<on air> PHOBoS presents: There is no show, or is there ?
Sawtooth from Triangle (or vice versa)
Page 1 of 1 [3 Posts]
ThreeFingersOfLove
PostPosted: Thu Sep 30, 2010 5:07 pm    Post subject: Sawtooth from Triangle (or vice versa) Reply with quote  Mark this post and the followings unread
I am looking for an elegant way to derive a sawtooth from a triangle waveform or vice versa. The two waves should have the same frequency and should be in phase when they start their cycles.
For instance, I can use a slew limiter with adjustable rise and fall times on a triangle waveform. If the fall time = 0, then it slews only the rise and thus produces an up saw but it's not a very "clean" saw. It's important that the ramp is as linear as possible.
Another way is to fully rectify a sawtooth; this however produces a tri with half the frequency. Plus it has an offset.
I have a few more ideas, but I am looking for the more direct way to do this.
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Thu Sep 30, 2010 6:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
A couple of methods in this patch. Purple modules give a triangle with same frequency, phase and no offset. Green module gives a triangle that has (I think) 90 phase shift from the first triangle.
saw-tri.pch2
 Filename:  saw-tri.pch2
 Filesize:  1.02 KB
 Downloaded:  356 Time(s)
ThreeFingersOfLove
PostPosted: Thu Sep 30, 2010 10:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks ian-s!
I will check this when I get home. Smile
