GREENSKiN
Posted: Wed Jul 07, 2004 4:06 am Post subject:
Nord G2 PSU, 110 - 230V? |
Can anyone tell me if the Nord G2 keys uses a power supply suitable to both 110V (US) and 230V (Europe)?
Thanks!  |
Joined: Apr 01, 2004 Posts: 2478 Location: Auckland, New Zealand
G2 patch files: 575
Posted: Wed Jul 07, 2004 4:28 am Post subject:
No voltage selector switch on the outside and the carton has 'check boxes' for 240,230,110 etc. May be if you get inside and have a soldering iron handy. No good for Zurich<->NY commuters.
Have to ask someone who has had it apart to install expansion. |
GREENSKiN
Posted: Wed Jul 07, 2004 4:34 am Post subject:
Argh, that's just plain silly
It doesn't say something like 110-240V on the back? My Alesis Ion was 110-240V. Even cheap PSU's for PC's can switch between the voltages. Not good for touring. |
ikk
Joined: Mar 26, 2004 Posts: 8 Location: Tampere, Finland
Posted: Wed Jul 07, 2004 6:45 am Post subject:
| Mine says 230V on the back. |
Joined: Apr 03, 2004 Posts: 18435 Location: Netherlands, Enschede
Audio files: 107
G2 patch files: 314
Posted: Wed Jul 07, 2004 11:16 am Post subject:
It has a switch inside, that is my engines have it.
Apart from switching over you'll also have to change the fuse, it must have twice the amperage when set from 230 to 115 Volts.
Jan. |
GREENSKiN
Posted: Wed Jul 07, 2004 11:21 am Post subject:
Hoi Jan,
That's great news! Bedankt!
Now let's see if someone has a G2 keys who can check this too? |
Joined: Jan 31, 2003 Posts: 17196 Location: Allentown, PA
Audio files: 102
Posted: Wed Jul 07, 2004 6:19 pm Post subject:
Hsarkka and Greenskin. Glad to have you here. |
GREENSKiN
Posted: Thu Jul 08, 2004 3:18 pm Post subject:
Thank you Mosc, really looking forward to getting my G2 keys  |
GREENSKiN
Posted: Mon Jul 19, 2004 1:00 pm Post subject:
Tony Scharf posted some pictures of the G2 keys internals: http://www.chasingzero.com/nord.php
And yes, the G2 keys also has the 115-230 volt switch Blue Hell mentioned. Blue Hell/Jan, are you positive that only flicking the switch and changing the fuse is what it takes to go from 115to 230 volts, and vice versa?
You mentioned you need a fuse with twice the amperage when going from 230 volts to 115 volts, so that would mean you need halve the amperage of the fuse when you go from 115 volts to 230 volts. Makes sense
(edit: can't see the fuse on this pic though http://www.chasingzero.com/images/nord/Nord_Right_big.jpg)  |
Audio files: 107
G2 patch files: 314
Posted: Mon Jul 19, 2004 1:19 pm Post subject:
Well what can I say ...
I'm very sure and wouldn't hesitate a moment to do it to my own NM, but at the same time I probably wouldn't do it to a G2 belonging to anyone else. And most certainly I will not say that you'll have to do it.
In the end it's really up to you what to do, and in that you are alone.
Your conclusions about the fuse are correct.
As a precaution I would label the G2 after a voltage change has been made, and maybe fit it with a different power plug to avoid as many accidents as possible (not only your mistakes but others as well).
Jan. |
GREENSKiN
Posted: Mon Jul 19, 2004 1:23 pm Post subject:
Hi Jan,
That's fine enough for me, thank you very much! Now my only worry is to find the fuse on the pic (fuses look like little glass tubes with a thin wire going through it, right?).
Off to the US to get a G2X  |
Audio files: 107
G2 patch files: 314
GREENSKiN
Posted: Mon Jul 19, 2004 3:07 pm Post subject:
Excellent! Thanks!  |
The Why Project
Posted: Thu Dec 16, 2004 5:51 pm Post subject:
Just purchased an 'American' G2... and would like to 'switch' it to 230.
Anybody had any luck with the switch as described in this thread?
Regards,
The Why Project |
The Why Project
Posted: Fri Jan 21, 2005 10:52 am Post subject:
Hi all,
My G2 engine finally arrived today!
