CGS77 input bleed
Page 1 of 1 [3 Posts]
whomper
PostPosted: Fri Jul 23, 2010 12:05 pm    Post subject: CGS77 input bleed Reply with quote  Mark this post and the followings unread
Testing my newly built CGS77 serge filter provided two challenges to solve:
1. I get an input bleed to all outputs. It is present even at power off and is also present on the power rail (+, - and gnd).
2. The BP is very low in level compared to the LP and HP.
Am not using the on board buffers.
Any ideas?
Erez Yaary
Buy my CDs at http://www.mellowjet.de
andrewF
PostPosted: Fri Jul 23, 2010 9:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
These are just suggestions scratch :
outside of solder bridges and wiring errors
the bleed thru can be caused by a problem with your power supply, it can happen when the power supply is overworked.
also it could (possibly?) be caused by one or boh of the fets installed incorrectly.
whomper
PostPosted: Sat Jul 24, 2010 4:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Removed all trannys, wires etc just to find out I forgot to ground the panel to the board Embarassed .....
No issue, board is working great!
Erez Yaary
