LED check ?
Page 1 of 1 [4 Posts]
The_Unknown
PostPosted: Mon Jul 19, 2010 3:46 am    Post subject: LED check ?
Subject description: Do they work ?
I recognized that the LEDs next to the Process and Ribbon button do not light up if I press those ones. The display changes to the desired function so generally they work.
I do not remember if they ever lightet up, so when they have to do ? Is there a possibility to check LED functionality ?
Thanks.
kpatz
PostPosted: Tue Jul 20, 2010 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
The ribbon LED only lights when the ribbon is active (e.g. you're pressing on the ribbon, or you engage the ribbon hold and then press the ribbon).
I've never seen the process LED light up on mine. I wonder if it's used for anything at all.
The_Unknown
PostPosted: Tue Jul 20, 2010 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, the thing with the process LED I read from other users too in between.
The Ribbon LED still don´t light up on my A6 but it seems that some other users have the same "feature" sometimes while the Ribbon function still works...strange...
Alle other LEDs seems to work fine.
marctims
PostPosted: Sun Aug 01, 2010 9:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have you tried this?
press and hold soft button 2 power up the synthesizer, then you're in diagnostic mode.
When you press soft button 1(leds) under the display all leds will blink.
Niio2
