Computer Language Song Description
Page 1 of 2 [33 Posts]
Inventor
Audio files: 256
PostPosted: Sat Jan 22, 2011 11:29 pm    Post subject: Computer Language Song Description
Subject description: Must be an old idea
This morning, well, around 1:20am here, I had a sudden insight. I was listening to a song and the singer kind of messed up and stumbled through the words, then when he finished that section of lyrics, the lead guitarist took off on a jam. It was as if someone had written code in an event based language that said when(singer ends segment 1) {lead guitar jam 1;}, like that. In fact, computer language could be used to describe the entire song.
Then I thought - that has got to be the oldest one in the book! So I guess I'm asking if you're familiar with such things and what you know about them?
Les
Audio files: 211
G2 patch files: 92
PostPosted: Sun Jan 23, 2011 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I think the MIDI file format is event-based, like this (simplified):
Code:
wait 100ms: note down C1
wait 200ms: note down G1
wait 300ms: note up C1
wait 0ms note up G1.
http://www.sonicspot.com/guide/midifiles.html
It's a good thought. I've always found sheet music kind of annoying, partly because you have to constantly turn pages, since it wastes space for parts where nothing much is happening, or long notes are being used. Though the greater part of my annoyance is due to my not being very good at reading sheet music in the first place... Embarassed
I haven't gotten to grips what bachus is doing with his Zylaphone project, maybe he's got some clever solution there.
nobody
PostPosted: Sun Jan 23, 2011 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought everyone knew music and mathematics are inextricably intertwined.
Inventor
Audio files: 256
PostPosted: Sun Jan 23, 2011 11:32 am    Post subject: Reply with quote  Mark this post and the followings unread
oh come on now Damien, you know that's an oversimplification... I was specifically talking about making songs by describing them with event based computer language. To make some broad all-encompassing statement like that is to diminish music and mathematics into the realm of semantics.
I could say "the earth contains you" and then be satisfied with my limited knowledge of what you are without bothering to even look at you once. Anyway i grow tired, it's sunday so chill out man!!!
Audio files: 116
G2 patch files: 317
PostPosted: Sun Jan 23, 2011 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I once made this little time driven language ... as in :
<time-expression> function( params)
where time-expression would be an expression to evaluate to the time the function should be executed. The function then could specify other events to happen at times relative to the one passed ... some example code :
Code:
Include midi; // Include standard MIDI stuff
Include nm;   // Include standard Nord Modular stuff
Silence( aDevice);
  // Silence in the studio
  Loop( i, 1, 4);
    0 SetVolume( aDevice, i, 0);
FadeIn( aDevice, aCh);
  // Fade the Volume for aCh from 0 .. 127 - in 20 seconds
  Loop( i, 0, 127, 8);
    20.0 * i / 127 SetVolume( aDevice, aCh, i + 7);
FadeOut( aDevice, aCh);
  // Fade the Volume for aCh from 127 .. 0 - in 20 seconds
    20.0 * i / 127 SetVolume( aDevice, aCh, 120 - i);
FadeInSynth( aDevice);
  // Assuming Synth uses midi channels 1 .. 4
  Loop( i, 1, 4);
    0 FadeIn( aDevice, i);
FadeOutSynth( aDevice);
  Loop( i, 1, 4);
    0 FadeOut( aDevice, i);
// Ok a piece for 1 synth
StartPlay( aDevice, voice1, voice2, voice3, voice4);
  0.0 Silence    ( aDevice);                 // Silence all outputs
  0.0 SelectVoice( aDevice, 1, voice1);      // Switch in 4 new voices
  0.0 SelectVoice( aDevice, 2, voice2);
  0.0 SelectVoice( aDevice, 3, voice3);
  0.0 SelectVoice( aDevice, 4, voice4);
  7.0 FadeInSynth( aDevice);                 // Give voice switching 7 sec's
   0.0 FadeOutSynth( aDevice);               // takes 20 sec's
  21.0 SelectVoice ( aDevice, 1, voice1);    // so start selecting voices at 21 s.
  21.0 SelectVoice ( aDevice, 2, voice2);
  21.0 SelectVoice ( aDevice, 3, voice3);
  21.0 SelectVoice ( aDevice, 4, voice4);    // which we assume to take 7 s, so
  28.0 FadeInSynth ( aDevice);               // after that we fade in
PlayPiece( aDevice);
        0.0  StartPlay   ( aDevice, 101, 102, 103, 104); // at  0:00 - start with patches 101 .. 104
   6 * 60.0  Play        ( aDevice, 102, 104, 107, 108); // at  6:00 - switch to new set
  12 * 60.0  Play        ( aDevice, 101, 102, 103, 110); // at 12:00 - after 6 minutes switch to new set
  18 * 60.0  Play        ( aDevice, 109, 110, 107, 108); // at 18:00 - switch to new set
  24 * 60.0  FadeOutSynth( aDevice);                     // at 24:00 - fade to silence
                                                         // at 24:20 - all done
0 PlayPiece( 1); // Do it all, at time 0, on device 1
I used this to control not only synths (with MIDI), but for a slide show as well.
