Posted: Sat Aug 28, 2010 10:41 am Post subject:
| LektroiD wrote: | | Does this mean you're no longer making this module (or others) available for DIY? |
no!
since the publishing of the prebuilt module i did the VCPS-8 PCB, and i am currently working on the CV ringmod PCB
i just wanted to try out offering a professional built complete module. it worked out well and i will offer more, i believe. however, DIY rules! _________________
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids) / facebook (news) |
sonicwarrior
Joined: Dec 22, 2005 Posts: 189 Location: Cologne, Germany
Posted: Thu Oct 21, 2010 1:10 pm Post subject:
| fonik wrote: | | the board is not changing. i just replace R30 by a Z-diode. oh, and i incorporated the missing 100k resistor to GND for the AC mode - but i didn't change anything to the actual boards layout or part numbers. |
What about updating the rev2 documentation to include the Z-diode as an option?
Are the 10nF ceramics critical or is it safe to use e.g. 22nF or 47nF instead?
I have currently no 10nF lying around but I want to finish soldering my boards. |
Posted: Thu Oct 21, 2010 1:28 pm Post subject:
| sonicwarrior wrote: | Are the 10nF ceramics critical or is it safe to use e.g. 22nF or 47nF instead?
IMHO it is not that critical. it is for filtering noise, and taking the tolrances into account i would say it is oky to use a 22uF.
anyways, i think i need much more knowledge about all this filtering and decoupling stuff - wouldn't this be a great issue for an thread in the main DIY forum? _________________
fonitronik at
sonicwarrior
Posted: Thu Oct 21, 2010 2:06 pm Post subject:
| Then I'm curious why you chose 10 nF caps instead of the usual 100 nF. |
mark_olson
Joined: Oct 26, 2006 Posts: 177 Location: Lawrence, Kansas
Posted: Thu Oct 21, 2010 2:26 pm Post subject:
| fonik wrote: | | ...i need much more knowledge about all this filtering and decoupling stuff - wouldn't this be a great issue for an thread in the main DIY forum? |
Indeed it would! Just two nights ago I was breadboarding a circuit and found myself wishing I understood decoupling better.
Mark |
Posted: Thu Oct 21, 2010 3:31 pm Post subject:
| sonicwarrior wrote: | | Then I'm curious why you chose 10 nF caps instead of the usual 100 nF. |
because i had them ;-P
(you will find both versions in various of designs around here) _________________
fonitronik at
sonicwarrior
Posted: Thu Nov 04, 2010 1:04 pm Post subject:
Regarding the Zener:
The direction is towards R29 (black line)? |
Posted: Thu Nov 04, 2010 3:37 pm Post subject:
| sonicwarrior wrote: | Regarding the Zener:
yes. replace R29 by a 1k, and replace R30 by a Zener from GND to R29
(GND -->|-- R29). this will clamp the 15V down to the Zener value. _________________
fonitronik at
sonicwarrior
Posted: Sat Nov 06, 2010 8:22 am Post subject:
Ok, thanks.  |
jnuaury
Audio files: 9
Posted: Tue Dec 07, 2010 7:12 pm Post subject:
if i dont have trimpots, what would be the best value to replace the trimpot and the 10k resistor before it? 50k?
thanks _________________ az/gde
Flickr
YouTube |
Posted: Wed Dec 08, 2010 12:32 am Post subject:
| jnuaury wrote: | | if i dont have trimpots, what would be the best value to replace the trimpot and the 10k resistor before it? 50k? |
no. the best value would be the actual value of the potentiometer. so match the resistor to the pot (potentiometers have quite a huge tolerance... _________________
fonitronik at
RSFC
Posted: Sat Feb 05, 2011 7:32 pm Post subject:
| Am I right to think I could use a 3PDT as opposed to a 3PST just wired differently? PST's are f*ing expensive from mouser while PDTs aren't too bad... |
tazer
Posted: Thu Apr 14, 2011 10:56 am Post subject:
attenuverting mixer pcb |
please please please can you do a small run of these when you do the 4046 vco pcb run-i would so appreciate that i have been trying to track this pcb down to no avail-I'm sure others would be interested also, my modular isn't complete without it
I would certainly take a few pcb's of this mixer, see what you can do...............
many thanks
Ian |
