Living VCOs
Page 17 of 21 [520 Posts]
Goto page: Previous 1, 2, 3, ..., 15, 16, 17, 18, 19, 20, 21 Next
Would you prefer one PCB with 3 VCOs a la JH-5A, or 1 VCO per PCB with more features
One PCB with Oscillator Driver and 3 VCO cores (like JH-5A - cheap!)
60%
 60%  [ 62 ]
1 PCB = 1 VCO (with many waveforms and inputs)
39%
 39%  [ 41 ]
Total Votes : 103
The Bad Producer
PostPosted: Sat Sep 04, 2010 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks! Yes I do, but as it is not my circuit, as it were, not sure about the ethics of posting such a thing...?
It needs a bit of work to make it into a PDF though, so maybe I'll do that and in the meantime make an enquiry to the relevant peeps as to whether I can post it here...
charlie
EDIT - Doug says that is cool, so I'll post it up, tomorrow hopefully...
JoeMorris
PostPosted: Sun Sep 05, 2010 4:22 am    Post subject: Reply with quote  Mark this post and the followings unread
nice one. id like to add those capabilities to my living vcos
LetterBeacon
PostPosted: Sun Sep 05, 2010 4:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Great news!
The Bad Producer
PostPosted: Sun Sep 05, 2010 4:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Might be Monday now, I left my hard drive at work! Embarassed
LetterBeacon
PostPosted: Sun Sep 05, 2010 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
The Bad Producer wrote:
Whereabouts did you get the frequency knobs and the linear detune knobs from? They look great!
The Bad Producer
PostPosted: Sun Sep 05, 2010 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
The linear detune knobs are Davies 1910CS :
http://www.alliedelec.com/search/productdetail.aspx?SKU=5431916
The frequency knobs are Davies 1610AA:
http://www.alliedelec.com/search/productdetail.aspx?SKU=5431610
Both available from Allied Electronics, they do lots of other nice knobs too!
Close up:
Luka
PostPosted: Sun Sep 05, 2010 6:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
that is where i get mine from also
shipping is killer to australia though
problemchild
melbourne australia
The Bad Producer
PostPosted: Mon Sep 06, 2010 5:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay, got my hard drive and the files.
I've attached the stripboard layout for Electronic Peasants Waveshaper, also on the PDF is a stripboard layout for the pulse amplifier, copied from JH's schematic for the saw output. I have not included decoupling caps, I just used a couple of 10uF electro's and a couple of 100NF on the power rails.
Please double check everything, I have built quite a few of these, but there may still be errors. Also, I used multiturn in-line trimpots, it gets a bit tight with these - I wanted the layout to be as small as possible - so double check that the ones you have will fit.
Another thing I noticed when I tested the first one, if you haven't got all the trimmers (esp the saw offset) set correctly there will be no output, I went through prodding with the oscilloscope as I went to calibrate it, but it does work and works very well too!
Charlie
PS I hope you don't mind the graphic 'style' it seems clear to me!
PPS The schematic is from Electronic Peasants post on page 12 of this thread...
Living VCO Waveshaper Stripboard.pdf
Living VCO add-on
 Filename:  Living VCO Waveshaper Stripboard.pdf
 Filesize:  103.21 KB
 Downloaded:  897 Time(s)
LetterBeacon
PostPosted: Mon Sep 06, 2010 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
That's perfect - thank you very much!
Luka
PostPosted: Tue Sep 07, 2010 1:17 am    Post subject: Reply with quote  Mark this post and the followings unread
that is the best stipboard layout ever charlie
problemchild
melbourne australia
The Bad Producer
PostPosted: Tue Sep 14, 2010 5:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Made a track using just Living VCO's (and some envelopes etc - no filters though)
here:
http://soundcloud.com/thebadproducer/stranglehold
I quite like the hissing and bass etc...
(its not a bad recording that is the VCO's too... VHF I guess... I like)
jhaible
PostPosted: Tue Sep 14, 2010 11:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
here:
The noises fit beautifully into the musical context, but for general use you should get rid of them, I guess. Do you have bypass caps on the opamps of your waveshaper board?
JH.
The Bad Producer
PostPosted: Wed Sep 15, 2010 3:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I have bypass caps on the waveshapers (they're not on the stripboard layout though).
It is quite interesting the noise - I have no idea where it comes from, maybe you would understand this more?
Basically they only occur when I set the frequency 10 turn pot all the way up as far as it will go and then use CV to send the frequency higher with a gate or trigger, if the frequency knob is even slightly away from fully CW it does not happen - I always thought it was some kind of glitch with the wirewound 10 turn pots?
But as I said, it never occurs in normal operation, they are clean as you like!
I quite like it though, I stumbled across it when I tried processing a friends guitar through the FM input and seeing what happened... It also reminds me a bit of Pole, who - legend has it - dropped his filter unit and when he turned it on again created all those pops and clicks which defined his oeuvre... So maybe it isn't supposed to do that!
I repaired a friends Plan B Elf LFO recently and that also goes VHF a bit like this, but not so 'musically' Very Happy
jumunius
PostPosted: Wed Sep 15, 2010 9:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I must say I am relieved that you clarified this. I knew the Living VCOs were supposed to be "imperfect" in terms of tracking, but I expected better signal to noise ratio than your track implied. As a proud owner of two empty boards, I'm glad to hear that even if it is normal behavior, it's only occurring at an abnormal setting.