Just checking if anybody has had some luck switching
the voltage on their G2 with the switch/fuse option?
I'd like to go ahead and do it, but want to be sure!!!
Regards,
The Why Project |
pix
Posted: Mon Jan 24, 2005 9:59 pm Post subject:
Hey folks!
I'm having the same problem and I'm desperating here...
Is this really the way to do it?
Switch to 110V and get a fuse with twice the amperage?
I'd pay you a beer if you help me out!
pix
Posted: Mon Jan 24, 2005 10:02 pm Post subject:
| ...the fuse being 110V 250mA? |
Zebulon
Posted: Tue Jan 25, 2005 1:09 am Post subject:
You guys are beginning to make me worried since I live in Switzerland and purchase a G2 X to make shows with my band in the States
For my european gear, I often use a power supply transformator which my band mate has in New York. Can't such a thing make the job for the G2 ? |
Audio files: 102
Posted: Tue Jan 25, 2005 7:23 am Post subject:
I assume you haven't got a guarantee for someone because maybe no one has made the trip with their G2. I'd say you have the info. The thing to do if you aren't comfortable is contact the distributer, your music store, or Clavia.
If I was taking my G2 to Europe, I'd throw the switch and change the fuse. But I'm not going to pay for your G2 if you have a problem. You know, if you aren't careful, you can break a wire or something inside the instrument - although the G2 is very well built. _________________ --Howard
my music and other stuff |
pix
Posted: Tue Jan 25, 2005 10:52 am Post subject:
No, I´m actually confortable with doing it. My fear is that this is not the right procedure and I end up burning it for good. Specially because the unit was bought in an European store and I´m the US now. It´d be a pain if I had any problem.
I already opened the unit and toggled the switch. Removing the fuse is also nice and easy. the fuse says 220V 125mA. Does this seem right?
So in theory all I need is a 110V 250mA one, toggle the switch, and voila...right? ~=[
Another option is to get a 220V-110V transformer (about 35$ here) but if I could do it by switching the fuse it´d be a much cleaner option.
i also contacted clavia about a week ago but haven´t heard from them yet.
In the meanwhile here I am with no synth or controller keyboard...Glad live4 lets play with your computer keyboard other wise I´d be stuck with the mouse...!!!! |
pix
Posted: Tue Jan 25, 2005 10:59 am Post subject:
sorry for the newbiness guys but is it a fast blow or a slow blow fuse?
Audio files: 102
Posted: Tue Jan 25, 2005 11:54 am Post subject:
250 ma is correct for the US. 120 V or 220 V won't matter.
As for the fast blow or slow blow, I don't know. I don't feel like taking my G2 apart to look. Take the fuse that's in it down to where ever you're going to get the new fuse and have someone there take a look. Slow blow fuses look different and ususally say slow blow on them somewhere.
If you do a lot of travelling, the transformer may be more convenient in the long run. _________________ --Howard
Audio files: 102
Posted: Tue Jan 25, 2005 11:56 am Post subject:
If you do a lot of travelling, the transformer option may be more convenient in the long run. _________________ --Howard
pix
Posted: Thu Jan 27, 2005 6:44 pm Post subject:
2 more questions,
can I use a .315A fuse? That's the lowest they have at RadioShack.
And they also have 110V to 220V converters but the current stays at 60Hz....do you have any idea if the 220V G2 can handle 60Hz current?
Thanks! |
Audio files: 102
Posted: Thu Jan 27, 2005 8:43 pm Post subject:
The answer to that depends on your disposition.
The fuse that is rated 26% too high might not blow as fast as the correct fuse, but it will probably never blow. They blow when there is a short inside the equipment or somthing start drawing too much current. Something is already broken, in other words. There is equipment that is 30 years old with the original fuses. If you are conservative and cautious by nature, then don't exceed the rating. If you are more relaxed and you can handle the risk, go with the higher amp fuse.
I don't know what transformer you are looking at, but no matter. Some say "not for use with computers or electronic devices." It might be prudent not to use such devices. Will 60 Hz hurt the G2? I don't know for a fact, but I doubt it.
If it was my G2, I would switch the switch and swap the fuse. Who knows what's in those transformers. _________________ --Howard
