going LFO crazy
Page 1 of 1 [12 Posts]
Audio files: 69
PostPosted: Sun Oct 17, 2010 4:35 am    Post subject: going LFO crazy
Subject description: More lfo's please
Damn, I ran out of lfo's on a patch , need to make space for more lfo's Very Happy.
i need to condense 3 older designed panels to free up space for a new 6 lfo panel i've templated in corel draw.
Panel design for 2 dual vc-lfo's done below and a new module panel design for 6 of Ray's http://www.musicfromouterspace.com/analogsynth/coolnewlfo.html
versatile multi waveform lfo , to be constructed on vero-board & panels drilled in the garden shed Smile .
more pics as i progress Smile .
3 older style single vc-lfo's i built in 2005 plus a 4th board will squeeze into 2 dual vc-lfos
 Filesize:  111.78 KB
 Viewed:  88 Time(s)
2 of the new dual vc-lfo's under construction also multi lfo , which is 6 of Ray's versatile lfo's (a circuit ray has on the website)
 Filesize:  140.48 KB
 Viewed:  95 Time(s)
www.myspace.com/skrogproductions
ashleym
PostPosted: Sun Oct 17, 2010 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
It is funny, there are many things in life you can never have too many of. On my list were horsepower, records, chocolate fingers and now LFOs. Most of the time something basic will do, exactly as you are making here!!
wmonk
Audio files: 12
PostPosted: Sun Oct 17, 2010 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks great again Dave!
Now I think of it, why do I only have LFOs without VC? o_O
How many VCAs do you have? Wink
Weblog!
Kits for synthesiser modules in Europe
Audio files: 69
PostPosted: Mon Oct 18, 2010 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Ashley....choccy fingers , yum , cadburys of course Smile Smile .
Wmonk ...."How many VCAs do you have?" i just have 6 at the moment , enough for a handfull of monosynths from the modular Smile .
wmonk
Audio files: 12
PostPosted: Mon Oct 18, 2010 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
No VCA control over all those modulations?
Weblog!
Audio files: 69
PostPosted: Tue Oct 26, 2010 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello ...
I have built 6 of http://www.musicfromouterspace.com/analogsynth/coolnewlfo.html
onto stripboard following the diagram as i go and added the crows nest wiring , also populated a 4th VC-LFO & wired ready for panel assembly , panels are almost ready to dress with sockets & pots , the 3 new design modules will be ready to use for Halloween stream on sunday , They will be ready Smile
 Filesize:  193.5 KB
 Viewed:  77 Time(s)
 Filesize:  74.73 KB
 Viewed:  84 Time(s)
Fenris
PostPosted: Tue Oct 26, 2010 5:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looking very nice indeed. I look forward to hearing them in action.
regards
Fenris
Windows OS Sir?
No thanks. I'd rather shove wasps up my ass
jordroid
PostPosted: Wed Oct 27, 2010 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice, i love Ray's cool LFO also and have built quite a few of them. Your stuff never fails to inspire and i have adopted a bunch of your "space saving" techniques into the modules i'm building, great stuff and great sounds from your recent sequencer and SVF threads.
Audio files: 69
PostPosted: Wed Oct 27, 2010 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the comments guys Smile , i'm probably going to have to review my current capacity on the "windscale" diy power plant for the modular after adding all these upgrades Very Happy.
6 multi LFO module complete , all working after some head scratching faults / mistakes Smile ......3 stripboard isolator drilled pads had micro slivers of copper shorting (classic 'non concentration'), drill more out , fixed.
forgot 2 wire links , fixed .
Sine wave trimmers all set, & all 6 tested with oscilliscope
as i was wiring i tested some different sizes of caps for the lfo rates i used 100N mylar for the high rate and a Wima 2.2uF box polyester instead of the 2- 10uF electrolytics back to back in the diagram.
I also used Log 100K pots for the rate controls , for me , they give a bit of fine adjustment at the lower speeds.
 Filesize:  89.96 KB
 Viewed:  75 Time(s)
 Filesize:  85.36 KB
 Viewed:  83 Time(s)
Audio files: 69
PostPosted: Sat Oct 30, 2010 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Pots arrived in the post today to finish the VC-LFO's All calibrated & tested , cool .
I found some 10uF non polar caps & have put them in the bottom 2 lfo's low speed switches on the 6 multi lfo module , great for very slow filter sweeps (windy landscape Smile ) .
sounds of 10 lfo modulation to follow Smile ...
 Filesize:  150.57 KB
 Viewed:  79 Time(s)
 Filesize:  100.29 KB
 Viewed:  78 Time(s)
Audio files: 69
PostPosted: Sat Oct 30, 2010 9:35 am    Post subject: Reply with quote  Mark this post and the followings unread
some vco sweeps & a very cold north wind Smile
Multi lfo wave forms & rates.mp3
going through the waveforms and rates on the mfos Multi lfo
 Filename:  Multi lfo wave forms & rates.mp3
 Filesize:  1.6 MB
 Downloaded:  171 Time(s)
VC-LFO rate sweep by hand.mp3
 Filename:  VC-LFO rate sweep by hand.mp3
 Filesize:  742.37 KB
 Downloaded:  149 Time(s)
VC-LFO modulated by 2 lfo's.mp3
2 triangle lfo's from the multi lfo, hooked up to cv1 and cv2 inputs , modulating the vc-lfo at different rates
 Filename:  VC-LFO modulated by 2 lfo's.mp3
 Filesize:  2.81 MB
 Downloaded:  151 Time(s)
super cold wind 10 lfo's - 5 vcf's.mp3
ice cold north winds , get your thermals on :D.....
3 noise generators hooked up to 5 vcf's , which are being modulated by 10 lfo's (all the new ones) run straight through a vca as an amp
 Filename:  super cold wind 10 lfo's - 5 vcf's.mp3
 Filesize:  6.5 MB
 Downloaded:  154 Time(s)
Fenris
PostPosted: Sat Oct 30, 2010 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Some great sounds Dave. You must be very pleased. Blimey that wind is cold!
regards
Fenris
Windows OS Sir?
