cw / ccw viewpoint for pots on cgs75?
Page 1 of 1 [5 Posts]
mcetilia
PostPosted: Mon Nov 01, 2010 7:33 am    Post subject: cw / ccw viewpoint for pots on cgs75?
Subject description: thinking from above with pins facing down
hi all,
i'm just finishing up my first two cgs panels, both cgs75s (the VCSs),
and wanted to make sure that i was thinking of counter-clockwise &
clockwise correctly before wiring up the pots…
http://www.cgs.synth.net/modules/cgs75_vcs.html
i'm thinking you'd be looking at the pot from above with the pins facing down?
mark
mcetilia
PostPosted: Tue Nov 02, 2010 10:41 am    Post subject: aha Reply with quote  Mark this post and the followings unread
not sure how i missed this before:
"The pots are viewed from the rear"
so that's 1/2 of the equation,
the other half being whether the pins are pointing up or down
when looking at them from the rear.
i guess i've got a 50/50 chance, so i can just try it out & see…
then if the polarity is wrong, just switch them around.
but if anyone knows offhand, it would be nice to just plug & go Smile
mark
mark.cetilia.org | mem1.com | reduxproject.com
andrewF
PostPosted: Sat Nov 13, 2010 8:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Mark
welcome to e-m
Usually Ken's wiring diagrams show the pots from the rear with pins pointing upwards.
This is from Ken's VCA page:
Viewing pots this way the ground connection will go on the left, input or +V on the right. The main point is to get the centre pin connection correct, the other two just determine which way the pot will operate.
otherunicorn
PostPosted: Fri Nov 19, 2010 12:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Physically take a pot, and twist it CCW. Look in the opening near the pins and you can see the wiper (16mm alpha type pot). That is the CCW end.
mcetilia
PostPosted: Sat Nov 20, 2010 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks andrew, ken…
it all makes sense now.
the modules sound amazing btw,
can't wait to get these racked up
& start on the next round of boards…
mark
Niio2
