Heterodyne Space Explorer
Page 2 of 3 [69 Posts]
adambee7
PostPosted: Mon May 24, 2010 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
STOP man. Take a break. Go for a beer and come back to it later with a fresh head. I've done this more than once and i've gone as far as throwing the f@:@ker against the wall. Very Happy Very Happy
-minus-
PostPosted: Mon May 24, 2010 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
ok...panic over. New breadboard. Seems to be working. Need to do some research into the resistor before the volume pot theory... ladies before gents... shovel before shit... The original way seems to have the one volume pot to rule them all thing going on.
I really don't know why I feel compelled to solder crap together. More trouble than what it's worth most of the time. No good for your nerves.
Oh look, if I want to chew up valuable informative forum space with this sort of rant, I should go and do it in the chat room! I'll post some results when I have something valid to say....
-minus-
PostPosted: Tue May 25, 2010 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
ouch! just tried the white noise generator section.... Q2 got really hot! This cannot be right! I am using BC 547 transistors. The only noise I hear is the obscene language coming from my mouth after I touch the smoldering transistor Exclamation
richardc64
Audio files: 25
PostPosted: Tue May 25, 2010 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you sure you didn't put it in with the same orientation as Q1, which is supposed to be "backwards"?
"It's quite OK to make music with tea spoons and rubber bands!" -- Blue Hell
-minus-
PostPosted: Tue May 25, 2010 8:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I thought that myself.... Tried it again but got same result. Thanks for your comment. No doubt I'll get back to this soon.... Just gone off on a huge 'research' tangent in terms of methods of controlling the oscillations. Wink
I shall report findings soon!
Top Top
PostPosted: Sun Jun 06, 2010 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Has anyone successfully gotten the white noise section of this circuit to work?
I tried bread-boarding just that (for another project), but didn't get anything from it.
I tried it with 2N3904 and 2N2222 transistors and same result - nothing. I tried tearing it all out and starting over, and still nothing.
sndbyte
PostPosted: Sun Jun 06, 2010 8:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I couldn't get the white noise to work. No sound at all.
adambee7
PostPosted: Sun Jun 06, 2010 8:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
try a different noise circuit? Very Happy Very Happy
Top Top
PostPosted: Sun Jun 06, 2010 10:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Strangely enough, on the breadboard right now...
I have another noise generator circuit...
WHICH ALSO WON'T WORK!
Laughing
Rykhaard
PostPosted: Mon Jun 07, 2010 4:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's another simple one, at the Experimentalist Anonymous's site:
http://experimentalistsanonymous.com/diy/Schematics/Oscillators%20LFOs%20and%20Signal%20Generators/Simple%20White%20Noise%20Generator%202.jpg
Top Top
PostPosted: Mon Jun 07, 2010 12:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Rich. I will give it a shot!
Fourth time's a charm! (?)
sndbyte
PostPosted: Wed Jun 09, 2010 4:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I finally put together the Heterodyne Space Explorer and boxed it up this weekend.
First I want to thank Beavis for posting this and his excellent tutorial. Also, thanks to electri-fire and Uncle Krunkus for their suggestion on how to deal with individual volume control (using a resistor and reversing the pot as electri-fire illustrated in his modified schematic).
I only made some minor changes to Beavis's schematic. First I left out the Sag pot. I then reversed the individual volume pots and added a 22k resistor before the wiper. This allows me to turn off individual oscillators without muting all of them. I also changed the values of the oscillator pots and used what I had on hand. For oscillator 1 & 2 I used a 1M pot with a 10k limiting resistor and a 104 capacitor. For oscillator 3 & 4 I used a 1M pot with a 10k limiting resistor and a 103 capacitor. I also added an Led to indicate when the power was on.
Here is a photo of it:
 Filesize:  91.81 KB
 Viewed:  126 Time(s)
Audio files: 51
PostPosted: Wed Jun 09, 2010 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good on ya sndbyte!
Looks great.
Give us some samples?
We would lose our friends.
So,.........
sndbyte
PostPosted: Fri Jun 11, 2010 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
When I originally started to breadboard this I wanted to modify it so that each oscillator could put out either a square or triangle wave.
I was able to get a triangle wave out of each 40106 inverter by adding a 100k resistor and 10 uf cap at the input of each inverter. (I got this idea from a schematic in Nicolas Collins Handmade Electronic Music, page 162). The triangle wave worked and I could select either the square or triangle output using a switch. I verified each on my oscilloscope.
