Super Psycho LFO sync....
Page 1 of 1 [2 Posts]
ricoloverde
PostPosted: Wed Aug 18, 2010 10:06 pm    Post subject: Super Psycho LFO sync.... Reply with quote  Mark this post and the followings unread
Hi just finished a SuperPsycho Lfo and was wondering if there is anyway to add some type of sync signal to it. Not really sure if its possible, thought itd be great to send a gate or trigger to it and have the LFOs fire in a rhythmic fashion...I know it uses a schmitt trigger and thought it might be possible.
thanks
rico
andrewF
PostPosted: Thu Aug 19, 2010 4:07 am    Post subject: Reply with quote  Mark this post and the followings unread
this question gets asked every now & then.
I am not sure if anybody has developed a solution but two spring to mind.
use a 4066 or 4016 to break the connection between the inverter inputs and the 22n caps. remember the 40106 is powered between 0V and -15V, so same for the 4066. This way you can sync 4 of the 6 oscillators.
another possibility, I saw this on a chaos circuit recently.
add 100 ohm resistor between ground and the power pin (14). From pin 7 break the connection to -15V and put in a transistor subcircuit that closes when a trigger arrives. This will turn off the chip briefly and result in a syncing, of sorts.
These are untested ideas i am throwing out thanks to a few glasses of Bellarmine Riesling....have a few spare chips handy Very Happy
