 Forum index » Clavia Nord Modular » Bugs
Envelope Generator in FX Area Legato Voice Mode Bug
varice
Audio files: 29
G2 patch files: 53
PostPosted: Sat Jun 19, 2010 3:26 pm    Post subject: Envelope Generator in FX Area Legato Voice Mode Bug Reply with quote  Mark this post and the followings unread
There appears to be a bug with the EG modules when placed in the FX area. The EG (with the KB gate button switched on) will ignore the Legato Voice Mode setting of the synth and will incorrectly retrigger on each new note just as if the synth is set to Mono Voice Mode.
Note: G2X running version 1.40 OS, 1.40 Editor on Windows XP.
The EG modules only work as expected with the voice mode settings when placed in the VA section of the patch.
You can force the EG module in the FX area to behave in legato fashion by adding a MonoKey module and connecting the gate signal, but then the EG will not retrigger properly when the synth is set to the Mono Voice Mode.
This patch demonstrates the bug. The voice mode by default is set to Legato. If you play the patch in legato fashion, the filter and amp EGs will incorrectly retrigger with each new note.
mono_monster_vm.pch2
 Filename:  mono_monster_vm.pch2
 Filesize:  7.8 KB
 Downloaded:  1402 Time(s)
varice
