Best way to cut the tube VCA board?
Page 1 of 1 [8 Posts]
RSFC
PostPosted: Sun Oct 17, 2010 7:29 pm    Post subject: Best way to cut the tube VCA board?
Subject description: CGS65
I've never cut a PCB before. Any suggestions on the best way to do it?
fluxmonkey
PostPosted: Mon Oct 18, 2010 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
i just scored it pretty deep (multiple passes w/ a utility knife, on both sides) and snapped it. make sure to cut all the way thru all the foil. if it doesn't snap easily, score some more
www.fluxmonkey.com
shawn
PostPosted: Tue Oct 19, 2010 5:53 am    Post subject: Reply with quote  Mark this post and the followings unread
If you have access to a dremel and a cutting wheel that'd be a quick solution.
fluxmonkey
PostPosted: Wed Oct 20, 2010 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
wear a good dust mask... airbourne fiberglass particles = bad 4 u!
www.fluxmonkey.com
emdot_ambient
PostPosted: Wed Oct 20, 2010 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
What about drilling? Will any old bit work? I've got a bunch of old PCBs that didn't come with mounting holes (well, most have like one, but not 4 as I'd like). They actually all are made to fit 11/22 pin card edge connectors but I'm having trouble finding them.
tomcat
PostPosted: Fri Oct 22, 2010 3:34 am    Post subject: Reply with quote  Mark this post and the followings unread
A small handsaw Idea
PostPosted: Fri Oct 22, 2010 11:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I would definitely suggest that you score the board with an exacto knife.
First, cut the traces so that they don't pull up from the PCB. Then score the PCB as far as you can. At that point, you should be able to get a clean break.
The dremel tool will work, too -- however it is easy to end up with a crooked cut. In either case, make sure you get clean cuts on the traces -- they are are a real pain if they pull up from the board.
RSFC
PostPosted: Sat Oct 23, 2010 7:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks everyone, I just scored the boards on the copper side and snapped them. Worked great.
