 Forum index » Instruments and Equipment » Waldorf
Waldorf Q
Page 1 of 1 [9 Posts]
Marhof45
PostPosted: Wed Aug 04, 2010 4:14 am    Post subject: Waldorf Q
Subject description: Using Phones
Hi all,
I have a Q and if I using phones, the left and right is reversed. I noticed this on an INIT sound and send the OSC1 completely to Filter 1 and panned Filter 1 hard left, but on my phones I heared the sound hard right. I also tested my phones on two mixers and panning is OK there.
Regards,
Mark
DrJustice
PostPosted: Wed Aug 04, 2010 5:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I just tested and it's the same with mine. The easy fix: turn the headphones around Razz
When the main L/R outputs are connected to a mixer, is the panning reversed then? It seems so, but mine isn't hooked up to a mixer at the moment, so I can't test properly. How about the sub outputs, are they reversed too?
BTW, I'm running the latest OS, v 3.02.
DJ
Marhof45
PostPosted: Wed Aug 04, 2010 6:14 am    Post subject: Q Panning Reply with quote  Mark this post and the followings unread
Hi DJ,
Hahaha, yes, turn the phones!!!! I'm running 3.02 also. I'm not at home tonight, but I will test it tomorrow and hook the Q to my mixer. I will test both sub out's too and let you know the results. But it is strange, isn't it?
Regards,
Mark
DrJustice
PostPosted: Wed Aug 04, 2010 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, it's a bit strange. A quick google search didn't bring up any mentions of it, except for this thread. I must admit that I usually do pan positioning in the mixer, while on the synths there may be pan modulation - thus, I probably wouldn't discover a reversal of the left/right channels unless specifically testing for it...
It'll be interesting to see the result of your testing.
DJ
Marhof45
PostPosted: Fri Aug 06, 2010 1:29 am    Post subject: Waldorf Q
Subject description: Panning
Hoi DJ,
Last night I hooked the Q on my mixer, and guess, same problem, left and right are reversed. So The best thing you can do is switch your cables.
Regards,
Mark
HrastProgrammer
Audio files: 34
PostPosted: Fri Aug 06, 2010 11:02 am    Post subject: Re: Waldorf Q
Yes, this is the old problem present on Waldorf Q since its release. There is a small chance it will boot with the correct panning sometimes, but I really cannot remember when this happened for the last time (and I have a few Q synthesizers since 2000). There is no cure for this, no OS update etc. Just have your L/R cables reversed and that's it ...
http://www.hrastprogrammer.com/hrastwerk/
http://hrastprogrammer.bandcamp.com/
Marhof45
PostPosted: Fri Aug 06, 2010 1:19 pm    Post subject: Q
Thanks for the info Hrast. I never noticed this problem! But it's just a software problem and no hardware problem?
Mark
HrastProgrammer
Audio files: 34
PostPosted: Fri Aug 06, 2010 9:34 pm    Post subject: Re: Q
Hi Mark,
I think it is a combination of software and hardware. There was discussion about it on Waldorf mailing list, long time ago ...
As far as I know, both yellow and blue Q can be affected by this problem, at least some of the units, and at least all my yellow and blue racks are affected ... And if I remember correctly, my XT has reversed L/R outputs, as well. It's just a part of "Waldorf tradition", I am affraid ...
DrJustice
PostPosted: Sat Aug 07, 2010 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
At a guess i'd say it's a software problem. I once found a similar bug in another box, and it was just the startup code for the CODEC (it's driving routine/DMA) that was sloppy (not waiting for sync) resulting in a left/right channel swap on most startups. Same DSP, same'ish CODECs, same hook up.
Oh well, I can live with it. Although seeing as the Q is still in production, it's such a silly bug that I'd fix at once if it was up to me...
DJ
AmbiphonicDSP
