  bingsatellites Mostly Ambient
 Forum index » electro-music.com » electro-music 2010
Request for your advice
Page 1 of 1 [16 Posts]
I would prefer to hear
Surround-sound theremin set with old material
0%
 0%  [ 0 ]
Improvised synthesizer set
50%
 50%  [ 4 ]
Equally interested in either
37%
 37%  [ 3 ]
Equally dis-interested in either
0%
 0%  [ 0 ]
Other (see comments)
12%
 12%  [ 1 ]
Total Votes : 8
Audio files: 27
PostPosted: Tue Aug 31, 2010 8:43 am    Post subject: Request for your advice Reply with quote  Mark this post and the followings unread
Hello to all.
Well, Murphy's Law has struck, it seems. I wanted to introduce a new work in my theremin set however my schedule has been pummelled with unexpected work. This morning I arrived at the office -- my message light was "on" -- and I have lost ALL of my evenings this week to work. This means little rehearsal time and no chance of completing the composition I've started.
So, I am faced with a dilemma. I can play a theremin set similar to what I've played in the past drawing on old repertoire and would be done in surround-sound.
Or, I can do an improvised (non-theremin) set on the Aries synthesizer -- which will be similar to what I've done on some of the streaming broadcasts. This would be in stereo, though -- I haven't yet been able to implement surround sound for Aries improvs.
Either way -- I'm kind of a nervous wreck -- wanting to do a quality set and not sure what to do.
The theremin sets have been well-received however I fear people will tire of hearing the same material again.
Thank you for taking a moment to respond to the poll -- your response will contribute to a quality result for my set on Friday.
Audio files: 116
G2 patch files: 317
PostPosted: Tue Aug 31, 2010 8:58 am    Post subject: Re: Request for your advice Reply with quote  Mark this post and the followings unread
The aries sets you did on the radio here were most excellent too! So please don't let lack of confidence slip in there, whatever you may decide.
Audio files: 27
PostPosted: Tue Aug 31, 2010 9:55 am    Post subject: Re: Request for your advice Reply with quote  Mark this post and the followings unread
Thank you.
This year, I will admit, I've been more focused on DIY module-building and not as much on composition.
One of the tough issues with electronic music is that one must wear many hats: hardware, software, composition, performing, etc. Often times the technical issues come to the fore and it is difficult (at least for me) to switch gears back to "musician" mode.
laura woodswalker
Audio files: 10
PostPosted: Tue Aug 31, 2010 2:27 pm    Post subject: Re: Request for your advice Reply with quote  Mark this post and the followings unread
Hi Kevin!
Yeah, I like your message, I totally agree with you...there is so much to learn, do and create... I'm getting ready for my first set, and it's been crazy.... there are loops to set up, patches to modify, riffs to compose, and halfway thru I switched synths & had to learn a whole different piece of equipment!!!
I sympathize about not having nearly enough time! But you're so good that whatever you do, I"m sure it will sound great!
The most important music equipment is what's in front of the instrument.
Danno Gee Ray
PostPosted: Tue Aug 31, 2010 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Kevin,
Anything you are able to share with us, perform for us will be, for me at least, greatly appreciated. I just dig hearing you play.
Frankly, if you turned a coffee can over and banged it with a chicken bone, it'd probably start a new craze. You could throw gravel at street signs and make sound magically musical.
Relax and enjoy the weekend. Whenever you play, whatever you play...We do!
Dan
EdisonRex
Audio files: 168
PostPosted: Wed Sep 01, 2010 12:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Kevin, I think whatever you're comfortable with, you should do. I could listen to your Theremin performances again and again. I am quite sure many people would agree.
Garret: It's so retro.
Audio files: 150
PostPosted: Wed Sep 01, 2010 4:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd love to hear an improv on the Aries Smile
music | adventures in sound
nobody
PostPosted: Wed Sep 01, 2010 7:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I enjoy your work and am FAR from tired of it! Play on, my friend!
DES
Audio files: 6
PostPosted: Wed Sep 01, 2010 11:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Not sure if I'll be able to make it again due to commitments, work and such....but what about doing some on both? Can your run the therimin into the Aries (or does it have midi out to control the Aries?)
www.davesneed.com
www.myspace.com/desneed
nobody
PostPosted: Wed Sep 01, 2010 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Even if it doesn't, he can always use a CV converter.
Audio files: 27
PostPosted: Wed Sep 01, 2010 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually, there are two ways to interface a theremin into the Aries...
1) the Aries' pitch-to-voltage converter
2) from the theremin's CV out.
Few theremins have MIDI output, though.
With limited set up time, I am inclined to do either a theremin set or a synth set. One of my future projects will be to build a self-contained theremin/synthesizer -- something that is pre-patched -- in order to do synthesizer/theremin sounds. I appreciate the suggestion -- might try it out in the studio. The technique has definite potential.
At this point, I'm considering a synthesizer set because, due to the size of the Aries synth, I am not sure if I'll bring it with me next year. It contains many modules that you've read about on the forums here (the Mega Percussive Synthesizer, the Klee Sequencer, and a number of other DIY modules from Yusynth, CGS, and MFOS).
Acoustic Interloper
Audio files: 26
PostPosted: Wed Sep 01, 2010 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I second this. As much as I love the Theremin+surround -- last year I spent your set lying on the floor on my back swimming in the sound -- improv is near and dear to my heart.
You did great as band director of the Pocono Electronic Jug Band Ensemble. Time for more new strangeness, I think Exclamation
"Time is a ruler across the knuckles of eternity."
Dale Parson
"Just say no."
Nancy Reagan
DES
Audio files: 6
PostPosted: Wed Sep 01, 2010 8:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was thining of the Moog theremin - Etherwave I believe. I know there are a few others out there... I was also thinking just process it's audio in the Aries - as a modulator or ??? In any case I hope I can get there...not looking too good though.. Sad
www.davesneed.com
Tantroniq
PostPosted: Sat Sep 04, 2010 6:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I dont think there is such a thing as tiring from too much quality theremin performance. I've never heard you! Look forward to it.
-T
"Be still Taggart, be still! My mind is aglow with whirling transient nodes of thought careening through a cosmic vapor of invention!"
nobody
PostPosted: Sat Sep 04, 2010 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
++! Cool
JEM
PostPosted: Sun Sep 05, 2010 1:00 pm    Post subject: Live Improv
Subject description: Aries Modular
Kevin, most of the modular performances I've seen were done in conjunction with sequencers and/or pre-recorded reel-to-reel tapes.
If you could do an improv that demonstrates the live, real-time performance capabilities of the Aries modular, it would be both enjoyable and informative.
JEM
Niio1