Other than that I quite enjoyed your glitchy noise bursts.
The Bad Producer
PostPosted: Thu Sep 16, 2010 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, Just to clarify, they sound amazingly clean, track well etc, in fact the ideal oscillators! There is no 'noise' in normal useage at all... eg the sub-bass is from the same Living VCO unit playing at the same time, no noise there!
I just found this odd 'function' (well odd and new to me!) which as I said, seems to be a glitch with the pots I'm using and using the osc (with FM) at extreme high frequencies (at least that is how it looks to me!)
defex
PostPosted: Thu Sep 16, 2010 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Just a quick question. I am not using the linear detune input on the second oscillator, can the input be left floating? or should i put a jumper on that connector to ground?
In this version I have a mix control/amplifier between saw/pulse of each section, and the individual outs are normalled to the FM inputs in a 1-2 2-3 3-1 fashion.
so far each osc has been tested and working, i am just finishing up the mixer/amplifier part and the lots and lots of wiring!
jhaible
PostPosted: Thu Sep 16, 2010 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
You can leave that open.
JH.
defex
PostPosted: Fri Sep 17, 2010 12:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for the quick reply!
defex
PostPosted: Mon Sep 20, 2010 7:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Although not as ambitious as the waveshaper, I have replaced the saw/pulse switches with 50k pots, and it is well worth it, you can fade between saw and pulse for each oscillator.
(it has screwed up the text of my lovely FPE panel, but worth it for the extra feature)
just connect each end of the pot to where it says "pulse" and "saw" on wiring option 3, and the wiper to the common side of the switch.
this will probably only work if you are using wiring option 3 because you would end up with a high impedance output if the pot was not in front of the "amp" sections.
If using BL conductive plastic pots, they do not go all the way down to 0 ohms (the ones i tried anyways) so you get a little tiny bit of pulse left on the saw even when it is cranked all the way over to "saw", with carbon pots it did not happen.
defex
PostPosted: Fri Sep 24, 2010 7:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yet another question. Rolling Eyes
I have decided to cut or switch the connection between the LFO to the CV out of the main pitch CV section (r142), and use it for a PWM LFO instead (with a separate buffer like the U11b Drvout one) but i want to slow down the LFO , I am guessing i can just increase the value of c31 to accomplish that, is that correct?
jhaible
PostPosted: Sat Sep 25, 2010 2:33 am    Post subject: Reply with quote  Mark this post and the followings unread
It's fairly trivial to build an LFO that covers a wide frequency range - but *this* war especially tailored to have a small frequency range, dedicated to typical Vibrato applications.
You can always make an LFO slower by increasing the integration cap, or integration resistor. But that won't defeat the (intentional) range limitation - you'd just scale the whole range down.
So if you want to (ab)use that generator as a general purpose wide-range LFO, 1st thing is vastly increasing R151. Try 10Meg here, and only if it's still too fast for your taste, increase C31.
JH.
kjackman
PostPosted: Sun Oct 10, 2010 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
A bit of a newbie here, so bear with me...
CA3046 is increasingly hard to find these days, and I'm guessing it's just going to get harder as time goes on. Would a precisely matched pair of general-purpose NPN transistors, connected as a differential pair, in thermal contact, work just as well? For example, two 2N3904s Vbe-matched to within 1mV, with thermal compound between them and tied together with a cable tie? I'd have to thermally connect them to the Tempco as well, of course...
Also, what does connecting pin 13 of U2 (the "substrate") do? Schematically, this is just the emitter of Q5, which is not used in your circuit.
I know I can get 3046's from Bridechamber for $1 (today, yes; tomorrow? Who knows!). I Just want to make sure we can continue to build and maintain these VCOs long after the apocalypse, when the zombies hoard the last of our precious analog ICs.
jhaible
PostPosted: Sun Oct 10, 2010 8:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I haven't tried it, but a pair of discrete transistors should work. No idea if a cable tie is good enough for thermal connection - I'd use something thermally conduction, like copper wire, instead. Try and find out for yourself, if it's good enough for you. VCO will work with about any decent transistor pair - drift and tuning stability will vary.
Don't expect the LV to work after the apocalypse, though, 3046 or not. Smile
JH.
MR-808
PostPosted: Mon Oct 25, 2010 1:36 am    Post subject: Reply with quote  Mark this post and the followings unread
A friend and I are looking to make some MOTM-format front panels, with silkscreened graphics on powder-coated aluminum. To defray costs, I'm wondering if we should make more than 2.
The design is based heavily on Bill & Will's 5U design. In lieu of switches, we chose normalized jacks for the Driver & PWM links, and dedicated jacks for Saw & Pulse. The Pulse outputs will require amps to boost them to MOTM levels.
The non-Bourns knobs are all smaller Alco knobs, like on the Encore UEG.
If you'd be interested in purchasing one for a reasonable price (US$40-50?), then please contact me ASAP. This is not a firm commitment; I'm just trying to gauge interest to see how many panels I should make.
Oh, and I'm open to suggestions on what to do with that blank space. Wink
JH_LivingVCO_5U.pdf
 Filename:  JH_LivingVCO_5U.pdf
 Filesize:  116.37 KB
 Downloaded:  448 Time(s)
MR-808
PostPosted: Mon Oct 25, 2010 6:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Has anyone found that they actually need the trim pots on the front panel?
