<on air> Muied Lumens Frequencies
Ultimate Expandotron MFOS + hint of Buchla Photo Build Blog
Page 1 of 7 [168 Posts]
loydb
PostPosted: Tue Sep 28, 2010 1:34 pm    Post subject: Ultimate Expandotron MFOS + hint of Buchla Photo Build Blog
Subject description: A Custom 24-U Synth Build
My first build (see sig below) is now wrapped up except for a little glassblowing that is waiting on some ventilation work in my flame lair. The next one is quite a bit more ambitious.
The path of twisted logic that led me to this destination went roughly as follows:
Initially, I wanted to build an Ultimate to get something going more quickly than a full 5U cabinet of modules would take. Then I decided that I should build the Expander into the same cabinet, rather than building a separate one for it.
Then I decided that it would be cool to have the MFOS 16-step sequencer included as well rather than another separate box.
So I started arranging panels. If I put them side by side, it was wider than I liked. So I jammed the panels for the Ultimate and Expander together to make a 21" megapanel.
Putting the 16-step panel above them by itself looked funny -- so I suddenly had another huge chunk of panel space to fill. I thought about a second sequencer, but instead went on a PCB buying binge. I plan on doing a custom front panel the same size as the Ultimate + Expander panels that will contain all the other modules. This will be 24U (12U on each level).
The final cast is as follows:
MFOS Wall Wart Power Supply
MFOS Ultimate + Expander
MFOS 8-stage Phaser
MFOS Stereo Panner
MFOS Voltage Quantifier
Buchla 292c clone filter
This will be pic heavy. You've been warned...
loydb
PostPosted: Tue Sep 28, 2010 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
After digging through the wood stash, I've decided to use some 1" walnut boards for the casing (final thickness will be 0.75").
diablojoy
PostPosted: Tue Sep 28, 2010 4:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
love the nicely figured walnut should come up a treat ! Smile
can't get walnut like that here anymore not for 10 years at least
no one brings it in anymore Sad
loydb
PostPosted: Wed Sep 29, 2010 8:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Fortunately, it seems to be sustainably harvested here -- at least the board foot price hasn't been going up too much.
I love knots. Some people want nothing but clear wood, but I think they give the piece character. Unfortunately, they also cause a piece to come apart messily when using a jointer or planer on them (the blade 'grabs' the knot, or the edges around the voids). So the first thing I'm going to have to do is stabilize the wood so it can be surfaced.
Normally, I'd joint the rough edges smooth first thing, but as you'll see below, that would likely end badly.
diablojoy
PostPosted: Wed Sep 29, 2010 5:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree i generally don't try to avoid what is normally described as faults
or shakes in timber prefering to keep them in. i use an epoxy to fill them usually died a solid black so they remain very visible . for very small cracks
i tend to go with a thick super glue and drop fill . i like your build blogs
its very interesting to see others work in progress, keep up the good work Smile
loydb
PostPosted: Thu Sep 30, 2010 5:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Great minds, etc... Smile
Here's my fix for knots in Walnut.
Slow-set two-part NON-SHRINKING (that's important) epoxy tinted with analine dye (1 drop is plenty, I use Dark Walnut color).
Because of the rough edge pointed out earlier, I know that it's going to take multiple passes -- the first one will hopefully stabilize the edge enough to be jointed.
I put blue painter's tape on the bottom and side (make a dam), and clamp it hard to another board to reduce the amount of seepage I get.
Mix the epoxy (1:1), plus a drop of the dye. It's nice and runny (to fill small gaps), and has an open time of around 30 minutes @ 77 degrees F.
Pour some in, let it settle.
Keep topping off. Let it cure overnight.
loydb
PostPosted: Fri Oct 01, 2010 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
So, as expected with the rough edge, a bunch of the epoxy seeped into the side.
It *did* stabilize things enough that I could joint the edge, giving me a smooth surface for the next round of epoxy. For this second round, I clamped a piece of scrap behind the tape to make a stronger dam.
loydb
PostPosted: Sun Oct 03, 2010 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
So here's what the edge looks like now that it has been stabilized and jointed. The hard epoxy can be rough on blades, so I use a small block plane to remove the bulk of it (it's a whole lot easier to re-sharpen a block plane blade than it is the blades on my 13" electric planer...).
loydb
PostPosted: Tue Oct 05, 2010 5:23 am    Post subject: Reply with quote  Mark this post and the followings unread
More pics later today, but after working on the panel layout, I've decided to eliminate the voltage quantizer and go with a second 292c -- that will let me build one with fast vactrols and one with slow.
I've also decided to build two cases -- I can use the second one to start my 5U collection when I'm done with this build. I've got some nice birdseye Maple -- I'll do one as Walnut with Maple drawers, and the other the reverse.
loydb
PostPosted: Wed Oct 06, 2010 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
If you followed my calibrator build, you know I'm a fan of foamcore. Black foamcore is my layout tool of choice -- it's already square, and pencil writes and erases on it really well. It lets me do life-size drawings and test component arrangements.
