 Forum index » How-tos » Visualizations - VJ etc
Instant VJ
Page 1 of 1 [3 Posts]
ARieu
PostPosted: Tue Dec 14, 2010 7:09 am    Post subject: Instant VJ
Subject description: Analog mobile VJ device.
Hello, I'm new on this forum. From 1960 on I am working with electronics. My speciality is analog visual hardware. Now, just before my retirement, I am back to basics, after the digital revolution. A month ago I started a project, making a small VJ device for your mobilephone. In short; this tool is feeded with audio/visual material from the AV output of my SGS phone. Any device with an AV pal/ntsc output will do. The sound is going to modulate (influence) the video and comes from a external line input or the build-in microphone. The video is going to pass some analog effects (wipe,posterisation, solarisation, inversion, etc) and leaves the device as a composite signal. The VJ device has the same size as an Iphone, incl. the battery. So, you can click this device on the back of your mobilephone. I talk about realtime videoprocessing. There are several manual controls to influence the outcome. This is an open hardware project and when there are some results I will show this on You Tube. Be patient, working with video circuits is of an other order as sound.
The name of the project is Instant VJ. Summary:
Design and construction of a small VJ device with RT analog videoeffects. This effects are under control of sound and manual sliders. The content comes from the mobilephone videoplayer (playlist) or any external pal/ntsc source. In the first half of 2011, I will publish the schematic diagram and board layout. Parts will be easy to get and all will do not more than 100 dollar.
egw
G2 patch files: 8
PostPosted: Tue Dec 14, 2010 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds interesting.
And Welcome to the forum!
www.gregwaltzer.com
tazer
PostPosted: Thu Dec 15, 2011 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey great project keep us posted.
