OSX Editor no longer opening
Page 1 of 2 [42 Posts]
foss
PostPosted: Wed Jan 26, 2005 3:16 am    Post subject:  OSX Editor no longer opening Reply with quote  Mark this post and the followings unread
Hi, I was wondering if anyone could help or has similar problems?
For some reason my nord editor [beta] for OSX has stopped working. It had been working fine but now when i open it i get a warning that reads- "Assertion Failed: MacGraphic.cpp, line 199"
I tried reinstalling my osx thinking it could have been an OS update to no avail and i tried reseting my clock to 2003 thinking it could be related to the new year with no avail. The editor refuses to open even without my Fastlane and Nord attached so it is definately a software not hardware failure.
If ANYONE! can help me with this i would be delighted. This is a real hinderance and my 7 year pc bit the dust so i am stuck ATM. I'll be raging if Clavia have built a lifespan into their software to try and force you to upgrade!
Help!
foss
PostPosted: Wed Jan 26, 2005 3:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I think we have a thread here somewhere discussing a similar situation where the OS X Editor app was not launching.
You shold try to find that one. .. It is here somewhere...
Uh..
I might want to kow which mac you are using, OS cersion .. and do you use the editor when logged in as admin or as a regular user with restricted access?
Reinstallation of the editor is probably just a matter of dragging the app from a mounted .dmg and into the /Applications folder
However, I would like you to try to drag a fresh app into your user home somewhere instead. YOu can drag it even onto your desktop. Then try to launch this app. It could be just a matter of privs.
Flickr
PostPosted: Wed Jan 26, 2005 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
It might also be a matter of which beta you are using, but then you should be getting a different message.. if the app is date capped. I recently grabbed a beta of the same app from a link posted here somewhere and that app worked at least last night.. Very Happy
You better be aware that Apple has been upgrading its display drivers bigtime recently and it might be a matter of incompatibility, bt personally I doubt that. What I think this is .. is simply that some of the package file s.. inside tyhe app.. have wrong priviledges. try moving a fresh app to your home folder and launch it from there. Trash the app you already have in your /Applications folder
Flickr
foss
PostPosted: Wed Jan 26, 2005 3:55 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for your replies but i'm still having trouble=/
I am on OSX version 10.3.3...i was 10.3.7 when it stopped working. I am now running a completely clean install of OSX and i have repaired and fixed permissions several times at every point of the install. I am operating as Administrator and have tried running the editor from my documents, applications and desktop to no avail. I have also re downloaded the editor from the Clavia site, trashed my old one and tried but no=/ looking for that thread with the alternate version now.
to my knowledge my other editor came from bittersweet sound.
do you have any other ideas?
PostPosted: Wed Jan 26, 2005 4:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm.. not really right now..
Using the Disk utilities app for permissions repair does of course only handle the Aplle set standard for how default permissions for the system and Appe software are supposed to be set.
Do a "get info" on the dead app and tell us what the permissions are?
You might want to let "everyone" have read/write privs for the package.
I am not in the studio right now, so I cannot check out this in detail myself.
Perhaps you could post the Beta version number here ?
Flickr
foss
PostPosted: Wed Jan 26, 2005 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
AHA!
i have fixed it. This is what the problem was for others that might have the same. I had followed out an article called "tracking the big cats" from electronic musician magazine so when i installed OSX i had done the minimum install to increase performance. This included using minimal Fonts.....this was the problem! I downloaded Aerial and Geneva from the Clavia site and now the editor boots as normal again and finds my nord=]
Thanks for your help elektro80. Much Appreciated=]
foss
PostPosted: Wed Jan 26, 2005 4:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Ahhh.. right... fonts!!!!!
I didn´t think of that at all. However, this is a "big problem" quite often.
Our accounting system network client written in Java dies when it does not have Helvetica, Times and Courier available. It is possible to embed font resources inside apps but .. they always forget..
Shocked
Flickr
foss
PostPosted: Wed Jan 26, 2005 4:19 am    Post subject: Reply with quote  Mark this post and the followings unread
yes..i've certainly learnt my lesson! glad that's sorted i'd been walking about with a fat bottom lip for 2 days=]
seraph
Editor
Editor
Audio files: 33
PostPosted: Wed Jan 26, 2005 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
foss wrote:
AHA!
i have fixed it.
WOW Very Happy congratulations, I would have never thought about fonts Idea
Audio files: 148
PostPosted: Wed Jan 26, 2005 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Why would Keyboard Magazine think taking the fonts off of your machine would give you better performance?