This is my initial sketch (on paper) and my layout. After remeasuring the boards I'm using, I ended up shrinking the width at the top from 8" to 7".
This shows the layout of the PCBs -- I wanted to make sure there would be enough space for all of them (I've since swapped the quantizer with another 292c filter).
loydb
PostPosted: Fri Oct 08, 2010 5:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the birdseye maple I'm using for the sides of the second case, and the curly maple board (2.5" thick!) of curly maple I'll resaw for the top and bottom.
PostPosted: Fri Oct 08, 2010 5:56 am    Post subject: Reply with quote  Mark this post and the followings unread
What a lovely bit of wood! Cool
Looks lovely. Keep up the good work!
Tom
ACHTUNG!
diablojoy
PostPosted: Sat Oct 09, 2010 11:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
ah birdseye maple my all time favourite timber, will be a great contrast to that walnut Smile
loydb
PostPosted: Tue Oct 12, 2010 7:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I love birdseye maple. Machining it down to thickness sucks though, it likes to tearout.
Here's how the front panel is going to end up playing out. The second picture is my Photoshop mockup using a scan of the Expander front panel to get component size/spacing correct. Obviously, the labels are wrong, but the number/type of controls is correct for each module.
I created the shape in Illustrator and imported the resulting DXF into FPD Express. The next step is actually laying it out in FPD.
ashleym
PostPosted: Tue Oct 12, 2010 7:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I have got some FDP/Shaeffer files for the Ultimate, Expander and sequencer (I think) I can share with you if it's any help? I have made a couple of panel changes and additions but it could be a starting point.
loydb
PostPosted: Tue Oct 12, 2010 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
That would be fantastic! I started on a complete replacement for everything in the top half, but bailed on it when the panel cost broke $400 and I hadn't done anything but the 16-step and the auxiliary panels for the Ult/Exp. Smile
ashleym
PostPosted: Tue Oct 12, 2010 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
http://electro-music.com/forum/topic-39249-25.html
look for my post on page 2 for pictures.
The build has ground to a halt after the PCB were populated due to various outside problems. It is driving me crackers to be close.....
Just seen it is easy to attach some files so here goes.....
ultimate FP.fpd
 Filename:  ultimate FP.fpd
 Filesize:  2.58 KB
 Downloaded:  550 Time(s)
ashleym
PostPosted: Tue Oct 12, 2010 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
some more
expander FP.fpd
 Filename:  expander FP.fpd
 Filesize:  2.64 KB
 Downloaded:  511 Time(s)
expander FP.fpd
 Filesize:  2.64 KB
 Downloaded:  502 Time(s)
ashleym
PostPosted: Tue Oct 12, 2010 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Some sequencer layouts. FPD is easy to use and you will be able to change the colour and typefaces etc
seq round FP1.fpd
 Filename:  seq round FP1.fpd
 Filesize:  3.47 KB
 Downloaded:  532 Time(s)
seq round FP2.fpd
 Filename:  seq round FP2.fpd
 Filesize:  2.57 KB
 Downloaded:  496 Time(s)
seq round FP3.fpd
 Filename:  seq round FP3.fpd
 Filesize:  1.99 KB
 Downloaded:  499 Time(s)
loydb
PostPosted: Tue Oct 12, 2010 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I'll check these out.
loydb
PostPosted: Wed Oct 13, 2010 5:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Spent some quality time with a soldering iron the last couple of nights. All resistors are done, and most of the caps, for the Ultimate PCB.
loydb
PostPosted: Fri Oct 15, 2010 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Yesterday I started sorting out the front panel for the Ultimate. I'm probably one or two evenings away from having the PCB stuffed.
loydb
PostPosted: Sun Oct 17, 2010 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
So, the time to notice that your LED bezels are too big for the holes in the panel is *not* when they're the last bits you need to install Smile A little careful work with a stepped drillbit and they mounted fine...
The front panel is stuffed except for one switch. Apparently I used my only DPST switch somewhere else. I need to do a mouser order anyway...
loydb
PostPosted: Mon Oct 25, 2010 5:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pretty much all of my time for the last week+ has gone into making my flamework studio habitable. I finally finished off the ventilation work, and can start melting stuff again (which will let me finish the mini-controller project at last).
Still, I spent some time working on the Expander front panel -- I'm going to have to make a Mouser order for some missing parts for the Ultimate, I figured I should try and get some idea of everything I need. It turned out to be a good call, as you can see by the empty spots on the panel Smile
Audio files: 131
PostPosted: Sat Oct 30, 2010 12:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow , looking fantastic , it certianly helps to have a wood / metal workshop at hand for doing synth construction , a pillar drill is essential for me Smile , nice neat job with the components on the boards .
look forward to seeing the complete unit.
Great job so far.
epicyclus@skrogmusic.plus.com
