8-Step Sequencer with voltage controllable pattern (VCPS)
Page 9 of 13 [311 Posts]
Goto page: Previous 1, 2, 3, ..., 7, 8, 9, 10, 11, 12, 13 Next
diablojoy
PostPosted: Mon Aug 23, 2010 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
and a second noodle from exactly the same patch with just a few changes of settings [different clocking and the coarse offset changed]
vcps seq test 2.mp3
 Filename:  vcps seq test 2.mp3
 Filesize:  2.95 MB
 Downloaded:  260 Time(s)
emdot_ambient
PostPosted: Mon Aug 23, 2010 9:05 am    Post subject: Reply with quote  Mark this post and the followings unread
diablojoy wrote:
...not quite finished completely but along with everything else it is getting there slowly...
Woah...what's goin on with the pot mounting in that cabinet? Looks like you're mounting the pots behind the front panel so the knobs kind of go through the front panel? Strangely compelling.
I see an M-185 sequencer on the other side of the cabinet, too. I've got 2 of both sequencers to be built and am looking forward to programming the VCPS with the M-185 (clock the M-185 so that it only plays one pulse every 4 measures or something so the VCPS pattern changes are controlled more at a song level).
diablojoy
PostPosted: Mon Aug 23, 2010 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Smile yes exactly that. pots and switches are mounted on a piece of unequal ally angle set behind the front panel that also provides for the board mounting
there is also 6mm of perspex between, which i hope to light up at some point
to provide some back lighting
i have few of each M185 and VCPS seq + others to do so i'am following a similar plan as you there, really need to get on and do a master clock and some dividers soon but got to get my head round pic programing first though for the master clock
TekniK
PostPosted: Mon Aug 23, 2010 9:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
with a proper silkscreen or engraving your modules would be more as awesome
Very machine looking devices,i like them very much
diablojoy
PostPosted: Mon Aug 23, 2010 10:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks TeKniK
will be doing something along those lines haven't quite decided
what exactly as yet though I am leaning towards white with blue lettering
also note that is only a temp timber case for testing shown the real ones are still under construction also in wood but very organic looking lumpy and bent like bananas haha very labour intensive !
hence the vertical not quite 19 inch format 50mm width increments not the norm, material is easier to obtain and cheaper that way
PostPosted: Wed Aug 25, 2010 8:34 am    Post subject: Reply with quote  Mark this post and the followings unread
awesome!
fonitronik at
DamDuram
PostPosted: Thu Sep 02, 2010 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
i want to order 2 pcb´s , please.
greetings
oldmanfury
PostPosted: Sat Sep 25, 2010 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I finished up my VCPS8 this morning. The project documentation was great, although I recommend revising the comment
"MOTM Style Connector +15V / GND / -15V nothing special to take care about."
to "Unlike PCB graphics take care to place the tab on the bottom!"
I went with 2-color 2.5 mm LED's to save some space - I like this option. Since I used jacks on the board, I can swap S_LED and P_LED, depending on whether I want green/orange or red/orange LED's to show each step.
Works fine - except for one oddity... mine "boots up" funny every other time I power up. It shows active steps (LED's are lit) , but is unresponsive to the offset/fine/CV control. Cycle the power and it usually wakes up fine. Any ideas on this?
-gerald
http://buzzville.typepad.com/oldmanfury/2010/09/fonitronik-voltage-controlled-pattern-sequencer-8-vcps8.html
 Filesize:  795.77 KB
 Viewed:  74 Time(s)
PostPosted: Sun Sep 26, 2010 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
awesome work. your fracrack version looks amazing...
Embarassed yep. i somehow mixed that up...
Works fine -
good to hear.
i already built two units, both work fine.
maybe next time it stuckes you could check the clock for the ADC with a scope?
or try a different ADC - just guessing though...
fonitronik at
unterbit
PostPosted: Sun Sep 26, 2010 1:57 pm    Post subject: 8-Step Sequencer
Subject description: ODER FORM
Dear Matthias !
I would take 1(VCPS) psb,+2ring mod=comb.shipping?
Please confirm.
Oleg
oldmanfury
PostPosted: Sun Sep 26, 2010 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
maybe next time it stuckes you could check the clock for the ADC with a scope? or try a different ADC - just guessing though...
