LM4250 VCF rev5 PCB EURORACK/FRAC run
Page 1 of 3 [70 Posts]
Goto page: 1, 2, 3 Next
haxster
PostPosted: Thu Jan 06, 2011 9:14 pm    Post subject: LM4250 VCF rev5 PCB EURORACK/FRAC run Reply with quote  Mark this post and the followings unread
NEW REV 6 IN EFFECT. IF YOU WANT ONE GO POST IN THIS THREAD:
http://www.electro-music.com/forum/topic-48995.html
This is REV5 old thread........
I revised another version of this circuit on pcb. I made it even easier to build and it can be self mounted. I added some screw holes in case you did not want to use the pcb mount parts. I designed this to be as pro as the other companies out there.
The power connector is in EURORACK format.
The core circuit did not change. I did get rid of the Pre-amp. It was nice but I wanted to make it compact. The Bi-polar FM is still there.
Anyone who missed out on the last run please let me know if you would be interested in getting one. I am asking $17.00 with shipping included WORLDWIDE USPS.Posted Image, might have been reduced in size. Click Image to view fullscreen.
The switch is this kind:Posted Image, might have been reduced in size. Click Image to view fullscreen.
The onboard 3.5mm jack is this kind:Posted Image, might have been reduced in size. Click Image to view fullscreen.[url][/url]
haxster
PostPosted: Thu Jan 06, 2011 9:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
The other IDC looking connector location is where you solder wires going to your jacks: BP out, FM in, etc. I use an IDC connector to another JACK pcb eliminating wires altogether.
snebenan
PostPosted: Fri Jan 07, 2011 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awesome!
I'm interested in two PCB's.
Do you want A PM with my details or how do you prefer to gather orders?
//s
haxster
PostPosted: Fri Jan 07, 2011 6:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am waiting for about 15-20 pcb requests before I order them. everyone interested just post a reply how many you want and later I will remind all to gather the funds to make the order. The turn around is about 7-10 days for pcb arrival and shipping out.
a100user
PostPosted: Sat Jan 08, 2011 12:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll take 1 please.
David
kollo
PostPosted: Sat Jan 08, 2011 3:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll take one as well!
rosch
PostPosted: Sat Jan 08, 2011 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
i'd like 1 also.
thanks!
haxster
PostPosted: Sat Jan 08, 2011 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I made a mouse BOM. This does not have LM4250 or ic sockets though. You need to get those elsewhere. Digikey carries LM4250.
This BOM also does not include the other (5) 3.5mm Jacks needed for the other inputs. You can use your own sources.
I really recommend to get the included 3.5mm jack in the BOM even though you might use this pcb for MOTM or 1/4" jacks. It serves as a strong pcb panel mount and you can use it to connect external 3.5mm gear. I have updated the pcb with another Audio In solder hole so if you were MOTM you can have a 1/4" jack also. On the picture above 'j6' has now become 'AIN1'
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=5d03e5a824
haxster
PostPosted: Sat Jan 08, 2011 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is the general part list:
2011 LM4250 VCF PART LIST
IC:
(1) TL074
(2) LM4250
TRANSISTOR
(1) 2N2222A
CAPACITORS:
(2) 10UF 0.1" SPACING
(2) 100NF 0.2" SPACING (5.08mm)
(2) 2UF - 2.2UF NON POLAR CAP
TRIMMER:
(1) 100K MULTI-TURN TRIMMER
POTENTIOMETERS:
(1) 10kK LINEAR
(2) 100K LINEAR
RESISTORS:
(6) 1K
(7) 10K
( 8 ) 100K
(1) 150K
(2) 1M
(1) 27K
(2) 10R-22R PROTECTION
(2) 200K
(1) 3K
(1) 4K7
(2) 47K
CONNECTORS
(1) IDC 16 PIN HEADER (8X2 DOUBLE ROW) 0.1" SPACING
THIS IS FOR EURORACK TYPE POWER CONNECTION.
OPTIONAL:
(2) SPDT TOGGLE SWITCHES FOR REZ HACK SWITCHES. ONE SWITCH RELAXES THE NOTCH, THE OTHER PUSHES THE NOTCH A BIT MORE.
