Analog switch matrix & digital noise
Page 1 of 1 [5 Posts]
Audio files: 129
PostPosted: Mon Jun 28, 2010 12:58 pm    Post subject: Analog switch matrix & digital noise
Subject description: panel sticker for 2 cgs pcb's
Hello, working on 2 CGS pcbs right now , both are needed in the middle of the modular so i squeezed them both onto my standard 100mm X 250mm size module.
sticker jpeg is showen in black , this will change to blue to match my other modules.
hope to have more pics over the next week or so .
 Filesize:  437.9 KB
 Viewed:  211 Time(s)
epicyclus@skrogmusic.plus.com
Audio files: 129
PostPosted: Sun Jul 11, 2010 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finished now Smile.
great digtal noise circuit , i included the timing caps mod for 3 rates slow medium & fast , i like this one Smile.
analog switch matrix is really good when the gate switches are hooked up a random gate module or a sequencer set for 4 steps on a slow clock rate , ideal for slow changing tones or c.v.'s .
here's a pic of the finished module.
 Filesize:  196.68 KB
 Viewed:  192 Time(s)
Adam-V
PostPosted: Mon Jul 12, 2010 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice one Dave.
Just out of interest, what value caps did you use for the rates?
Adam-V
Audio files: 129
PostPosted: Fri Jul 16, 2010 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Adam , i used a double pole switch, on (off) on, and have the 10nF for fast , 1uF poly for medium , 2.2uF poly for slow.
Adam-V
PostPosted: Mon Jul 19, 2010 9:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Dave.
Adam-V