Yeah - it could have to do with my using an alternate ADC (mouser didn't have the recommended one). I used this one, which looks to be nominally the same, but perhaps it is just ever so slightly different...
http://www.nteinc.com/specs/2000to2099/pdf/nte2053.pdf
Audio files: 69
PostPosted: Sun Sep 26, 2010 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have that problem with a stuck clock on power up sometimes , i got round it by using a double pole momentary push to break switch , press it to break the supply a couple of times then good to go Very Happy , that's perhaps a lazy way to fix it , but works great for me Smile
www.myspace.com/skrogproductions
PostPosted: Mon Sep 27, 2010 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
dave, which ADC did you use?
(the ADC0801 provides an internal clock. however according to datasheet one would then need a 'start'-switch circuitry. so i went for an external clock for the ADC just to prevent the need of such an additional switch!)
fonitronik at
oldmanfury
PostPosted: Mon Sep 27, 2010 5:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks like you're onto something here - the data sheet for the DAC I used says :
"The device may be operated in the free−running mode by connecting
INTR to the WR input with CS = 0. To insure start−up under all possible conditions, an external WR pulse is required during the first power−up cycle."
Audio files: 69
PostPosted: Thu Sep 30, 2010 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Mattias , i used the ADC0804 from Farnel uk , just occasionally it sticks on step 8 at start up with all adc switches on, i had a look at the data sheet and i see the momentary grounding WR diagram , i'll try catching it under fault & test the clock feed.
PostPosted: Thu Sep 30, 2010 11:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Skrog Productions wrote:
...i had a look at the data sheet and i see the momentary grounding WR diagram
i thought the momentary grounding -WR is needed only when self-clocking is used (internal clock). strange that i never experienced any problems with three builds. BTW i am using a 0801, however they should be all the same despite their accuracy, i believe.
fonitronik at
LektroiD
PostPosted: Sat Oct 02, 2010 7:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Edit - double post Embarassed
My tunes available here
(check out the new Electro-Funk LP)
LektroiD
PostPosted: Sat Oct 02, 2010 7:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Would a BZY88 (5V1) be ok in place of Z1?
PostPosted: Sun Oct 03, 2010 11:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes, no problem.
fonitronik at
LektroiD
PostPosted: Wed Oct 06, 2010 9:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi a couple of questions;
1, can these work linked to make 16 steps? I'm thinking of building 2 into a single panel.
2, I'm in the process of ordering the 40xx series ICs, there seems to be many variants and some appear to have different functions, they all have different suffixes, which are recommended for each?
..I have some 40xx series ICs in my collection, but they are not prefixed with 'CD', is this essential?
Thanks in advance
PostPosted: Thu Oct 07, 2010 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
it is not that easy to link two 4017 to have more than 8 steps. the easiest way would be to clock one 4017 using the CLK+ input (that's how it works now), and to clock the 2nd 4017 using the CLK- input (pin13, with pin14 set HI). this way the two seqs would work alternating. i am not quite sure about the reset, though. anyone?
another interesting method would be what hoshuyama did. here you would have both 4017's linked sequential. however, i would not recommend to try modifying the PCBs to reflect his circuitry...
hoshuyama 16step 4017 seq
the suffixes are ordering information, actually (packaging, temperature range...).
the prefix can be the manufacturer and/or the type. in my circuit the 4017 is powered from +15V, so you definitely want to be sure to have a CMOS that can handle this. the parts with "HC" in their name (i.e. 74HC4017) are not suitable for +15V operation.
fonitronik at
XCenter
PostPosted: Thu Oct 07, 2010 3:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I´d just add a sequential switch circuit in front of both gate/trigger-ins to route the incoming clock. That way both VCPSs should be "addressed" one after another. Question
How may I be of disservice?
Music for conscious listening @ http://www.frankmakowski.com
PostPosted: Thu Oct 07, 2010 3:42 am    Post subject: Reply with quote  Mark this post and the followings unread
this and a divider upfront, and a mixer downstream.
i mean, it is called "modular"... Very Happy
fonitronik at
XCenter
PostPosted: Thu Oct 07, 2010 3:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep. Wink
I´m always trying to think in modules first before modifying (and probably frying) a project. I´m not willing to learn it the hard way, you see. Very Happy
werock
PostPosted: Tue Oct 12, 2010 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
-gerald
That's a nice build - how exactly do you wire the 2-color LED's? I'm interested in doing the same thing for mine, just not sure what gets wired to each leg of the LED - with normal LED's there are separate leads for anode/cathode.
Niio1
