 Forum index » Instruments and Equipment » Sequencers
Anyone here with an Arp 1601 sequencer?
Page 1 of 1 [3 Posts]
sonicwarrior
PostPosted: Thu Nov 04, 2010 12:43 pm    Post subject: Anyone here with an Arp 1601 sequencer? Reply with quote  Mark this post and the followings unread
If someone here owns an Arp 1601 sequencer it would be nice if you could test the following:
1. Set all Position Gate Assignment (PGA) switches to bus 2
2. Connect bus 1 with the Step input
3. Connect bus 3 with the Reset input
4. Set the mode to 2x8
5. Switch one of the PGA switches to bus 1 or 3 while another step is active.
Does the sequencer step or reset directly or only when the changed step has been reached?
davebr
PostPosted: Sat Jan 15, 2011 12:25 pm    Post subject: Re: Anyone here with an Arp 1601 sequencer? Reply with quote  Mark this post and the followings unread
If I switch a gate to bus 3, it resets the sequencer. If I switch gate 5 to bus 3, the sequencer runs 1-4, 1-4
If I switch a gate to bus 1, it simply skips that step. If I switch gate 5 to bus 1, the sequencer runs 1-4, 6-8, 1-4, 6-8
In other words, the action is taken when the selected gate would have occurred.
sonicwarrior
PostPosted: Mon Jan 17, 2011 12:31 pm    Post subject:  Re: Anyone here with an Arp 1601 sequencer? Reply with quote  Mark this post and the followings unread
Thank you! Smile
JuneSolstice2013
