G2 and low level DSP
Page 1 of 1 [9 Posts]
ik
G2 patch files: 25
PostPosted: Sun Jan 30, 2005 7:25 am    Post subject: G2 and low level DSP Reply with quote  Mark this post and the followings unread
Hi!
My name is Istvan Kaldor, .... I am a 'silent reader' of this forum for a while ....
See attached file ...
This is an experiment of porting a 12 db resonant LPF from SynC Modular.
Seems to work, I didn't know if it is possible to build your own filters for the G2 by low level DSP, ... really cool .....
(note: Sorry, I don't know how does the filter works, I just ported. Smile)
ik.
2pol LP 12db.pch2
12db resonant LPF ported from Sync Modular.
 Filename:  2pol LP 12db.pch2
 Filesize:  1.31 KB
 Downloaded:  1137 Time(s)
Audio files: 213
PostPosted: Sun Jan 30, 2005 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome ik. Glad you decided to climb out of the woodwork...
This is really cool. Not only does this filter sound great, but you made it pretty much out of multipliers and mixer module. Can you explain how this works? Did you start with a formula or something?
ik
G2 patch files: 25
PostPosted: Sun Jan 30, 2005 11:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is the original SynC Modular "source code" Very Happy .
See image attached.
I am not a DSP guru but one could relay back from the image to the original C++ code. (I'll check the archive, it is probably not too difficult to figure out.)
This is really neat since it looks like one could build any (??) desired filters, OSCs ... (??) from the original C++ codes in the G2.
ik.
Original SynC Modular 2pol LPF image.
 Filesize:  26.2 KB
 Viewed:  8121 Time(s)
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sun Jan 30, 2005 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is brilliant. The Z-1 (1 sample delay) modules are not required because of the 1 sample feedback delay in the mixers.
A ShpStatic (4th shape) on the Frequency input exponentialises the response quite well.
Must dig out my sync-c Stilson filter.
ik
G2 patch files: 25
PostPosted: Sun Jan 30, 2005 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Z-1 (1 sample delay) modules are not required ...
First, I tried to stick delays into the feedback loops, then I found out
no need for those. I wondered why... Very Happy
So, The G2 mixers could be used as Z-1 modules? ... A .... ha.
BTW. SynC Modular has more then enough material (filters, OSCs .... ) to port. ... Smile
ik.
cebec
G2 patch files: 31
PostPosted: Sun Jan 30, 2005 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
An entire project unto itself! What an amazing revelation, here...
I hope this takes off as I'm eager to learn these very principles.
Roland Kuit
G2 patch files: 127
PostPosted: Sun Jan 30, 2005 2:26 pm    Post subject: G2 and low level DSP Reply with quote  Mark this post and the followings unread
Idea
Nice work iK
ik
G2 patch files: 25
PostPosted: Sun Jan 30, 2005 5:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry Sad , ... the previous file had the wrong output.
Here is the corrected one. LP/BP/HP outputs added.
ik.
2pol filter from SynC Modular.pch2
12db LP/BP/HP filter, ported from SynC Modular.
 Filename:  2pol filter from SynC Modular.pch2
 Filesize:  1.44 KB
 Downloaded:  1249 Time(s)
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Sun Jan 30, 2005 10:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
hello Very Happy this is a neat experiment. I'm glad you are not lurking (silent reading), I for one appreciate your insight.