bachus
PostPosted: Sun Jan 23, 2011 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, not me. Zylaphon isn't geared toward processes that evolve in real time. I guess I must not understand what Chuck does. I would have though that would be right up its ally.
bachus
PostPosted: Sun Jan 23, 2011 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
If I were going to go that way I'd think about writing a language that would compile down into Chuck -- but again Chuck and I haven't really met. just a thought
nobody
PostPosted: Mon Jan 24, 2011 8:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool No worries, my friend. I dig!
Inventor
Audio files: 256
PostPosted: Mon Jan 24, 2011 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
My apologies Damien, I was in a very bad mood swing at the moment i wrote that I was trying to say F.U. politely, did that work? We good bro.
Les
nobody
PostPosted: Mon Jan 24, 2011 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Les
We're good, dude. I took it in good humour. I knew you didn't mean anything (and neither did I). No apology necessary. Cool
Audio files: 29
PostPosted: Mon Jan 24, 2011 5:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is a really cool idea, though I think that you would have to put some randomization into it, or else it would either play the same thing every time or just exactly what you tell it to do. Maybe for every event there are several things that could be triggered (or none) and it makes a random selection.
Inventor
Audio files: 256
PostPosted: Mon Jan 24, 2011 5:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, good point. The dafaflow graph of such a program would have multiple destinations per source with random or other factors determining outcome. This is done with the rand() function and the if() statement or in other ways.
Actually any language with a full set of features could do it, and ChucK is a music programming language and I know ChucK, so if i do get to working on this, i'll prolly ChucK it.
I think we have to have objects called "musicians" and "instruments" too, and model the thinking of a musician. Like Angus Young is thinking: "Just as soon as he gets done singing this section, I jam this jam or something like it" and that's modeled by the program.
Les
Audio files: 116
G2 patch files: 317
PostPosted: Mon Jan 24, 2011 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
That experiment is called CSound I think Wink
bachus
PostPosted: Mon Jan 24, 2011 6:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
CSound must have progressed a long way since I last looked at it Shocked
Inventor
Audio files: 256
PostPosted: Mon Jan 24, 2011 6:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, here is my musican thought model:
If (wantChicks) {
while (!gotChicks) {
play(guitar);
or something like that. but what i meant by that poorly prhased reference was, well you know what i meant. grrr!
Les
bachus
PostPosted: Mon Jan 24, 2011 8:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, my post was not a response to you, Les, rather it was to Mr Hell.
I just checked out CSound and can't tell that it has moved in any new directions in years. Did look at Rosegarden again too and it has been spiffed up quite a bit in the past few years. But still, no banana.
dewdrop_world
PostPosted: Tue Jan 25, 2011 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I did something like this in SuperCollider.
After a couple of false starts, I made a framework for live performance pieces. The main problem that the framework addresses is that the objects to produce complex musical behavior are themselves complex, and I wanted a way to invoke them using simple commands. That's been working well enough for me that I haven't had to redesign in the last 5+ years.
Then I needed to work on a couple of pieces that would be performable without my presence. That is, the things I would do in performance (loading processes and other resources, starting and stopping musical activities, adjusting controllers) needed to be automated.
It's based loosely on the Design Pattern called "Command." A command is an object that represents an activity to be carried out, and it holds information about the current state of that activity. It's commonly used when a task has to go through multiple stages -- you can just pass the command into the first stage, that stage updates the command's state and then passes it into the next stage etc.
I didn't need multiple states, but I did need to know at every moment everything that's happening. So a command answers isPlaying with true or false. You create the command, 'play' it, and when it finishes, it broadcasts a notification to say "I'm done." Commands can end by themselves if their child activity runs out of things to do, or they can run for a fixed duration, or they can set up a user trigger to stop (could be GUI, could be MIDI, could be OSC or anything else). So you're not limited to preset, deterministic sequences. (A command's activities need not be deterministic, either, though they could be.)
