  bingsatellites Mostly Ambient
Krautrock Phaser ... but maybe I make some mistakes...
Page 1 of 1 [10 Posts]
Lorenzo
PostPosted: Fri Oct 08, 2010 5:13 am    Post subject: Krautrock Phaser ... but maybe I make some mistakes... Reply with quote  Mark this post and the followings unread
I "finished" my "Krautrock Phaser" ... but maybe I make some mistakes...
the PCB was already populated, so I think I connect the pots not correctly!! Embarassed
my electronics knowledge are very basic... and I'm very slow to realize my plans Embarassed
anyway I cant ear the effect ... !!
The effect seems to be in by-pass mode, even if the phaser is turned off, the sound pass through the effect...
by-pass switch seems to be ok.
If I make a bridge between the Rate Jack pins I can ear a filter effected the input sound, but I cannot modulate it...
Lamps blinks... but I think to fast, I mean they doesn't blink slowly
I follow the explications of ths site but probably I make some mistakes...
I will try again following the schematics... but, any suggestions??
P.S. My brother have to play two gigs supporting NEU! in late October... it would be nice if my "Krautrock Phaser" will work fine Very Happy
Oh Yeah!
Yes!
Wow!
PostPosted: Fri Oct 08, 2010 5:22 am    Post subject: Re: Krautrock Phaser ... but maybe I make some mistakes... Reply with quote  Mark this post and the followings unread
WOW!! Then it MUST be fixed!!!
To support Neu! (minus Klaus of course Sad ) Is a very cool thing to be able to do. And I mean cool as in really good, because the word "cool" has become a bit of a cliche in recent years- anything that is crap is now cool. But Neu! are not crap at all!! Very Happy
ACHTUNG!
Luka
PostPosted: Fri Oct 08, 2010 5:47 am    Post subject: Reply with quote  Mark this post and the followings unread
cover up the lamps
problemchild
melbourne australia
TekniK
PostPosted: Fri Oct 08, 2010 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
There are some cool ppl here on the forum.
The Bad Producer
PostPosted: Fri Oct 08, 2010 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Luka wrote:
cover up the lamps
good advice! I remember the first one I made, and forgot to do that...
Embarassed
http://soundcloud.com/thebadproducer
Luka
PostPosted: Fri Oct 08, 2010 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
yup got stung by that one also Embarassed
problemchild
melbourne australia
Lorenzo
PostPosted: Sat Oct 09, 2010 4:42 am    Post subject: Reply with quote  Mark this post and the followings unread
to cover up the lamps = OK
but... so... Question
so... EDIT
I resolve some questions by miself Very Happy
but:
I can't modulate dry/wet effect... so the ouput give me always 100% dry and the effect. ??
I have some problem with "Modulation" knob that seems do not affect the sound... I'm reading someone else have my same problem
but I don't understand how resolve it... Confused
Thank you very much in advance for your kindly replies!
Oh Yeah!
Yes!
Wow!
Lorenzo
PostPosted: Mon Oct 11, 2010 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
hmm... Confused
I do not understand if i could adjust Modulation knob with R18... I mean I try to turn R18 (and/or R21) but seems to not affect the sound.
I prefer to use a potenciometer to control "DEPTH" instead of the pedal to ammount on pcb. Could you suggest me a value for this pot??
Thanks
Oh Yeah!
Yes!
Wow!
The Bad Producer
PostPosted: Mon Oct 11, 2010 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Lorenzo,
I think I remember reading somewhere that mod only really makes a difference if you listen to both outputs - stereo. But I think JH sums it up well...
I think amount would be the same as phasing amplitude, I mean you could just get rid of amount and not have it at all, just connect the two switched contacts of the amount jack with a piece of wire - do you have a switched socket there at the moment?
Lorenzo
PostPosted: Tue Oct 12, 2010 3:10 am    Post subject: Reply with quote  Mark this post and the followings unread
ehm... I just use a 100k Pot...
I'm testing my Phaser with a keybord... it is working better than using my guitar.
I think Modulation knob effect the phase, now I'm using "R" ouput...
I have to built a Y cable so I will be abble to use L-R ouput Embarassed
It is a very good Phaser! My brother likes it!
But i can't understand if it is possible to modulate WET/DRY.
I can't turn down the DRY volume !!! Rolling Eyes
Oh Yeah!
Yes!
Wow!
