mattmumu
Posted: Tue Sep 28, 2010 3:38 pm Post subject:
modelling an fm patch from pluggo Subject description: patch modelling |
I don't know if this is the correct place to post this question. I would like to model a particular preset from a pluggo plugin fm 4op, attached is the screen shot. For those experienced g2 modular programmers, is this particular patch a possibility, it is called film strip testtone. In other words as a total beginner should I even attempt it? it is just it would be nice not to take out a laptop just to run one or 2 sounds for live!
| an editor view of the plugin |
12.66 KB |
| Viewed: |
3065 Time(s) |
| a graphical view of the plugin |
80.41 KB |
| Viewed: |
102 Time(s) |
Audio files: 211
G2 patch files: 92
Posted: Wed Sep 29, 2010 3:17 am Post subject:
Everything is possible with the G2 - do you have more information about what a film strip testtone is, and maybe some illustration of pluggo's signal chain?
Regardless, you should always try stuff on the G2, that's what it's for. You'll run into all kinds of happy accidents on the way.
@soundcloud @Flattr @myspace A blog home - you can't explain music |
ian-s
Joined: Apr 01, 2004 Posts: 2516 Location: Auckland, New Zealand
Audio files: 42
G2 patch files: 584
mattmumu
Posted: Thu Sep 30, 2010 10:08 am Post subject:
fm 4 pluggo patch |
| Thanks for this I will check it out, the only information I have about the patch, apart from hearing it are the 2 screen grabs I did of the preset. |
mattmumu
Posted: Thu Sep 30, 2010 11:51 am Post subject:
filmstrip testtone pluggo patch |
Have only so much info from the pluggo interface, have tweaked the envelopes etc and frequencies. attached is the sound of the pluggo preset c note held down for a few seconds, then just played instaneously, likewise up the register and down. also attached the tweaked patch
| an mp3 of the pluggo preset |
 Download |
| Filename: |
film strip test tone C..mp3 |
1.22 MB |
| Downloaded: |
165 Time(s) |
| an edited version of the patch you kindly postted |
 Download |
| Filename: |
filmstrip_559 ed1.pch2 |
1.67 KB |
| Downloaded: |
322 Time(s) |
ian-s
Audio files: 42
G2 patch files: 584
mattmumu
Posted: Fri Oct 01, 2010 9:46 am Post subject:
filmstrip testtone pluggo patch Subject description: recreating a plugin preset |
Hi, Ian,
Thanks for posting this new patch, I am starting to get a handle on how to program and what to connect etc. The real issue with this sound is in creating the same settings, and more particularly the envelopes for each oscillator.
Is there a way of designing your own envelopes by building subroutines, using logic gates and an envelope with control inputs. I am not expecting someone to do it, I just wondered without me tearing my hair out, whther it is theoretically possible with the G2. I have emailed the pluggo designers of the preset, (hopefully they may get back to me) asking for some of the parameter settings, what frequencies, what time and gain factors for the envelopes, and whther there are any under the hood settings with the fm modulation. |
