 Forum index » Instruments and Equipment » Nord stage
Nord Electro 2---Contact Pad Problems!!!!
Jared_Pauley
PostPosted: Mon Sep 27, 2010 7:21 pm    Post subject: Nord Electro 2---Contact Pad Problems!!!! Reply with quote  Mark this post and the followings unread
Hello All,
I recently spilled grape soda all over my Nord Electro 2. In the process, I took it apart and let it dry out for 2 days. Luckily everything still works but I think I might have created a bigger problem.
When I turned it on, the G above middle C was going in and out of producing sound. I've taken apart my board before so I took it apart and removed the circuit panel underneath the keyboard, where the contact pads are. I took off the rubber pads to see if something had happened to the connection.
Now, when I put the contact pads back on the circuit board and turn on the keyboard, only ONE of the keys between middle C and G work.
Did I mess up big time by taking the contact pads out of their little grooves? Does Clavia sale the part I need with all of the contact pads intact? Any help is GREATLY appreciated!!!
Niio1