THE LOCATION FOR THIS IS LABELED H1,CMN,H2. YOU HAVE TO SOLDER WIRES TO SWITCHES IF YOU WANT TO USE THIS FEATURE.
THE CMN (COMMON) GOES TO BOTH SWITCHES CENTER PIN. H1 GOES TO ONE SWITCH, H2 GOES TO THE OTHER.
haxster
PostPosted: Sat Jan 08, 2011 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
If this is your first DIY build and you own a EuroRack system I really recommend you try this out. You really can't mess up. It works at first power on, of coarse you have to turn the trimmer for proper Cutoff knob range. No measuring devices needed. It's adjusted by ear. Of coarse if you make a soldering mess and stuff the IC's wrong it will not work! Just be neat and patient.
Don't go mad trying to source the original UA Russian IC. The LM4250 has a flavor of it's own, respect it also. Just build and make noise.
fluxmonkey
PostPosted: Sat Jan 08, 2011 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
i would take 2, thx
www.fluxmonkey.com
RSFC
PostPosted: Sat Jan 08, 2011 8:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll take 1
Danno Gee Ray
PostPosted: Sat Jan 08, 2011 9:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for 1.
LektroiD
PostPosted: Sat Jan 08, 2011 11:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
1 here please Wink
LektroiD
haxster
PostPosted: Mon Jan 10, 2011 9:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
I made the order today.
So far I have this list:
DEGO-SWEDEN (2)
gpmacklin - USA SF (2)
snebenan - Sweden (2)
a100user (1)
kollo -SWEDEN (1)
rosch -GERMANY (1)
fluxmonkey -USA CLEVELAND (2)
RSFC (1)
Danno Gee Ray -USA PA (1)
LektroiD (1)
reflux (1)
iopop3 (1)
RF (2)
hodad -USA Atlanta (1)
synchroton -USA (1)
Rivelen -France (1)
tazer - UK (1)
diablojoy -Australia (2)
Feel free to jump aboard there is still room for this first run Rev5.
I should have it in my hands next week. I will build and post till then. It's a really slick design. Suitcase worthy stuff.
reflux
PostPosted: Mon Jan 10, 2011 11:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll take 1, thanks
iopop3
PostPosted: Tue Jan 11, 2011 2:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm interested in one board.
Do you have any schema available? The pcb is rather easy to follow, but if you have a schema please post.
Any special mods needed if running on 15v?
haxster
PostPosted: Tue Jan 11, 2011 2:28 am    Post subject: Reply with quote  Mark this post and the followings unread
No mods needed for 15v operation. There is a trimmer that can adjust for both formats. I personally have tried both 12v and 15v with no problems.
POLIVOKS LM4250.sch
 Filename:  POLIVOKS LM4250.sch
 Filesize:  28.73 KB
 Downloaded:  280 Time(s)
a100user
PostPosted: Tue Jan 11, 2011 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Haxter,
Sorry if this is a dumb question but what applications can read sch files?
Thanks
David
Dego
PostPosted: Tue Jan 11, 2011 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Eagle can read it
http://filext.com/file-extension/SCH
RF
Audio files: 28
PostPosted: Tue Jan 11, 2011 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd like 2 please!
www.sdiy.org/rfeng
a100user
PostPosted: Tue Jan 11, 2011 6:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Dego
David
haxster
PostPosted: Tue Jan 11, 2011 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
This free program is where i made it also:
http://www.expresspcb.com/expresspcbhtm/download.htm
I did not order the PCB's there, i just used the software Wink
rosch
PostPosted: Tue Jan 11, 2011 10:01 am    Post subject: Reply with quote  Mark this post and the followings unread
i can't open it with eagle.
it says something like there's invalid data in the file.
haxster
PostPosted: Tue Jan 11, 2011 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is the hole cutout if you plan to build the filter exactly the way I designed it. meaning you used all the pcb mount parts.
Download this free program to see it and to print it out.
http://www.abacom-online.de/uk/html/dateien/demos/viewlayout50.exe
When you print it out, uncheck "S2" to hide the measurements if you want.
EURO PANEL LM4250.zip
 Filename:  EURO PANEL LM4250.zip
 Filesize:  11.74 KB
 Downloaded:  304 Time(s)