PostPosted: Wed Jan 26, 2005 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, removing the fonts will not speed up anything at all.
However, activating a gigabyte of postscripts fonts by putting them in the user/library/fonts is not something I would recommend either.
Flickr
seraph
Editor
Editor
Audio files: 33
PostPosted: Wed Jan 26, 2005 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
it was "Electronic Musician" not "Keyboard" Very Happy
le_tigre
PostPosted: Fri Jul 15, 2005 12:30 am    Post subject: Reply with quote  Mark this post and the followings unread
perhaps this could be made a sticky. it solved my problem, as well =)
yours,
niall.
Audio files: 148
PostPosted: Fri Jul 15, 2005 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome Le-Tigre
Thanks for the suggestion. Good idea. Done... welcome
3phase
G2 patch files: 141
PostPosted: Fri Jul 15, 2005 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
foss wrote:
AHA!
foss
All these os tweakings are really shit in the days of OS x... a clean install with all options is the safest and stablest... I heard to learn these lesson a few times allready... And still i do every update when it comes along... Sad
le_tigre
PostPosted: Sat Jul 16, 2005 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the neighbourly welcome, mosc. it looks like the G2 is where it's at these days - as usual, i'm behind the times, but i reckon that this recently acquired little marvel will be more than enough synth for me for a long, long time =)
yours,
niall.
seawolf
PostPosted: Mon Sep 12, 2005 9:48 pm    Post subject: similar problems and my fix Reply with quote  Mark this post and the followings unread
The beta is so buggy. I was having a problem where every time I right-clicked, a message referring to "MacGraphic.cpp" and "PortMenu.cpp" would pop up 4-6 times before and after the appearance of the right-click modules menu. I discovered that the problem went away once I went into the "synth" menu up-top, whilst editing a patch locally, and filling out the synth name field.
On a side note, I found this, but it looks like work has just started on the libraries it is based on, so an OS X port is probably out of question for the time being:
nordqt - Qt based open source editor for Clavia Nord Modular synthesizers
-elijah
Seawolf
http://www.teamabunai.org/seawolf/
ocp
Audio files: 9
PostPosted: Tue Oct 11, 2005 8:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Has anyone had any luck with the beta and Tiger?
https://opcabpol.bandcamp.com | https://www.mixcloud.com/Boiar | http://editoradoporto.blogspot.com |
seawolf
PostPosted: Wed Oct 12, 2005 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
yeh, beta & tiger has been working great for me. Just don't control-click on any part of a module that isn't a controller...
Its a damn shame that clavia decided to cancel the project. They could have made the G2 editor backwards compatible or something, don't you think?
Well, I'm glad that we have the beta at least.
Seawolf
ocp
Audio files: 9
PostPosted: Wed Oct 12, 2005 9:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
My beta doesn't open Rolling Eyes
I click it and nothing happens.
I'm using Tiger 10.4.2.
Any clues?
PostPosted: Thu Oct 13, 2005 12:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Did it come .sit compressed? If so has Stuffit Deluxe set the execution bit to on? Using the wrong version of stuffit or wrong setting will render applications dead and sinking.
Stuffit calls this "execute permissions".
Can you send me the exact URL to the application you downloaded. I can test this myself. Perhaps it is the fonts issue or something else.
Flickr
PostPosted: Thu Oct 13, 2005 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Fonts issues can do stuff like this on OSX???!!!
Isn't that a bit of a problem?
PostPosted: Thu Oct 13, 2005 4:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Well.. not at all. This is an application issue. This has to do with application programming and some very faulty thinking while designing the application. Shit happens. I had the same problem with a java app we are using at work. If the expected fonts weren ´t there the app would keel over and hit the ground. Ouch. Musta hurt.. Shocked
OS X allows for embedded fonts in apps and this is the route to follow.. or the available fonts can even be checked at launch and if they are missing they can be copied form inside the app package and into the user fonts folder in user/Library.
Flickr
PostPosted: Thu Oct 13, 2005 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, ok, that makes sense. So the Beta is like a guest that doesn't bring anything to the party yet starts demanding a rare whiskey, then leaves in anger when it isn't served?
It should be more like html which goes "I'd like to have this one but if that's not around anything monospaced will do, thanks" or better yet like my page which doesn't define a font at all, asuming the reader will set his favourite one as a default.
PostPosted: Thu Oct 13, 2005 5:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Yup! Laughing
Flickr