But unfortunately when I attached the triangle wave output to the wiper of a volume pot, the triangle wave would stop working. I tried inserting a preamp using CD4049 between the triangle output and the volume pot but could never get it to work.
I eventually gave up and just stuck with the 4 square waves.
Anyhow, here is a photo with labels added (I just typed them over the picture in MS paint).
 Filesize:  112.62 KB
 Viewed:  138 Time(s)
Gordon Charlton
PostPosted: Thu Oct 07, 2010 2:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I am beat frequency.
sinister dexterity
megalodon
PostPosted: Wed Feb 16, 2011 7:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've built the space explorer with a WSG filter and I'm getting no sound out of it. Does this look right to you guys?
 Filesize:  104.5 KB
 Viewed:  345 Time(s)
-minus-
PostPosted: Wed Feb 16, 2011 11:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm just looking at the original diagram at the top of page one and comparing it to your diagram...
If you look at say pin 1 of your 40106, you have it going to a 1.5K resistor then to a 2.2uF capacitor going to GROUND. You are then taking that ground connection and running the green wire to your pot.
If you compare it to the original diagram you will see the difference. The 1.5K resistor goes from pin 1 to the pot. Pin one also goes through the capacitor and then to GROUND.
I would de-solder the resistor and put a link on your board where the cut is. Mount a 1.5K resistor upright at pin 1 and take the other leg to the green wire. Alternatively you could run the green pot wire to pin 1 and solder the 1.5K resistor to the pot leg and attach the green wire to the other leg. Same thing.
I think the reason you are getting no sound is that you are taking the pot wires from ground and not from pin 1, pin 3, pin 5 etc. You should be able to check each oscillator at pin 2, pin 4, pin 6, and pin 12 in your case.
I assume the other side of the battery is connected to ground?
megalodon
PostPosted: Thu Feb 17, 2011 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
That got it working! Thanks a lot, this thing is mental, I'll post some soundclips when I've boxed it up.
Mikmo
PostPosted: Thu Feb 17, 2011 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Could you please post a "corrected" perf board layout.
Thanks
Stay Cool
Mikael
http://www.mikmo.dk
megalodon
PostPosted: Thu Feb 17, 2011 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here you go, it's a bit messy, but it works. PDF, PNG and DIY Layout Creator files, in case you want to poke around and improve it, and some other bits that helped me out.
Heterodyne.rar
 Filename:  Heterodyne.rar
 Filesize:  4.21 MB
 Downloaded:  356 Time(s)
Mikmo
PostPosted: Fri Feb 18, 2011 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool.
Thanks
Stay Cool
Mikael
http://www.mikmo.dk
TheOutsider
PostPosted: Thu Mar 10, 2011 7:42 am    Post subject: Birth of a beast... Reply with quote  Mark this post and the followings unread
Hello all... I've been reading this thread for a few weeks now. I stumbled across it during my search for info about building a HSE or a WSG, and let me give a giant thank you to the contributors to this thread because without finding this, I would not have been able to build my own monster of a cross-breed drone box.
Details:
Neon yellow/green clear acrylic faceplate
4 X OSC
2 X LFO
Resonant filter (taken from WSG)
Panic button (taken from Cacophonator)
Voltage sag
Switchable capacitors for each OSC (for a bit of variety with OSC range)
LEDs for each OSC (no idea how I figured this out, probably from Beavis)
Let's see if I can manage to attach some photos and a link to a video of the monster on youtube...
http://www.youtube.com/watch?v=2dVXLBbwK4Q
For some info about who the Outsider is..
http://soundcloud.com/the_outsider
 Filesize:  1.96 MB
 Viewed:  179 Time(s)
sndbyte
PostPosted: Thu Mar 10, 2011 10:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice. The WSG filter is a great addition.
tjookum
Audio files: 26
PostPosted: Fri Mar 11, 2011 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice work! I like it a lot, good combination of circuits and nice enclosure.
Hunter S. Thompson
movies
noise
TheOutsider
PostPosted: Wed Mar 23, 2011 10:01 pm    Post subject: The latest creation... Reply with quote  Mark this post and the followings unread
Hello again.
I've built another monster. Hopefully I'll be able to make up my mind about an enclosure and get it finished completely before too long....
(I'll post pics when it's finally done)
http://www.youtube.com/watch?v=dNIbjbZS2g8
