 Forum index » DIY Hardware and Software » Synthasystem
VCF up and filtering
Post new topic   Reply to topic Moderators: dingebre
Page 1 of 1 [5 Posts]
delayed
PostPosted: Fri Sep 24, 2010 12:08 am    Post subject: VCF up and filtering Reply with quote  Mark this post and the followings unread
Here are some images of the VCF. A simple and easy build with great sounding results. Worked without any debugging. Stuff, wire, add power, and filter!
 Filesize:  131.14 KB
 Viewed:  644 Time(s)
delayed
PostPosted: Fri Sep 24, 2010 12:10 am    Post subject: Reply with quote  Mark this post and the followings unread
filter stuffed and power board
 Filesize:  192.5 KB
 Viewed:  8556 Time(s)
 Filesize:  254.01 KB
 Viewed:  533 Time(s)
 Filesize:  195.65 KB
 Viewed:  542 Time(s)
gwaidan
PostPosted: Fri Sep 24, 2010 4:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice!
kjackman
PostPosted: Fri Sep 24, 2010 8:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, you've been quite busy!
I've got a month or two before I can start diving into this project. I have most of the tools I need, but I'm still short an oscilloscope and a few other odds and ends. And then I'll need to start stocking up on pots, trimpots, knobs, and all the rest. But pretty soon I'll be placing an order for a few of those PCBs (VCO, Filter, VCA, and Triple EG to start).
I decided to shoot for two power supplies, rather than having to deal with the headaches of converting 15v modules for 12v or vice versa. I was going to start the DIY system with MFOS modules, but I'd like to try these instead.
dingebre
PostPosted: Sat Sep 25, 2010 2:54 am    Post subject: Reply with quote  Mark this post and the followings unread
It's hard to go wrong. There are so many great modules out there you'll have fun with whatever you decide to do.
Of course, I think the Steiner modules are the coolest ones right now, but I'm hardly biased Wink
Two supplies is not a bad way to go, however, with the onboard regulators, at least for my designs, it's pretty straight forward to run the Steiner modules on +/- 15 volts.
Give me a call and you could come over sometime and I'll show you how I'm dealing with mixed voltage modules.
David
dingebre@3dphysics.net
