My patch contribution.
Page 1 of 1 [5 Posts]
anykeystudio
PostPosted: Tue Feb 01, 2005 3:06 am    Post subject: My patch contribution. Reply with quote  Mark this post and the followings unread
The only thins you need to do is to tell me witch one you liked best, and why.
Greetings Glenn.
Andy Kraft ModW.syx
Andy Kraft;
Sequncer patch with short delay. If you turn the mod wheel al the way up you get self oscillation on filter 2. Veeery Kraftwe….
 Filename:  Andy Kraft ModW.syx
 Filesize:  2.29 KB
 Downloaded:  315 Time(s)
Mystic Sparkle Pad.syx
Mystic Sparkle;
Super SEM pad that use only filter 1 and no saturation. Plus that the filter env fall back after the attack phase.
 Filename:  Mystic Sparkle Pad.syx
 Filesize:  2.29 KB
 Downloaded:  314 Time(s)
SH05 Bass.syx
SH-05 Bass;
Square bass with lot of resonance, that gives it a hollow shimmer.
 Filename:  SH05 Bass.syx
 Filesize:  2.29 KB
sunny pedaal
Audio files: 12
PostPosted: Tue Feb 01, 2005 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
i 'm going to try them, let you know my humble opinion.
by the way, would it be an idea to remove one of the folders or are they different?
greetings, sunny
anykeystudio
PostPosted: Tue Feb 01, 2005 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I couldent upload more than 3 files per thread ?? Rolling Eyes That way it's two threads.
Audio files: 107
PostPosted: Tue Feb 01, 2005 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
You can post more than three to a thread (topic), but only three attachments in a single post.
sunny pedaal
Audio files: 12
PostPosted: Tue Feb 01, 2005 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
oke, well i've to download the other 3 then also.
first the top 3 of this topic:
place 3 (to my taste):andy kraft: a bit tin, not much body. the ribbon does it well, the mod wheel effect is not very noticable on my system
number 2: mistic sparkle: full sound , even without the effects put on.
tip of the set: sh05 bass; a nice tight bass. also the switchable pingpong effect i like a lot . wondered what the idea behind modulating the subosc. by random voice is?
going to download the other set.
Niio2
