SteamSynth NanoVerb hack
Page 1 of 1 [16 Posts]
dugernaut
PostPosted: Sat Nov 20, 2010 7:34 pm    Post subject: SteamSynth NanoVerb hack Reply with quote  Mark this post and the followings unread
Hi All,
Don Slepian suggested that I get an Alesis NanoVerb for my SteamSynth. I found one on Ebay for about $50 and modded it for my 5U/MU format.
Looks and sounds great!
 Filesize:  186.19 KB
 Viewed:  89 Time(s)
 Filesize:  317.03 KB
 Viewed:  102 Time(s)
Dan Lavin
Audio files: 20
PostPosted: Sat Nov 20, 2010 8:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great idea! I think a few of us have a bunch of those little box type things cluttering up shelves, drawers, etc. That's a really nice way to control the clutter!
Synth DIY since 1977!
PostPosted: Sun Nov 21, 2010 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I've already suggested several times before, doing the same to a Nord Micromodular. Just think what possibilities lie in that!!
ACHTUNG!
dugernaut
PostPosted: Sun Nov 21, 2010 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds cool! Has anyone popped the cover on that Micromodular bad boy to see how much effort would be? Any pix?
I also bought a Roland SC-7 Sound Canvas and plan to hack it into another SteamSynth module. It'll JUST fit, I think.
adambee7
PostPosted: Sun Nov 21, 2010 6:52 am    Post subject: Reply with quote  Mark this post and the followings unread
thas a good idea. didn't they do a nano piano aswell? Very Happy Very Happy
seraph
Editor
Editor
Audio files: 31
PostPosted: Sun Nov 21, 2010 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes, there was also the nano synth and the nano bass Exclamation
Politics is the entertainment division of the military industrial complex - Frank Zappa
sduck
PostPosted: Sun Nov 21, 2010 9:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dugernaut - how did you adapt the power for this? I imagine it runs on some weird voltages - I just see wires flying into yours. Do they come from a wallwart or something?
Pehr
PostPosted: Mon Nov 22, 2010 4:08 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.leinermedia.net/aries/Aries.html Smile
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
PostPosted: Mon Nov 22, 2010 5:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Aha! And what a beautiful panel too!! (although it should really be in red? Wink )
ACHTUNG!
dugernaut
PostPosted: Mon Nov 22, 2010 5:56 am    Post subject: Reply with quote  Mark this post and the followings unread
The wall wart was AC. On the unit's PCB, it gets half-wave rectified into a positive and negative supply, then into a 7805 and a 7905 respectively (if I recall the numbers correctly). I just hooked my main PS +/-15vdc into the inputs of these regulators and ground. I also added a small heat sink to one regulator since it now needs to disipate more heat due to the higher input voltages.
I also removed some unnecessary components such as jacks, etc that added bulk and weight - lord knows the SteamSynth already weights a ton.
Tim Servo
PostPosted: Sat Nov 27, 2010 12:15 am    Post subject: SteamSynth NanoVerb hack Reply with quote  Mark this post and the followings unread
Dug,
Beautiful work! BTW, ran across some an interesting bit of info: apparently Alesis sell refurished NanoVerbs on their web site
http://alesis.com/nanoverb
This doesn't guarantee they actually have some on hand, but for $50 it's worth a shot.
Tim (NanoNerd) Servo
sneakthief
PostPosted: Sat Nov 27, 2010 2:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Does this abomination I did 6 years ago count? lol
http://sneak-thief.com/nordrs7000.html
Sneak-Thief - raw electrofunk
adambee7
PostPosted: Sat Nov 27, 2010 7:37 am    Post subject: Reply with quote  Mark this post and the followings unread
i'm impressed sneakthief. Very Happy Very Happy
LektroiD
PostPosted: Tue Dec 14, 2010 2:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I've just done the nanoverb hack myself, although I find while it is powered up my ARP filter clone has a 50Hz hum, more evident when self oscillating.. As soon as I remove power from the nano, it is smooth again, it's only that filter that presents this problem though.
Also on a few of the settings (flanger/chorus/rotary) I'm getting zipper noise on the adjustment dial.. I wonder if maybe those 22µF/220µF electro-caps are needed to smooth this?
Maybe I've simply maxed out my PSU, I will look into it..
My tunes available here
(check out the new Electro-Funk LP)
LektroiD
PostPosted: Sun Apr 29, 2012 5:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Any idea how to increase the gain on this? It seems really low compared to the rest of the synth.
PostPosted: Sun Apr 29, 2012 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
That's awesome, how did you do the fillagree?
