  bingsatellites Mostly Ambient
Show me your G2's!
Page 6 of 8 [182 Posts]
mush
PostPosted: Fri Oct 01, 2010 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Latest pictures of my setup in Copenhagen. (Have added an Acidlab Bassline II, a Korg SQ10 sequencer and a white Micro Modular since these pictures)
And behind the curtain:
And finally some of the music made in here:
http://soundcloud.com/kuf-records/fejld-winter-in-trumansburg
dorremifasol
Audio files: 6
G2 patch files: 47
PostPosted: Sun Oct 03, 2010 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow, that looks pretty inspiring, nice studio!
Albert
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon Oct 11, 2010 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
My new setup means one less Nord g2 (2 has always been too much G2 power for me, keeping it down with one G2 is what's always worked best for me.
I always have something else to do some sequencing for me which has been the rs7000 --- until now. I am beyond awestruck by the addition of some new red swedish gear -- namely, the Elektron MachineDrum UW Shocked Its awesome and mindblowing!
The MD machine drum is pretty sick little monster. It can be so tame, and so wild, and both deceptively simple and incredibly deep at the same time ... the last time I felt like this about gear was when I first got a Micro Modular, and before that Lego(tm).
I finally got around to putting it into the studio (into the heart of the studio of course). I have it's midi out going into a G2 which then acts as a huge midi processor as well, which then remaps certain midi messages before sending them back to the md (and through to a splitter which feeds every other synth). This way I can take an incoming note, and for example, transpose it, chop it, add controllers, remap controllers, create additional lfo's, whatever -- you get the idea.
My synths all run into the G2's inputs which mix (mic, blofeld, x0xb0x, dark energy), the mix out goes into my 2880 looper (which can loop long sections), but I also have a dedicated (mixed to mono) loop send output which goes into one of the MD's audio inputs for true looping madness... the md's stereo out goes into the 2800 looper's aux input, meaning I don't need to use a mixer (since the 2880 can do 4 inputs).
the pc1600 controls the drum volumes of each of the 16 MD tracks, and it rocks Smile
This is a very good functional combo that includes both VA and true analogue . The Nord going through the Dark energy is pretty amazing (I use it to add osc's, filter fb, and as a final amp incl amp envelope - because the Dark energy only has one - which I have routed to the filter). The only tricky part that took some more effort was ensuring that the Dark Energy's output was compressed correctly (through an alesis 3630) to handle any signal or resonance setting, prior to going into the G2. Albert, thank you salut for the Doepfer Dark Energy recommendation. I love that synth/filter.
The Blofeld does other things so it doesn't overlap, which isn't much at the moment, but soon it will (c/o the MD).
 Filesize:  130.19 KB
 Viewed:  128 Time(s)
http://www.clavia.se/misc/users/daszgarncarz.htm
http://haagenlive.blogspot.com/
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon Oct 11, 2010 8:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
mush, nice setup ... the elektron(z) next to the G2 is well, well, well ... and the moog is looking quite "lush" Smile (I'm getting that feeling from the Dark Energy over here)
I just added a MD UW to my rig very recently, and well, well, well ...
/Dasz
iPassenger
G2 patch files: 78
PostPosted: Mon Oct 11, 2010 11:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
@ Dasz + Mush,
Them setups are looking great fellas.
Hope to really sort out the ergonomics in mine once (/if?) I get a new house.
iP (Ross)
dorremifasol
Audio files: 6
G2 patch files: 47
PostPosted: Tue Oct 12, 2010 1:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow Dasz! that looks like a pretty complicated setup, but also extremely versatile. I've read wonders about the MachineDrum, looks like "the definitive" drum machine.
Albert
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Wed Nov 03, 2010 8:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey Albert, actually the setup is not that complicated. midi wise the nord and elektron both can create midi messages and the nord can also process them ... audio wise, it's basic too, although with the uw feature of the elektron I am running out of outputs on the g2 (as I use it as a mixer, and want to send its mix out independently of output I want to send to a looper -- allowing for a 4x1 input to 2x2 output matrix)
now on my to-do in my Nord G2 custom sequencing system (parts of which work in a way like parameter locks in the elektrons machines combined with apreggios) is to add transpositions along the circle of fifths meaning I can travel around harmonies in safety... and if I find a thing I like then I can go with a flow ... while still being able to change things ...
another thing that I have been doing is which is OT is using the swing from the elektron and using it to swing my g2 sequencers (as well as record G2 variation changes as parameter locks) ...
I think the Nord G2 and eletrkon really belong together they really complement each other ... maybe because they're both red and come from sweden ....
and both are quality machines.
i do have much to learn about the elektrons though ... not going to buy more gear for a while ...
 Filesize:  31.69 KB
 Viewed:  5410 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Thu Nov 04, 2010 1:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like you've got some interesting inter-relationship stuff going on between the machines. I recently rewired my midi in my studio so I could get anything that makes midi to control anything that wants midi, thanks to an old MOTU XT and a custom built midi switch box, still need a few midi leads to finish it off though.
Say what!? Smile What do you mean?
Quality idea! Smile I have made a few weird patches in the Nord which use another slots semi random sequencer to change the variations but this method could yield some quality results.
