Sleeveless LED
Page 1 of 1 [5 Posts]
Sugarfree
PostPosted: Tue Sep 07, 2010 4:09 pm    Post subject: Sleeveless LED Reply with quote  Mark this post and the followings unread
I'm trying to mount a small, round LED through a hole in an aluminum panel.
The size of the hole is perfectly matched to the LED, so I don't want to use a plastic sleeve. I just need to somehow attach it from the other side of the panel. Any ideas how to do it?
(possibly without glue, so that the LED can be replaced when it burns out)
Sound
PostPosted: Tue Sep 07, 2010 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Try a drop of silicone sealant. You always can remove it.
Danno Gee Ray
PostPosted: Tue Sep 07, 2010 7:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Crafter's Hot Glue.
stolenfat
PostPosted: Sat Sep 18, 2010 12:25 am    Post subject: Reply with quote  Mark this post and the followings unread
i used to use tape between the leads... ifs its soldered down well, the tape will be fine.
for example, dont soldier it to a wire but directly to a surface mounted pot via it's lead, that should hold it there.
Sugarfree
PostPosted: Sat Sep 18, 2010 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
this is a great idea, thanks! I'm gonna cut a piece of perforated board, solder the LED and fix the board with tape to the back of my control panel.
Niio1