Command classes inherit from an abstract superclass, so this is all extensible. If you need a command that isn't supported, write a new one based on a pretty simple API ('fire' method to start, 'done' to stop and cleanup).
Above that, I have a command iterator, which takes a list of commands and some other tokens. It keeps track of which commands are still active, and removes them from the active list when it gets the "done" notification. That means, if you tell the iterator to stop, it can tell all its children to stop. It also handles timing.
Code:
   bpCmd: (name: \kick),
   16,  // 4 bars later
   bpCmd: (name: \snare)
Since \kick doesn't say to stop after 4 bars, both commands will run together and the iterator keeps both of them in the activeCmds set.
You can also have the iterator synchronize: wait for all active commands to finish before going on to the next thing, or wait for only the immediately preceding one. Iterators can also be nested, like sporking shreds in ChucK -- so this kind of synchronization can get really complex -- nest another iterator inside, then \cmdSync so that it will wait for everything inside the subiterator and let everything else run on its own.
Then I put a section object on top of that, which can play one or more iterators. It's also responsible for loading the resources needed for that section, and keeping instructions to release those resources later. The top level is a section sequencer, which runs one section after the other in order, and allows you to start at any section (like rehearsal markers in a score).
I started on that in 2008 for a scored violin/computer piece and pushed it a lot further within the last year. It's now handling an hour-long interactive dance piece! (I don't have to tell you the number of obscenities uttered to bring the framework up to that point... yes, a whole lot of thinking, testing and sweat went into this... but it works!)
James
dewdrop_world
PostPosted: Tue Jan 25, 2011 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
For grins, this is what a short section looks like:
Code:
   // start "BP(\op)"; reset its ampCtl
   bpCmd: (name: \op, dur: 35, shouldSync: false, prepareBP: { |bp|
      bp.ampCtl.value = 0.68;
      // if(d.class == DDWTimer) { d.reset };
   // wait 12 beats
   12,
   // fade out BP(\op) -- automate its ampCtl down
   gcAutoSynthCmd: (gc: BP(\op).ampCtl, name: \ctlPoint, outName: \outbus,
      value: 0, time: 22, curve: -2, shouldSync: false),
   // start BP(\st) at volume 0
   // and reset a [bleep]load of its parameters
   bpCmd: (name: \st, shouldSync: false, prepareBP: { |bp|
      bp.ampCtl.value = 0;
      bp.gest = Pseq([Pn(\slowSteps, { rrand(2, 4) }), \slowStepStretch], inf);
      bp.numEv = Pwhite(4, 7, inf);
      bp.gDelta = Pwhite(2.5, 4.0, inf);
      bp.slowRate = Pwhite(0.5, 0.8, inf);
      bp.defaultParms = nil;
      bp.kdecay = Pexprand(0.014, 0.017, inf);
      bp.makeStreamForKey(\kfreq);   // reset this one
      bp.autoRun = true;
      bp.gestures.oneKlankStepsCallback = { |parms|
         CleanupStream(~gestures[\oneKlankSteps].(parms).asStream, parms[\callback])
   // fade it up
   gcAutoSynthCmd: (gc: BP(\st).ampCtl, name: \ctlPoint, outName: \outbus,
      shouldSync: false,
      value: 0.7, time: 14, curve: 2)
Audio files: 116
G2 patch files: 317
PostPosted: Tue Jan 25, 2011 9:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Was afraid already I quoted a bit much Rolling Eyes
bachus
PostPosted: Tue Jan 25, 2011 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I was glad to be prodded to look at those again Very Happy
Audio files: 116
G2 patch files: 317
PostPosted: Tue Jan 25, 2011 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
How was it again with shit and roses?
Laughing
nobody
PostPosted: Tue Jan 25, 2011 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't roses like being fertilised with shit? Laughing
dewdrop_world
PostPosted: Tue Jan 25, 2011 9:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Should I apologize for making an on-topic post?
Maybe this is better: Oh goddess, I had an epic dump yesterday. What a difference a good poo makes.
Rolling Eyes
bachus
PostPosted: Wed Jan 26, 2011 6:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Creative inteligence often does not operate in a linear manner.
Or, quoth another,
She who would have roses most often walks on compost.
Or to quote Wilhelm Reich on the anal character structure ... ahh on second thought ... nuff said ...
bachus
PostPosted: Wed Jan 26, 2011 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Rolling Eyes
As to the code you posted I found the mapping between the lexical layout (formatting on the page) and the syntax delimiting tokens -- (,),{, and } -- to be impenetrable. Perhaps you could reformat it to make its structure more clear?