Very much agree. Smile And the way you construct kits and can use the lfos make the MD pretty modular anyway.
SNEAKY SPAM ALERT : So far though I have been too chicken to use the Nord live so for my first outing I used the MD and a Virus C :
http://soundcloud.com/ipassenger/acrossborderspromo
I've had two of the beasts and I am still learning nearly every time I switch it on.
mm... Well I wouldn't be if the buggers at Elektron weren't bringing that damn Octatrack out!
I'm hoping that by using that I will be able to take the longer evolving pattern and sequence stuff from the Nord out with my to gigs without actually taking them.
iP (Ross)
mush
PostPosted: Thu Nov 04, 2010 2:40 am    Post subject: Reply with quote  Mark this post and the followings unread
That's easy. Make a midi-track outputing 16ths from the MD to the G2, use the 16ths to step the sequencer. Once you put shuffle on the MD the G2 will shuffle as well.
iPassenger
G2 patch files: 78
PostPosted: Thu Nov 04, 2010 2:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Doh! Of course, simple. Cheers. Smile
iP (Ross)
mush
PostPosted: Thu Nov 25, 2010 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
A bit has changed...
The Copenhagen Noise Lab today.
iPassenger
G2 patch files: 78
PostPosted: Thu Nov 25, 2010 3:44 am    Post subject: Reply with quote  Mark this post and the followings unread
mush wrote:
Wow, the Elektron/Acidlab rig looks sweet. Smile
iP (Ross)
BobTheDog
Audio files: 32
PostPosted: Thu Nov 25, 2010 5:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I was just thinking that.
klangumsetzer
Audio files: 10
PostPosted: Fri Nov 26, 2010 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
wow, vary noice! Very Happy
how did you integrate the manta in your setup?
best regards
eike
mush
PostPosted: Fri Nov 26, 2010 4:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. I use the Manta as a controller for the G2:
http://www.youtube.com/watch?v=bawAZn0Gi14
But the last weeks the focus has been on my own controller, the one on the left from the Monome 128. You can see that one here:
http://createdigitalmusic.com/2010/11/alternative-musical-expression-a-diy-pressure-sensitive-multi-ribbon-controller/
Audio files: 217
G2 patch files: 93
PostPosted: Fri Nov 26, 2010 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow - awesome controller! salut
mush
PostPosted: Fri Nov 26, 2010 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Tack, Antimon, att leka med den är faktiskt det mest inspirerande jag gjort med en synthesizer sen jag var typ 14...
klangumsetzer
Audio files: 10
PostPosted: Mon Nov 29, 2010 3:48 am    Post subject: Reply with quote  Mark this post and the followings unread
ahså, när ska du börja att tillverka fler till då? Jag vill har en sådan i alla fall! Very Happy
what data does your controller output? do you need a computer to use it?
best regards
eike
mush
PostPosted: Mon Nov 29, 2010 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
best regards
eike
Det blir bara ett ex av denna som den är nu...
It is using midi, sending only cc's. So no compu required. I've designed it for my g2. I can convert the data in the g2 for more conventional use, but i rarely do. I love my g2 and for softsynths like the marvellous aalto i use my Manta.
The g2 is nice as you have the voicenumber that you can route to the 2 muxes and set the pitch of each strip with a contolsequence and route the array of ccs through the muxes and get two continious controllers polyphonically on each note. I just set up two slots to cover all 12 touch-strips. Much more fast way to work than building 12 instances in each patch like i did with my first patches for this controller.
If i ever do build another controller it will be based around osc instead of midi, as the high resolution would make it even more costumizable.
Regards
Rasmus
klangumsetzer
Audio files: 10
PostPosted: Wed Dec 01, 2010 2:24 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the info, rasmus. Very Happy
if you ever should sell those, count me in.
best regards
eike
drumfish
PostPosted: Fri Dec 10, 2010 2:38 am    Post subject: Reply with quote  Mark this post and the followings unread
a small but efficient set-up Wink
 Filesize:  360.27 KB
 Viewed:  82 Time(s)
 Filesize:  360.27 KB
 Viewed:  92 Time(s)
Audio files: 217
G2 patch files: 93
PostPosted: Fri Dec 10, 2010 4:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah that looks like dynamite! Smile
klangumsetzer
Audio files: 10
PostPosted: Fri Dec 10, 2010 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for supporting the swedish economy, drumfish. Wink
looks user-friendly and well organized.
best regards
eike
Dougster
PostPosted: Fri Dec 10, 2010 5:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Drumfish, are you left handed?
Once you start down the modular path, forever will it dominate your destiny!
Blue LEDs are evil.
expermusic
PostPosted: Fri Dec 10, 2010 6:15 am    Post subject: Reply with quote  Mark this post and the followings unread
best regards
eike
Ha, I was jus tthinking the same thing sitting in my studio room. I've got a Nord Engine, a Nord LEad 2 keyboard, Machinedrum UW and all of my furniture is Ikea...
SO, are there any other swedish synth manufacturers? I don't want to leave anyone out!
Macbook 2.4 Unibody/Nord G2 Engine/9u of Euro Modules/Elektron Machinedrum SPS-1UW/NI Maschine/Novation Remote Zero SL MKII/
mps board
