a look-see-listen... _________________ Dave
www.davesneed.com
www.myspace.com/desneed |
trancekid
Posted: Sat Feb 19, 2011 11:57 am Post subject:
Ok you want cool synth. |
Why no one try Synapse audio Dune its the new hot soft synth out ther try demo and you see. |
Geir
Joined: Jan 27, 2013 Posts: 5 Location: Bergen, Norway
Geir
Geir
