 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
Can't even get a connection now!
treehugger
PostPosted: Wed Aug 11, 2010 2:36 pm    Post subject: Can't even get a connection now!
Subject description: MIDI communication OS X 10.5.x
Hi all
I've just installed the Mandolane 4.0. I've got what I believe is the latest Nomad for OS X, and I can't even get to square 1. I have two MIDI Time pieces. I get the following stream of errors
net.sf.nmedit.jsynth.SynthException: Invalid plug MidiPlug[name=Port 15 <MIn>,vendor=MOTU,description=Midi IN port:16] for net.sf.nmedit.jsynth.midi.MidiPort[name='pc-out',type=TRANSMITTER,plug=null].
at net.sf.nmedit.jsynth.midi.MidiPort.setPlug(MidiPort.java:110)
at net.sf.nmedit.jsynth.nomad.forms.SynthPropertiesDialog$PortSettingsDialog.applyPortSettings(SynthPropertiesDialog.java:248)
at net.sf.nmedit.jsynth.nomad.forms.SynthPropertiesDialog$PortSettingsDialog$MyAction.run(SynthPropertiesDialog.java:223)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:180)
at java.awt.Dialog$1.run(Dialog.java:535)
at java.awt.Dialog$2.run(Dialog.java:565)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Dialog.show(Dialog.java:563)
at java.awt.Component.show(Component.java:1302)
at java.awt.Component.setVisible(Component.java:1255)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.showSettings(SynthObjectForm.java:1257)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$2.actionPerformed(SynthObjectForm.java:609)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1882)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2202)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:420)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:258)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
at java.awt.Component.processMouseEvent(Component.java:5602)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3135)
at java.awt.Component.processEvent(Component.java:5367)
at java.awt.Container.processEvent(Container.java:2010)
at java.awt.Component.dispatchEventImpl(Component.java:4068)
at java.awt.Container.dispatchEventImpl(Container.java:2068)
at java.awt.Component.dispatchEvent(Component.java:3903)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4256)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3936)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3866)
at java.awt.Container.dispatchEventImpl(Container.java:2054)
at java.awt.Window.dispatchEventImpl(Window.java:1801)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
can anyone offer some assistance
Niio1
