  bingsatellites Mostly Ambient
Send MIDI signal to switch bypass on/off??
Page 1 of 1 [5 Posts]
clivemist
PostPosted: Sun Aug 08, 2010 8:49 pm    Post subject: Send MIDI signal to switch bypass on/off??
Subject description: MIDI Signals and analogue
Hi, I'll just dive straight in with what I am trying to achieve..
I wish to receive signal from a MIDI source (eg My soundcard/sequencer/keyboard) and send it to my synth.
I have figured out how to change pitch, but I was wandering how to route analogue to digital switching via MIDI?
I am building a synth with built in effects and wish to control on off/bypass functions via MIDI with out having to buy a pre constructed midi converter.
I have found this schematic:
http://www.emusic-diy.org/Schematics/Misc/MidiCv?action=AttachFile&do=get&target=MIDITOCV.GIF
But am unsure as how to use this to effect the circuit in the desired way.
For example:
I have two oscilators.
These will be controlled via the CV/gate resistance(?)
BUT I also have 14 switches I wish to change via raw MIDI signal, so that I may switch a reverb on/off, or switch a distortion on/off in the same circuit.
I understand I could use a PIC and stamps to do this, but do not understand how to interface the midi signal in to the circuit to create the above result.
Any help would be greatly appreciated!
Thanks in advance!
clivemist
PostPosted: Sun Aug 08, 2010 11:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have found this in my travels?
http://www.musicfromouterspace.com/analogsynth/midi2cv.htm
and this:
http://www.musicfromouterspace.com/analogsynth/gate_trig_mod.gif
Which is confusing me a little, would this mean I would only have one gate/CV per connection or could I duplicate the above system from the same output so that multiple triggers could be achieved??
Would that mean that I could receive MIDI signals via CC on the device? eg if I wished to control multiple I/O connections (for example, buttons that can be pressed for an action, or to switch a transistor in "Manual" mode, but then when operated by MIDI this is taken over by the function digitally?)
Please forgive my ignorance, I have only just started discovering what IC's etc can offer.
EdisonRex
Audio files: 168
PostPosted: Sun Aug 15, 2010 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi there and welcome to electro-music.com! welcome
Do the functions on the midi-enabled synth you are sending to appear as registered or unregistered parameters, or can you map a CC (continuous controller) event to it? I don't see why you need a midi to CV converter if you aren't using control voltages.
Garret: It's so retro.
clivemist
PostPosted: Mon Aug 16, 2010 1:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Little confused..
There is no MIDI onboard, but that is what I wish to implement, IE so that when I trigger something in MIDI it closes the gate on that specific transistor?
eg. button 12, close gate on EQ, etc?
I dont know if that helps?
EdisonRex
Audio files: 168
PostPosted: Tue Aug 17, 2010 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, I see. You're wanting to implement either continuous control or some kind of mappable parameters via MIDI to control CVs. For some reason I was thinking the opposite.
I have a Kenton Pro-2000 Midi to CV convertor that I use for this sort of thing. It has 6 "auxiliary" CV outputs which you can map to any continuous controller, or a parameter. This can be made to work just fine.
There are other MIDI to CV convertors you could do, but you're on the right track, map a CC event to some kind of auxiliary CV out and you're laughing.
JuneSolstice2013
