Very high temperature
Page 1 of 1 [7 Posts]
X-Electric
PostPosted: Fri Jun 11, 2010 6:09 pm    Post subject: Very high temperature
Subject description: high temperature near the power adaptor inlet
Hello guys.
I've been using my Micro Modular for almost 7 years now, but this is the first time I've discovered that it gets really hot near the power input, and also a bit on the whole right part of the housing. I've been using this little baby "A LOT", and had never seen (or touched Wink ) anything like this.
Could anyone confirm if this is normal behavior, or is it just mine going coocoo ?
Thanks Smile
Audio files: 116
G2 patch files: 317
PostPosted: Fri Jun 11, 2010 8:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi X, long time no see :-)
How hot does it get, like pssst when you touch it with a wet finger? or more like the water from your hot water tap?
drapdap
PostPosted: Sat Jun 12, 2010 2:23 am    Post subject: Re: Very high temperature
long time i've seen a micro, (engine here) but stuff does this when the power supply capacitors are not ok anymore, (dried out, or gone slowly for other reasons...) than the voltage stabiliser is going nuts...
it does use the metal-housing to cool isn't it?
first you could measure the adapter if you're getting the right voltage...
i don't think its normal if you can cook on it...
r.
X-Electric
PostPosted: Sat Jun 12, 2010 5:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello again Smile
Blue Hell: Hey, it is not as hot as a hot stove, but when you try to touch it with the outside part of of your finger - it does hurt a bit...
drapdap: Yes, it does have a metal housing, but none of which is touching hot transistors...
I've made a picture, showing which part of it gets so hot. This is LM2940CS transistor. It is a voltage regulator from what i've found, but I've never payed attention to its temperature...
...could someone please tell me if it always was this hot ? Thanks Smile
PS. Sorry, but I don't have any thermocouple here...
 Filesize:  138.92 KB
 Viewed:  88 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Sat Jun 12, 2010 6:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Its pretty normal when (linear) voltage regulators go hot - probably when it gets too hot to its own likings it will shut down (a lot of linear regulators do that). So as long as it doesn't shut itself off on a hot day you'd be okay.
When it hurts the outside of your finger it would be 70 C or hotter, but as long as a wet finger on it doesn't make the water boil its cooler than 100 C, this is a normal range for such devices to operate in.
3phase
G2 patch files: 138
PostPosted: Mon Jun 14, 2010 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
as blue hell said its normal when they get hot..
if its hotter now than it used to be you really might check your power supply.. when its giving over voltage the regulator has to work more and therfore gets hotter
X-Electric
PostPosted: Mon Jun 14, 2010 11:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, thanks guys, I'm a little bit less worried now Smile, and I'll check the power supply of course, as it is not the original one.
