  bingsatellites Mostly Ambient
 Forum index » Instruments and Equipment » Waldorf
Waldorf Blofeld Editor OSX available
Page 1 of 1 [4 Posts]
bouchemandela
PostPosted: Wed May 26, 2010 1:02 pm    Post subject: Waldorf Blofeld Editor OSX available Reply with quote  Mark this post and the followings unread
Hey all,
I've been working on a blofed editor built in MaxMsp on and off for about a week.
I still need to do a little work on the arpeggiator section, but everything else seems to be working fine. Below are links to both the editor file and some pics of the current revision, as well as a link to the Max 5 runtime which you will need to run the app. It only runs as a standalone as max5 has no ability to make plugins at the moment
Editor:
http://www.recordlabelrecords.org/Waldorf_Blofeld_Editor/
Pics:
http://imgur.com/3aNrK.png
http://imgur.com/6J9s9.png
Max 5 runtime:
http://cycling74.com/downloads/
*features include*
- get sound from synth, updates virtual editor with current sound buffer data
- Full control over all parameters including FX, Modifier, Modulation (Arp to be completed)
- onscreen feedback when parameters are changed on hardware
*To do*
- Finish Arp section and controls
- Devise a send patch with text input or possible librarian section
- implement some sort of monome arpeggiator controls
- implement Multi editing
*Setup*
- Under Global on the Blofeld, set ctrl send type as sysex/cc, ctrl receive to on, local control on
- In the Editor select the midi I/O and set input and output to appropriate blofeld channels.
- In the Editor hit get sound (bottom center), editor will update settings and away you go!
Let me know if you guys have any problems with this and I would be happy to help to the best of my abilities.
enjoy,
Carson
idealflaw
PostPosted: Sun Jun 06, 2010 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
this looks lovely but i can't get it to work.. it loads but doesn't talk to my waldorf..
waldorf is lacking in support of this wonderful machine. i wish there was more help out there..
the freakin' forum for it is straight out of 1978...
bouchemandela
PostPosted: Tue Jun 08, 2010 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Idealflaw,
Sorry you're having problems with the app, hopefully we can figure out whats going on with it. The current revision is beta_1_065. I incorrectly stated the blofeld control send type should be sysex/CC when infact it should just be sysex.
So Blofeld Global Settings are:
Device ID:0
Local Control: On
Control Send: Sysex
Control Receive: On
open the blofeld editor app:
set the midi I/O to the appropriate in and out to and from the blofeld
click or scroll 1-16 on the getsound numeric box to update the blofelds settings to the current sound 1 or current multi sounds 1-16
that should be it, hopefully this helps. if you're having more problems feel free to write back.
thanks,
Carson
idealflaw
PostPosted: Tue Jun 08, 2010 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
this worked and you are great!! Waldorf should pay you as they should have had this years ago....
outstanding work, man!
do you have a preferred patch management solution? I hate destroying patches in order to create new ones.
