Scrambled Phasers
Page 1 of 1 [3 Posts]
davep
Audio files: 10
G2 patch files: 73
PostPosted: Thu Feb 10, 2005 7:15 pm    Post subject: Scrambled Phasers Reply with quote  Mark this post and the followings unread
Here's a patch that is an attempt to mess up the phase shifters a bit, to make them a little less predictable. The upper screen is a simple synth, just a placeholder. The only thing to note is the keyboard-tracking filter, used as a frequency splitter at the end of the patch. This keeps the fundamentals out of the phasers & vocoders (the fundamentals get mixed back in later, just before the final TONE filters, via the green patch cords).
In the CVA, the signal goes through stereo phasers, one positive, one negative, with different sweep rates. The two channels then go through stereo vocoders, but each vocoder is controlled by the audio signal from the opposite channel. Try random vocoder band assignments. Enjoy!
PhaseVocodePad.pch2
Uses vocoders to mess up the phasers
 Filename:  PhaseVocodePad.pch2
 Filesize:  4.83 KB
 Downloaded:  1017 Time(s)
Dave Peck
Audio files: 143
PostPosted: Thu Feb 10, 2005 8:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very beautiful sounding. Very mysterious. Fun to play on the keys. Deep and organic.
davep
Audio files: 10
G2 patch files: 73
PostPosted: Fri Feb 11, 2005 2:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Howard. If you like that one you might like this too. It sounds like this
It's a big lush pad (no surprise) that uses the single-knob serial/parallel routing idea, but it uses it twice - first with a pair of phasers, then with a pair of filters. Various other tricks like two kinds of warming filters, and dual Chorus & dual Reverb for that bigbigsound.
This one actually has knob assignments and four variations. I especially like variation #4. Enjoy!
Lush Pad3.pch2
Like the name says - a Lush Pad
 Filename:  Lush Pad3.pch2
 Filesize:  7.18 KB
 Downloaded:  1021 Time(s)
Dave Peck
