JovianPyx
Joined: Nov 20, 2007 Posts: 1079 Location: West Red Spot, Jupiter
Audio files: 123
Posted: Fri Jan 14, 2011 11:01 am Post subject:
24 Bit I2S Stereo DAC up to 200 KHz SR |
http://www.digilentinc.com/Products/Detail.cfm?NavPath=2,719,859&Prod=PMOD-I2S
This is the same DAC circuit designed by Eric Brombaugh that I used in several of my FPGA synths. It is capable of up to 200 KHz sample rate. It will plug into a "standard" 6 pin Digilent port which appears on many devices including many FPGA development boards.
I post this only as a heads up to those looking for a stereo DAC with lots of bits and reasonably high sample rate. I do not work for Digilent. _________________ FPGA Synth Stuff
FatMan Mods
dsPIC Synth Stuff I am formerly known as ScottG here Time flies like a banana. Fruit flies when you're having fun. BTW, Do these genes make my ass look fat?
mhelin
Posted: Sat Jan 22, 2011 4:10 am Post subject:
| Circuit is the same but the pinout is different. Order of the DAC clock and data pins is mirrored in the digilent version. |
JovianPyx
Audio files: 123
Posted: Sat Jan 22, 2011 6:06 am Post subject:
True that. Eric laid out his board with components on both sides. Digilent reworked the board to put all components on one side. In the process, pins were changed. This is easy to deal with via the UCF file. _________________ FPGA Synth Stuff
FatMan Mods
sneakthief
Posted: Sun Jan 23, 2011 2:17 am Post subject:
Hope this isn't a thread-hijack...
For anyone who wants to do 2 stereo I2s in/outs via usb, check this out:
http://www.minidsp.com/onlinestore/details/64/14/i/o-cards/ministreamer
(it only goes up to 24/96 though)
Now if there were only a simple USB/Firewire to multichannel audio I2S interface!
I was hoping to diy some multichannel adc/dac's (ie. 8in/8out) but the only readily available "solution" to bringing that many I2S channels in and out of a computer is either:
1. buying an expensive dev board (eg. Dice II/III) or
2. converting it to ADAT (http://electronics.dantimax.dk/Kits/Digital_audio/index.html) then bringing that to a pc audio interface device that has ADAT in and out.
The costs for both add up quickly, making proper audio interfaces look like much more attractive alternatives to the diy-route. _________________ Sneak-Thief - raw electrofunk |
cloudscapes
Posted: Sun Jan 23, 2011 9:08 pm Post subject:
| sneakthief wrote: |
only? I have to work really hard going above 8/14 on my own projects!  _________________ Sonic Crayon DIY effects lab |
sneakthief
Posted: Mon Jan 24, 2011 2:04 am Post subject:
| cloudscapes wrote: | | sneakthief wrote: |
only? I have to work really hard going above 8/14 on my own projects!  |
Hey, 8bit / 14KHz sounds great to me! I just though I'd point that out since the title of the thread was "up to 200 KHz"  _________________ Sneak-Thief - raw electrofunk |
mhelin
