 Forum index » Instruments and Equipment » Nord stage
Is it possible to use the sustain pedal on the organ?
Page 1 of 1 [2 Posts]
martinshort
PostPosted: Tue Oct 26, 2010 1:26 pm    Post subject: Is it possible to use the sustain pedal on the organ?
Subject description: Is it possible to use the sustain pedal on the organ?
Hi
Can someone tell me if it is possible to set the Stage Ex sustain pedal to sustain the organ as it does for the piano and the synth? I realise it might not be terribly authentic, but I'd prefer it if it can be programmed to do this.
Martin
Pabl
PostPosted: Wed Oct 27, 2010 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure, you have to enable it. There's a button in each section (organ, piano, synth) that let's you enable the sustain in the section you like. Look for the word SUSTAIN on the organ section.
www.versusfive.com
www.myspace.com/versusfive
